Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 4th October 2001, 12:13 PM
beky
Unregistered Guest
Posts: n/a
Unhappy Evidence of Records disposition?
Do we have to have evidence of records already disposed, I mean like a sheet that tells when a specific record was destroyed or something like that? I'm asking this because in the company I'm working now the procedure specifies that and I really would like to get rid of that requirement..what do you think?
Sponsored Links
Old 4th October 2001, 12:51 PM
energy
Unregistered Guest
Posts: n/a
Default My opinion.
BEKY
Ours says we shred all obsolete documents, period. When you look at revision history for a particular document, there's the date you shredded it. JMHO
Sponsored Links
Old 4th October 2001, 02:48 PM
Michael T's Avatar
Michael T Michael T is offline
Semper Gumby
Registration Date: Apr 2001
Thanks Given to Others: 5
Karma Power: 43
Michael T is appreciated, and has over 100 Karma points.Michael T is appreciated, and has over 100 Karma points.
Default Records Disposal
Hi Beky...
ISO 9001:1994 and 2000 specifies that documented procedures be maintained for disposition of quality records, but does not specify that records be maintained of the disposition of quality records. However it is probably prudent to maintain records of disposal.
Our records retention/disposition system is set up in such a way that a report of records requiring destruction is generated each month for each department. Upon destruction (shredding if hard copy, deletion from the computer if a data file) of the particular records, the person who has responsibility for those records signs off that they were destroyed. This is maintained by the QA Department as evidence of records disposal.
Hope this helps!!
Cheers!
Michael Thompson
"Personal mastery is not something you possess. It is a process. It is a life long discipline." Peter Senge
Old 4th October 2001, 03:43 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
ISO 9001 doesn't but QS-9000 does require you to specify disposal method, as I remember.
Old 4th October 2001, 03:57 PM
energy
Unregistered Guest
Posts: n/a
Default Shred it!
Here's the actual way it's written in our Document Revision Control procedure. I also send a document acknowledgement sheet for sign off with the obsolete document returned to me for disposal. Another reason we do that is because people have pulled the wrong page out and trashed it.
5.4.2 Quality documentation surpassed by a revision or replaced with another document shall be returned to the Quality Assurance Department in accordance with Quality Procedure QAP-205-04, Document Administration and Control, and a copy may be retained as a record, if deemed necessary, in an archive in a labeled file to ensure that these documents are secured from use.
5.4.3 Obsolete documents not required for archive purposes shall be immediately destroyed by shredding.
Old 4th October 2001, 04:09 PM
Michael T's Avatar
Semper Gumby
Karma Power: 43
Default I Don't Trust Them That Far...
That sounds good Energy, I wish I could trust them to do that.
When we have a controlled document change, either myself or my cohort in crime will personally remove obsolete documents and replace them with the new revision and destroy the old rev. Luckily we have a relatively small shop (150 employees) so this doesn't take too long. On the other hand, when it comes to the Quality Record, I have faith in those people assigned to maintain those files - so when records are disposed of, I know they are done properly.
Cheers!
Michael Thompson
Old 4th October 2001, 04:53 PM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
We are ISO 9002 and have set minimum retention times for all our QMS records. Have had no problem to date. The question is "What does your QMS require of you?"
Old 4th October 2001, 08:03 PM
beky
Unregistered Guest
Posts: n/a
Exclamation Records not documents!
Thanks for your comments guys, Energy: I have the impression that you are only looking the documentation side of it, what I'm talking about is more of quality recors such as inspection sheets, from 2 years ago for example, that certain department has to dispose every year and maybe (Not sure yet) live evidence of the date those were disposed.. get it?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Obsolete Quality Records - Approval Prior to Disposal dQApprentice Records and Data - Quality, Legal and Other Evidence 15 29th September 2009 11:16 AM
Disposition of Records - Describe HOW records are being disposed of? zhugxian Records and Data - Quality, Legal and Other Evidence 17 4th May 2005 06:39 PM
4.2.4 Control of Records - Can someone please clarify "...and disposition of records" Crusader Records and Data - Quality, Legal and Other Evidence 7 22nd April 2005 02:51 PM
Control of Records Definition - Controls needed and the 'disposition' of records DAHSR Records and Data - Quality, Legal and Other Evidence 6 11th July 2004 05:45 AM
Retention of Quality Records - NC for "access and disposal of quality records" JParrish Records and Data - Quality, Legal and Other Evidence 3 9th April 2000 01:15 AM
The time now is 02:27 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
