Elsmar Cove Quality DiscussionsInterpreting Partial Least Square ResultsThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
  Post Number #1
Old 8th July 2009, 01:21 PM
Estelita
Hello everyone,
I run a Partial Least Square analysis with 15 predictors in Minitab 15 and would appreciate some help on how to interpret the results.
Under "Model Selection and Validation", the Minitab output window gives a list of 10 "Components" that the PLS analysis has selected as best predictors. 'Components" are identified with number 1,2 etc and I do not know which predictors they are equivalent to. I do know that predictor 1 is NOT equivalent to component 1... So basically my question is how to relate components and predictors? What statistics (p-value? coefficient of regression? etc) does Minitab uses to select components?
Thanks for reading my post and for helping me. Please let me know if you need more details.
Regards,
Sponsored Links
  Post Number #2
Old 8th July 2009, 07:06 PM
Miner's Avatar
Re: Interpreting Partial Least Square Results
I am not an expert on Partial Least Squares (PLS), but I read Minitab's Help info on it. It described Components as being similar to the Factors in Factor Analysis of which I am familiar. It also described the purpose of PLS as condensing a large number of variables, some of which are highly correlated with each other to a reduced number of Components. Again, this is similar to Factor Analysis.
In Factor Analysis, Factors combine multiple variables that are correlated with each other into a single construct or factor that you must name. An example that I have seen took a study to "define" feebleness where many factors , such as gripping strength, arm movement, range of motion, etc. were measured. The study found that many of these measures were correlated and could be reduced to several macro-variables called factors. For example, gripping strength, arm strength, arm range of motion were grouped into a single factor named upper body.
Components appear to be the same concept. Highly correlated predictors are consolidated into a macro-predictor called a component. You must identify what they have in common and name the component.
Minitab uses Loadings to select components. Again, this is similar to Factor analysis. Look at the loading graph. Long lines have high loads. Lines that are very near each other are correlated.
That is as much as I can help you with.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Interpreting Linear Regression Results from Minitab stats_beginner Using Minitab Software 15 17th January 2014 05:42 PM
Interpreting Minitab Gauge R&R Results velan26 Using Minitab Software 6 22nd April 2011 08:18 AM
Partial Least Square Regression Result - Question iwotic Using Minitab Software 3 27th October 2009 11:28 PM
Chi Square Help - One of my variables has three possible results mobious_1 Using Minitab Software 15 19th May 2009 12:09 PM
Interpreting Lean Survey Results pinder Lean in Manufacturing and Service Industries 3 22nd February 2007 02:33 PM
The time now is 04:42 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
