Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
24th September 2009, 06:53 AM
Shy Poster (1 to 5 Posts)
Registration Date: Jan 2009
Thanks Given to Others: 9
Karma Power: 18
Procedure is not Implemented - Audit Finding - ISO 9001 Clause 7.5.1?
If a procedure or activity in a procedure is not implemented, in what clause in ISO 9001 should it be called?
This has been a debate among our auditors on what specific clause in ISO 9001 this finding should called.
Our senior auditors and even one of the trainings we attended said it should be called againts clause 7.5.1 Control of Production and Service Provision.
However, other auditors said it is more appropriate to call it agains 4.1 (f) implement actions necessary to achieve planned results and continual improvement of these processes.
I just would like to know the practice of other auditors...
Please help... Your explanation on this matter would be appreciated...
Thanks!
24th September 2009, 07:05 AM
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 992
Karma Power: 484
Re: ISO 9001 Clause 7.5.1 (Auditing)
Write it against the requirement in the procedure! You don't have to write every nonconformity against ISO 9001.
If you still want to do it though, 7.5.1 would work for production operations, along with the requirement from your internal procedure. If it's an inspection operation, 8.2.4 would be more appropriate, along with the requirement from your internal procedure. For design use 7.3.1, along with the requirement from your internal procedure. Etc...
Thank You to howste for your informative Post and/or Attachment!
24th September 2009, 07:32 AM
Registration Date: Mar 2009
Thanks Given to Others: 12
Karma Power: 66
In Reply to Parent Post by Camit0212
Thanks!
If a procedure or activity of a procedure is not implemented the non-conformity is against the clause which was not implemented.You cannot generalise any one or two clauses.
V.J.Brahmaiah
VJBrahmaiah
24th September 2009, 08:23 AM
Getting Involved (6 to 9 Posts)
Registration Date: Oct 2007
Thanks Given to Others: 4
Karma Power: 23 Karma: 39
In Reply to Parent Post by howste
I would agree with this. If an internal audit, then I would not get hung up on the ISO9001 clause. If it is policy to write up against ISO9001, then it does not have to be a 1:1 relationship. Depending on the purpose of the procedure, you may have an NC against 7.5.1 and another appropriate clause.
Thank You to Allan66 for your informative Post and/or Attachment!
24th September 2009, 08:40 AM
Involved in Discussions
Registration Date: Nov 2006
Thanks Given to Others: 5
Karma Power: 29 Karma: 150
Re: Procedure is not Implemented - Audit Finding - ISO 9001 Clause 7.5.1?
I think you need to give consideration to the activity or procedure that is missing;
Is it a required procedure in ISO9001? I.E. "A documented procedure shall be established to define requirements for......"
Yes (and its missing) = Non-Conformity against the relevant clause.
No....
Does the procedure or activity impact on quality or regulatory compliance?
Yes - Then some control is required, such as described in 7.5.1, ask to see evidence of this control. If the organisation can suitably demonstrate and provide evidence of the control, you have no non-conformity. If they say, "Dave know's what he's doing, it's all in his head........." I would raise a non-conformity against 7.5.1 to in that no evidence could be shown that processes are being conducted under controlled conditions...
If the missing procedure or activity does not impact on quality or regulatory compliance, and is not explicited stated as required by the organisation, I would be inclined to say its an observation or recommendation for improvement at best.....
Thanks to seank for your informative Post and/or Attachment!
24th September 2009, 10:02 AM
Appreciated Information Resource
Registration Date: Oct 2006
Thanks Given to Others: 340
Karma Power: 169
I agree with Allan66 - if it is an internal audit raise it against the procedure, it will probably make more sense to internal people. If it is an external audit I would always raise against the standard.
I also agree with howste's comments and I would add that whilst quoting the standard and the procedure at the same time is fine, I think that only 1 clause of the standard should be quoted for any one situation. i.e. don't quote multiple clauses of the standard for the same N/C, it often causes confusion.
If you think training is expensive, try ignorance
Thank You to Colin for your informative Post and/or Attachment!
24th September 2009, 11:15 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
While I heartily agree in principle, I don't think it's a good idea to cite requirements that don't exist (which is what I take "not implemented" to mean).
What we need is for the OP to tell us what it means, why the procedure should have been implemented but wasn't, and what the requirements are for such things in his company. At what point must a procedure be implemented? Upon approval? Tuesday of next week? I think the problem might lie in the idea that such structure doesn't exist, and someone (perhaps justifiably) believes that he can satisfy an approval process and then implement the procedure when he gets around to it.
We aim to please. You aim too, please.
Thank You to Jim Wynne for your informative Post and/or Attachment!
24th September 2009, 12:11 PM
Appreciated Member
Registration Date: Apr 2005
Thanks Given to Others: 1,096
Karma Power: 71
In Reply to Parent Post by Jim Wynne
It seems to me that if the requirement has been called out in a written procedure then it exists, regardless of its merits or lack there of.
Things turn out best for those who make the best of the way things turn out. Jack Buck
Thanks to Doug Tropf for your informative Post and/or Attachment!
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Control of Nonconforming product, Clause 8.3 - Audit finding - No Procedure
mhuskey |
AS9100, Nadcap and related Aerospace Standards and Requirements |
18 |
19th May 2009 02:59 PM |
Customer Audit Finding against “where appropriate” of ISO 9001, Clause 7.4.2
dbzman |
ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions |
19 |
27th January 2009 04:23 AM |
One audit finding - deviated from 2 clauses of ISO 9001
mcenyll |
2 |
9th January 2009 08:18 AM |
ISO 9001 Clause 7.6 - Calibration - Audit finding
RosieA |
14 |
4th September 2008 01:45 PM |
ISO 9001:2000 - Exclusion of 7.5.2 - External Audit finding
Rosana |
33 |
21st March 2007 10:18 AM |
