Elsmar Cove Quality DiscussionsIn-House Calibration - Digital Micrometer found Out of CalibrationThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
  Post Number #1
Old 2nd October 2009, 05:21 PM
tknchancs
Please Help! In-House Calibration - Digital Micrometer found Out of Calibration
We calibrate/verify, in-house against Jo-blocks calibrated to a known standard, the micrometers and calipers used for Production and Inspection. I recently came across a digital micrometer that is off .005 on the barrel and the screen is not working (probably dead battery). Can we make the necessary adjustments in-house or should we send it out to a calibration service?
Sponsored Links
  Post Number #2
Old 2nd October 2009, 05:23 PM
Stijloor's Avatar
Stijloor
Re: In-house calibration
Welcome to The Cove Forums!
If your technician has the required competencies to make the necessary repairs and adjustments, yes you can do this in-house.
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
  Post Number #3
Old 2nd October 2009, 09:17 PM
Big Jim
In Reply to Parent Post by tknchancs View Post
The fact that you are asking tells me you probably should not. Those skills are not hard to learn, but if you don't know them the consequences can be disastrous.
Thanks to Big Jim for your informative Post and/or Attachment!
  Post Number #4
Old 2nd October 2009, 09:39 PM
BradM's Avatar
BradM
Hello there! In other words, howdy, from a fellow Texan!
It depends on the reason the instrument is out of calibration. The parallelism may be off on the jaws. If so, it may be worth it to trash the instrument and replace them.
1. Assure the problem is not with the standard or the calibrator.
2. Try to determine what the problem is with the instrument. Most dimensional instruments (Mitutoyo, Starrett, etc.) don't usually get off, if they have demonstrated repeatability. But it does happens.
Just write up the issue, assure that no significant impact has occurred, replace the instrument, and move on.
Thanks to BradM for your informative Post and/or Attachment!
  Post Number #5
AndyN's Avatar
AndyN
Thumbs up Re: In-house calibration
I agree with Jim!
When you say it's off by an amount, it's useful/necessary to know where it's off also. Is it only at zero? Or does a (similar) error occur along the range? Calibration should check for that, not just at zero!
  Post Number #6
Old 3rd October 2009, 04:02 AM
brahmaiah
Re: In-House Calibration - Digital Micrometer found Out of Calibration
You have to send it for recalibration after replacing the battery cell.
And secondly you have to investigate if the defective instrument was used to measure any products.If so required corrective action should be taken without delay.
V.J.Brahmaiah
  Post Number #7
Old 13th October 2009, 08:42 AM
tknchancs
Thanks for the input!
  Post Number #8
Old 16th October 2009, 09:16 PM
brobinson
Apple Re: In-House Calibration - Digital Micrometer found Out of Calibration
Throw away micrometers for parallelism error?
Wow...Must have an unlimited budget or are buying the el cheapos made of poor quailty in ZaZa Land.
There are several factors that could contribte to the gague being off .005" Some possibilities that I would consider:
1) Possibly a burr on the spindle or anvil face.
2) Parallelism of the two faces could be off.
3) The flatness of the anvil or spindle face could be of error.
4) Zero setting is off.
5) Standard is not qualified to nominal dimension.
These checks can be performed by trained technicians as stated earlier. The adjustment of zero can easily be done. If parallelism is bad, the gauge should be sent out to a reputable calibration house to have the faces lapped parallel and the thimble repositioned to compensate for the change.
Being off .005" is rather significant.
There are just too many variables to consider when there is an error this large. Simple adjustments of a few tenths- to a few thousandths of an inch can be made on the barrel. Over this and the zero line becomes too far out of position to easily read the gauge for future inspections. If an adjustment is .005" is required after all other possibilites are eliminated, I sugges that the thimble be repositions on the spindle and leave the barrel adjustment for the smaller increments.
Thanks to brobinson for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Micrometer Calibration - Seeking actual Calibration Procedure for 0-1" Micrometer dbulak General Measurement Device and Calibration Topics 19 6th April 2012 06:44 AM
Calibration Procedure for ID Micrometer Calibration & Extension Rods kearnj General Measurement Device and Calibration Topics 5 23rd March 2012 04:06 AM
Flow Meter Calibration - Outside Calibration Service vs. In-House Calibration CDISO General Measurement Device and Calibration Topics 3 1st November 2011 08:00 PM
Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question Coleman Donnelly General Measurement Device and Calibration Topics 10 29th November 2007 02:59 PM
Calibration Outsourcing vs. In House Calibration - Outrageous Costs of Calibration Cathy Everett General Measurement Device and Calibration Topics 28 5th September 2006 12:50 AM
The time now is 09:48 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
