Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 3.00 average. Display Modes
Old 26th September 2001, 07:39 AM
Audrey
Unregistered Guest
Posts: n/a
Question Corrective Action Impact
I know this subject has probably been raised before, but I have not been here long...
I just read TS16949 standard regarding preventive action and corrective action and this is what I understand:
When you have got a fault and you rectify it, it is a corrective action.
When you have a similar product and you apply the same fix to prevent the same failure (lessons learnt), it is not a preventive action but a corrective action impact.
And then what is the difference between PA and CI?
Any thoughts??? I have got to admit I am a bit confused....
Sponsored Links
Old 26th September 2001, 11:04 AM
E Wall's Avatar
E Wall E Wall is offline
Just Me!
Registration Date: Jun 2001
Thanks Given to Others: 67
Karma Power: 63
E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.
I Say...
Audrey, We do not have nor have I read the TS16949 standard. Our current system is ISO 9002:1994. We do not use the phrase 'corrective action impact' only CA & PA.
We do apply 'lesson learned' knowledge to preventive action, because we did not go out of spec, nor was there a trend identifying we were heading out..rather only an improvement that precludes a possible failure. Example:Replacing friction roller type on all lines after the larger product had a problem. Other lines were not affected, nor were smaller product impacted...but to avoid the possibility...we upgraded all. So to us this would be identified as CA on the problem line/products and PA on all others.
The organization's documented prodedure should specify the appropriate sources of information that would be analyzed in order to detect and eliminate potential causes of nonconformities. These sources could include, but are not limited to: Nonconformity records; Results of Customer Satisfaction Surveys; Field, service, or customer complaints; Sub-contractor problems; Observations by personnel; Audit observations; Inspection & test records, Process monitoring results; etc...
Best wishes,
Sponsored Links
Old 26th September 2001, 11:27 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
Take a read through http://Elsmar.com/Forums/showthread.php?t=3189 for some thoughts on Preventive Actions.
Old 27th September 2001, 12:11 PM
Fire Girl's Avatar
Fire Girl Fire Girl is offline
Registration Date: Apr 2001
Karma Power: 37
Fire Girl has less than 100 Karma points so far.
Audrey
Hello. I just went thru this with my registrar a few months ago. I asked them to clarify the difference between Corrective & Preventive Action. I have copied the e-mail they sent me clearing this us. Check it out
"Corrective Action: Action taken to eliminate the cause of nonconformities
in order to prevent recurrence.
Preventive Action: Action taken to eliminate the causes of potential
nonconformities in order to prevent their occurrence.
Preventive Actions are typically generated through trend analysis of
processes and product related issues. They can also come about from
benchmarking and hypothetical situations that you have thought of but have
not yet happened.
Preventive Actions can also be demonstrated in applications like error
proofing."
I hope this helps you. Good luck!
Fire Girl
Old 28th September 2001, 05:22 AM
Audrey
Unregistered Guest
Posts: n/a
BIG Smile
That is very helpful thanks a lot.
Audrey
Old 28th September 2001, 03:01 PM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
CORRECTIVE ACTION: used to eliminate a current problem. More than likely thru root cause.(replace line leaking oil on parts)
CORRECTIVE ACTION IMPACT: used to eliminate problems in other areas that could face same problem,learn from our mistakes ( replace line on all machines that have the same type).
PREVENTIVE ACTION: identification of potential problems before they occur for action now. Action is usually based on facts data(FEMA is a good source (we hear gas is going up to $5.00 a gal, so we fill all of our tanks)
Many companies confuse the later two. All of the above result in continiual improvement of the QMS
Old 28th September 2001, 03:18 PM
Marc's Avatar
Karma Power: 605
Default
> type).
Thanks!
Old 1st April 2007, 08:04 AM
travi95 travi95 is offline
Registration Date: Apr 2005
Karma Power: 19
travi95 has less than 100 Karma points so far.
Default Re: Corrective Action Impact
The difference between Corrective Action Impact (CAI) & Preventive Action (PA) is based on the relationship of the entity. If an organisation has multi-location multiple units and in one unit you find a problem and take a Corrective Action (CA) and if the similar problem is possible in other units and you deploy the same action in the other units:
a) It will be called as CAI if the other unit is part of the group and has a common QMS certification
b) It will be called as PA if the unit has an independent QMS certification.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
High Level CAPA (Corrective Action Preventive Action) SOP Example Needed brecksnowshoer Nonconformance and Corrective Action 6 31st October 2009 10:45 PM
Difference between corrective action impact and preventive actions. Rameshwar25 ISO/TS 16949 - International Automotive Quality Systems Standard 2 18th August 2009 11:28 AM
CAPA (corrective action preventive action) Effectiveness - Medical Device Industry jampot Nonconformance and Corrective Action 3 26th February 2006 04:22 PM
Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Ace Nonconformance and Corrective Action 6 26th November 2001 01:47 AM
PREVENTIVE ACTION - Separating Corrective & Preventive Action. What am I gonna do? Raffy Preventive Action and Continuous Improvement 2 3rd September 2001 05:25 PM
The time now is 08:09 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
