Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
29th September 2009, 01:24 PM
Involved in Discussions
Registration Date: Sep 2006
Thanks Given to Others: 64
Karma Power: 50 Karma: 166
UCL (Upper Control Limit) Calculations - Sample Problem
X (double bar) = 35.0 and sigma = 5.0. n = 5....what is the upper control limit for the process ?
options a) 37.24 b) 37.89 c)41.71 d)52.50
My approach: UCL = X(2 bar) +/- 0.58 (5.0) / 2.326.
Answer from calculations = ~36
please assist why the answer is not one of the given options.
29th September 2009, 02:45 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,537
Karma Power: 400
Re: UCL (Upper Control Limit) Calculations - Sample Problem
Where is this question from?
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
29th September 2009, 03:19 PM
Dear Marc,
It is from the sample exam available on the ASQ website. Please see the attached file.
29th September 2009, 07:05 PM
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 391
You are using constants for Rbar instead of the StdDev.
Since StdDev = Rbar/d2, you can calculate the answer as follows:
UCL = X2Bar + (A2* d2 * StdDev)
UCL = 35.0 + (0.577 * 2.316 * 5.0) = 41.68;
However, ASQ appears to be using the equation for the population StdDev:
UCL = X2Bar + (3 * StdDev / SQRT(n))
UCL = 35.0 + (3 * 5.0 / SQRT(5)) = 41.71
Note that the answers are very close, presumably because the process was in a state of control. If the process had not been stable, the second method would have inflated the control limits.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
30th September 2009, 09:01 AM
Appreciated Information Resource
Registration Date: Mar 2002
Karma Power: 99
Not sure..,
UCL = X_bar + A2 * SIGMA = 35 + 0.577 * 5 = 37.89
A2 = 3/[d2*sqrt(n)]
d2= 2.326 => A2 = 0.577
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
30th September 2009, 06:01 PM
Karma Power: 391
In Reply to Parent Post by Darius
Not sure..,
A2 = 3/[d2*sqrt(n)]
UCL = X_bar + A2 * Rbar (not SIGMA)
Since SIGMA = Rbar / d2; Rbar = d2 * SIGMA
Therefore, UCL = X_bar + A2 * d2 * SIGMA
Side note: You could also simplify this to UCL = X_bar + 3 * SIGMA / sqrt(n)
1st October 2009, 09:48 AM
Karma Power: 99
ok,  I missed that it was not Range and I didn't recognized your initial formula, the simplificated formula looks fine.
30th November 2009, 06:16 AM
Shy Poster (1 to 5 Posts)
Registration Date: Dec 2007
Karma Power: 23 Karma: 10
In Reply to Parent Post by Miner
Miner,
Your derivation is exactly right.Not just ASQ uses this formula but everyone
Because whatever we use as constants (like A2...) are the simplified form of "3/sqrt(n)".These values are given in the table assuming 99.7% of variation is captured between LCL and UCL
Once we know this ,it demystifies the notion of "constants".
I will always recommend the formula X(doulble bar)+-(x) sigma/sqrt(n)
where X stands for statistic for respective confidence level
Hope this helps
Forum Posting Settings
