Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 9001 - Quality Management Systems Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 30th August 2000, 03:07 AM
eee eee is offline
Involved - Posts
Registration Date: Apr 2000
Karma Power: 39
eee has less than 100 Karma points so far.
Question Difficulties with Process Approach - Defining 'Effectiveness'
As I know the clause 0.2 "Process approach" in FDIS 9001:2000 again changed. Moreover there is an ISO/TC176' decision to produce special guidance module regarding this problem. Neverthless, how should I start, using cl. 4.1 of ISO 9001:2000?
4.1 a) Identifying processes
I identified
- 6 interested parties (customers,
stuff, owners etc.)
- 8 key production processes ( marketing, design, purchasing, production etc.)
- 7 main management processes (responsibilities,planning,recourses, measurement etc.)
So I have a matrix of 6*8*7=336 processes.OK
4.1 b) Determining the sequense and interaction of these processes. Ha-ha,
Shall I identify input and output for all these processes?
How shall I describe this interaction to stuff and auditors ( a matrix, a lot of flowcharts, in procedures)?
4.1 c) Determining criteria and methods required to ensure that both the operation and control of these processes are effective.
I don't know how to do it, because I understand that my internal and external auditors are not able to estimate: "Are operation and control really effective?".
And what is the noun for the adjective "effective" - effectiveness or efficiency. You know that it is a big difference between them.
Thank you in advance
Sponsored Links
Old 30th August 2000, 02:02 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
"4.1 b) Determining the sequense and interaction of these processes. Ha-ha,
How shall I describe this interaction to stuff and auditors ( a matrix, a lot of flowcharts, in procedures)?"
Perhaps the best visual way to show interactions between processes is with a Venn Diagram. All will be disproportionaly affected in all probability. You may elect first to do some type of Regression Analysis to determine correlation between processes to help you create the diagram. Inputs/outputs is a good place to start.
Regards,
Kevin
Sponsored Links
Old 30th August 2000, 02:47 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
"...4.1 c) Determining criteria and methods required to ensure that both the operation and control of these processes are effective..."
Inspections and tests.
"...I don't know how to do it, because I understand that my internal and external auditors are not able to estimate: "Are operation and control really effective?"
You determine this - not auditors.
"...And what is the noun for the adjective "effective" - effectiveness or efficiency. You know ..."
Effectiveness ~ Does it work and if so how well?
Efficiency is an input/output ratio in units appropriate to what you're looking at. There are natural gas furnaces which are 95% efficient and there are others which are 60% efficient. This is an instance of BTUs lost to entrophy (potential of the gas put in {input} vs the BTUs output to the home). In manufacturing processes things can get much more complex. Try an internet search for Machine Efficiency, for example. See what you get back...
Old 28th September 2000, 02:28 PM
Alan Cotterell
Unregistered Guest
Posts: n/a
I Say...
I suggest it is worthwhile flowcharting the Product or service delivery process, at he 'macro level', before embarking on preparation of your Procedure Manual. You might have over 300 sub processes but only one or two product types which the manual should address.
Old 3rd August 2001, 09:39 AM
HFowler's Avatar
HFowler HFowler is offline
Involved - Posts
Registration Date: Aug 2001
Karma Power: 36
HFowler has less than 100 Karma points so far.
Question Process Approach
I am developing a Quality Management System for a small company. I plan to use graphical process models like the one shown in the beginning of the ISO 9001:2000 Standard in place of writing text procedures, (except for the required 6) to describe our processes. Is anyone else taking this approach?
Old 3rd August 2001, 11:08 AM
ISO in Baltimore
Unregistered Guest
Posts: n/a
We are using some process models to describe high level functions but we are mostly using flowcharts in place of text procedures. From the registrars and auditors we've talked to, flowcharts seem to be preferred over text procedures as much as possible anyways!
Old 3rd August 2001, 06:40 PM
Al Dyer
Unregistered Guest
Posts: n/a
Just an opinion, but I find that the level 2 procedures lend themselves to be written documents that reference the work instructions that are flow-charted.
In reality, very few use the procedures, most use the work instructions and forms.
By flow-charting work instructions it makes it easier for the general work population to understand and perform.
ASD...
Old 5th August 2001, 02:58 AM
Marc's Avatar
Karma Power: 605
Hehehe...
-> I find that the level 2 procedures lend themselves to be
-> written documents that reference the work instructions
-> that are flow-charted.
I disagree. I believe level 2's are the first to be flow charted. I haven't had a client use text level 2's since 1995.
Reply
Bookmarks
Tags
effectiveness, process approach
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Approach towards defining/documenting Requirements COTS vs. New-Product v9991 Software Quality Assurance 1 13th August 2009 07:27 AM
Process Approach beef - Registrar says that we 'should' use the process approach Crusader ISO 19011 and ALL Auditing Discussions 20 2nd April 2006 08:47 PM
What's the difference between system approach and process approach? haifeng ISO 19011 and ALL Auditing Discussions 2 8th September 2005 07:54 AM
Systems Approach or Process Approach? Micro level of managing systems_thinker ISO 9001 - Quality Management Systems Standard 107 18th March 2004 08:32 AM
'Process Approach' to ISO 9000 Internal Audits - Identify an 'owner' for each process M Greenaway Internal Auditing 15 4th July 2003 03:27 AM
The time now is 04:35 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
