The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards
Forum Username
Wooden Line
Difference between Calibration & Verification and How to calibrate Go/No Go gauge?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 11th July 2009, 01:17 AM
blue moon
Question Difference between Calibration & Verification and How to calibrate Go/No Go gauge?
Dear frineds
what is the difference between calibration and verification ?
and what about Gauge is it calibrated ? and how ?
Sponsored Links
  Post Number #2
Old 11th July 2009, 01:35 AM
Mike_H's Avatar
Mike_H
Re: how to calibrate the gauge ?
I'm from aerospace sector: I see calibration as the initial action whereby it "sets the baseline" for a piece of equipment (typically) against a known standard in controlled conditions - in a certified laboratory or other certified facility. This is the most formal method. It can then be used with confidence for all future verifications (measurements), usually in uncontrolled conditions, until an established schedule would require it to be calibrated again (under a periodic recalibration schedule). This cycle repeats for the life of the piece of equipment. Again, this is all quite formal.
If you are talking about simply verifying the same piece of equipment at time of use, this may be to check that basic functions are in working order. Checking for any obvious defects which might indicate possible malfunction. This might even entail testing the gauge over a range of values and compare the results to a known/expected value. This is similar to "calibration", but perhaps could be argued that it is not quite as formal. It would depend on what your quality system allows, what the gauge is used for, whether personnel are trained, what your customer requires from you and such...
~hope this helps a bit~
Sponsored Links
  Post Number #3
Old 11th July 2009, 01:45 AM
blue moon
i understand that from you and please correct me
when i have 5 thermometer . if i send one of them to calibrate outside it will be calibration and when i calibrate the another 4 meter inside it will be verification
is it right ?
i have gauge to check the conformity of product ( go or no go )
how i can calibrate these one ?
  Post Number #4
Old 11th July 2009, 02:15 AM
harry
Re: Difference between Calibration & Verification and How to calibrate Go/No Go gauge
Calibrate Go/NoGo gage
  Post Number #5
Old 11th July 2009, 02:16 AM
Mike_H's Avatar
Mike_H
you would have to show your "verification" process is robust and repeatable regardless of who performs it. in principle this is verifying the other 4 thermometers are fit for use, as they are measured against a calibrated piece of equipment (assuming they pass the verification to within a defined tolerance) but they are still not certified ie. they have not been calibrated by a certified facility/body. They may only be used as indication or reference only. It would depend a lot on how you define your process for accepting product.
in short: go/no-go gauges should also be calibrated and certified by an external facility as they accept product.
added:see above links by harry for more discussion (I should've known!)
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Verification vs. Validation vs. Calibration - What is the difference? Sean Manning Metrology Topics - Measurement Devices, Calibration and Test Laboratories 31 30th June 2014 08:24 PM
Calibration vs. Verification - Can we calibrate dial indicators in-house? dbzman ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3 15th April 2009 11:24 AM
What is the best way to calibrate a Go NoGo Gauge Calibration Sk0090 Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 18th May 2007 10:54 PM
What is the difference between in house calibration and verification? kbng82 Metrology Topics - Measurement Devices, Calibration and Test Laboratories 10 5th April 2007 10:37 PM
Wrong Calibration / Verification Result - Height gauge michu TS 16949 - International Automotive Quality Systems Standard 6 5th November 2006 08:20 PM
The time now is 12:30 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
