The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Miner's MSA (Measurement Systems Analysis) Blog
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Wooden Line
Gage R&R Form in Excel for Calculating Gauge R&R - Attached - Page 4
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
gage r&r (repeatability and reproducibility), microsoft excel .xls .xlsx spreadsheet, forms and templates (general)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
  Post Number #25
Old 12th November 2010, 06:25 AM
Mr.Happy's Avatar
Mr.Happy
Re: Gage R&R Form in Excel for calculating gauge R&R attached
In Reply to Parent Post by Miner View Post
The form looks nice. I entered the Ford MSA validation data set to validate the calculations. The %TV and %Tol calculations are correct. There is a slight difference in the ndc results (13 vs. 14). This may be due to how many digits were carried out in the calculation.
If you want to enhance it, consider the other graphs shown in the MSA manual.
Hi all,
I changed Cell J92 to correct difference in the ndc results (13 vs. 14) into
=1,41*(C84/C77)
and now I have 14 ndc instead of 13.
Have a nice weekend
Mr.Happy
Sponsored Links
  Post Number #26
Old 14th November 2010, 03:48 PM
automoto's Avatar
automoto
Re: Gage R&R Form in Excel for Calculating Gauge R&R - Attached
In Reply to Parent Post by Amartinez View Post
Ales,
The cell H26 shows incorrect formula to get the average, show : promedio (H24:H25) and must be promedio (H23:H25),
Regards
Cell H26 calculate "AVERAGE(H23:H25)2.
I change formula for AV calculation. In new form AV is 0 in case of R analyses.
Aleš
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Sponsored Links
  Post Number #27
Old 16th November 2010, 03:42 PM
jdhigh
The Excel template KT.158_MSA looked really good, and it should be very helpful. However, I reentered data from a Gage R&R that I did with MiniTab and I got different results. Here are the results from MiniTab that I am interested in using:
Total Gage R&R %Tolerance (Study Var/Toler) 6.91%
Here is the results from the Excel template:100(R&R/Tol) 5.08%
Are Study Var/Toler and R&R/Tol considered to be the same? If so what could be causing the difference between the two numbers?
  Post Number #28
Old 18th November 2010, 05:01 PM
Mr.Happy's Avatar
Mr.Happy
In Reply to Parent Post by jdhigh View Post
Hi jdhigh,
Did you try to check your minitab data with the Measurement_System_Software_Callibration_Tables.xls
see elsewhere in the cove.
Success,
Mr.Happy
  Post Number #29
Old 18th November 2010, 05:23 PM
Sturmkind's Avatar
Sturmkind
Very nice clean interface. Do you plan to update to MSA 4th edition as well? Your good work would need only a couple of tweaks as the 4th edition does more clearly differentiate between Product and Process GR&R and acceptable % and also modified the 0-30% rule.
Capability comparison and rationale demonstrated that 0-30% error has a neglible effect on Ppk/Cpk estimates. It was noted that capability percentage uses 30% as derived from σ; when the σ˛ (variance) is used, the maximum is 10%. Over 30% the effect on accept/reject decisions is almost exponential. (Appendix B, Page 199).
Thanks!
  Post Number #30
Old 7th March 2011, 08:56 AM
Mr.Happy's Avatar
Mr.Happy
Hi automoto,
Just another question about your MSA Excel file:
I used it a couple of times now, but i wonder if it is not to be needed to fill in the minimal gage resolution ? For example when using a digimatic caliper fill in minimal gage resolution 0,01 mm or when using a micrometer fill in minimal gage resolution 0,001 mm etc.
cheers
Mr.Happy
  Post Number #31
Old 8th March 2011, 04:53 PM
automoto's Avatar
automoto
In Reply to Parent Post by Sturmkind View Post
Thanks!
I have in plan to add on the form calculation of PV from historical variation informations (Pp). See page 121. Also calcualtion described in appendix B will be added. Thans for your proposal.
What you mean under 0-30% rule? GRR criteria all the same as in MSA 3rd version, right? Page 78.
Form update will be made in one month.
Regards
  Post Number #32
Old 8th March 2011, 05:01 PM
automoto's Avatar
automoto
In Reply to Parent Post by Mr.Happy View Post
Hi automoto,
cheers
Mr.Happy
Hi Mr. Happy,
If gauge resolution is OK tells you ndc index. Do you want that I add on the form data about gauge resolution?
Regards
Reply
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Gage R&R / Inspection Sheet - Example Excel .xls Templates Attached D2theave Excel .xls Spreadsheet Templates and Tools 39 11th September 2014 02:33 PM
5S Scored Audit form - 5S audit form .xls Excel file attached jrubio Excel .xls Spreadsheet Templates and Tools 74 28th July 2014 10:06 PM
Type 1 Gauge (Gage) R&R Excel Template anyone? wrekin Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21 16th February 2012 09:21 PM
Gage R&R Excel .xls form and SPC Xbar and R template (lost it.. ) TownDawg Excel .xls Spreadsheet Templates and Tools 13 28th July 2009 06:43 AM
Gage R&R Form - Excel or other - Calculations Questions IGORTS Excel .xls Spreadsheet Templates and Tools 13 19th October 2006 07:57 AM
The time now is 06:16 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
