The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Supplier Quality Assurance and other Supplier Issues
Forum Username
Wooden Line
When to start counting supplier PPM? Supplier Performance Metrics
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
ppm (parts per million), qms (quality management system), reject rate, supplier performance, supplier control and monitoring, metrics (measurables such as for objectives)
Reply
  Post Number #1
Old 28th August 2009, 01:54 AM
jperez25
Please Help! When to start counting supplier PPM? Supplier Performance Metrics
Hi there. I have a question that I know does not have a black or white answer, but I'm basically looking for any interesting insights.
One of the metrics we use to measure supplier performance is supplier PPM, calculated in the conventional way or reject rate per million.
Now our systems are similar to B3, where we require our suppliers to submit a PPAP before starting production and then we have a further Job#1 date of the new product, which usually happens 3-4 months after our suppliers submit their PSWs. In this period of time we run our pre-production, which are saleable units to the customer.
Our current process is that anything that is rejected in the plant (IQ or in process) is considered in the supplier PPM calculation.
However, there is a question to whether we should only consider rejected parts after the Job1, since the first pre-production lots have a greater risk of quality issues (though supplier PSW should have been signed at this point of time).
Then the question is, considering the following two alternatives, which one is the one that represents more the supplier quality:
1) A metric that includes every rejected part when calculating the reject rate (this could include pre-series, prototypes, etc)?
2) A metric that include rejected parts after a 'stabilization period' of 3-4 months after supplier PSW?
The two options actually measure different things, Any of you see any particular benefit of using either one of the methods?
Javier
Sponsored Links
  Post Number #2
Old 28th August 2009, 08:00 AM
Kales Veggie's Avatar
Kales Veggie
Re: When to start counting supplier PPM?
All rejects. Very simple. Why is it OK for supplier to send in rejects during the first 4 months?
If APQP/FMEA/Control Plan/PPAP/GP12(or similar) are done effectively, why would there be any rejects from your supplier?
A reject is a reject.....same goes for proto-types.
Sponsored Links
  Post Number #3
Old 28th August 2009, 11:28 AM
Jim Wynne's Avatar
In Reply to Parent Post by Kales Veggie View Post
The reason for rejection is important; sometimes in the prototype or pre-production phase the design is fluid and things get thrown out that aren't necessarily the fault of the supplier. During this period of time, the objective should be design validation, and the less finger-pointing and blame-seeking the better.
As to the OP's question, I don't think that PPM makes any sense at all unless you're actually dealing with millions of things. We ask suppliers to insure that their processes are stable and capable, but both of those things are based on the concept of randomness. If there's (for example) only a chance of 100 in 1,000,000 that any defect will occur, it doesn't mean that 1,000,000 individuals must be created in order to see the 100 defects. This means that if a supplier's PPM rate is 1000 today, it might not be 1000 after a million iterations. The point is that if we can't know what the actual rate might be after a million chances, there's no sense in using estimates that don't take long-term randomness into account.
  Post Number #4
Old 30th August 2009, 01:29 PM
Kales Veggie
In Reply to Parent Post by Jim Wynne View Post
Very simple again. Then it is not the fault of the supplier, but engineering or purchasing or whoever.
A supplier reject is a supplier reject.
  Post Number #5
Old 30th August 2009, 03:29 PM
Jim Wynne's Avatar
What you don't seem to understand is that in the early stages, things can be very ambiguous, and move so quickly that it's difficult (and senseless) to try to ascribe blame. What's the point in starting the PPM clock when the product might be substantially different when real production begins? We all know that part of what got the US auto industry in trouble was (is?) their inveterate finger-pointing and blame-seeking. Why encourage it?
Thanks to Jim Wynne for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Trading Company - Evaluating Supplier Performance and Approved Supplier List sammy_sm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2 23rd February 2012 06:04 AM
Supplier Performance - Recording Supplier Performance for long term trend reporting KAMay ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8 16th February 2010 06:34 AM
Supplier Scorecard Metrics - Supplier PPM Quality Defects pammesue Supplier Quality Assurance and other Supplier Issues 12 15th August 2008 12:28 PM
Supplier Defects Per Million Metric - Best way to depict monthly supplier performance quality_ab Supplier Quality Assurance and other Supplier Issues 3 14th January 2005 09:24 AM
Supplier Quality Management including Supplier performance evaluation methods dspinelli Supplier Quality Assurance and other Supplier Issues 2 5th November 2003 10:08 PM
The time now is 08:14 AM. All times are GMT -4.
NOTE: This forum uses "Cookies"
