18th October 2001, 04:19 PM
Registration Date: Oct 2001
Karma Power: 33 Karma: 15
Reccomended Number of Internal Auditors
I am wondering if any one has ever seen a list/matrix/scribbles on a napkin that reccomends the number of internal auditos a company should have (ie: 1 internal auditor per 15 employees.) It's much easier to push things through around here if I have something in writing.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
-Albert Einstein
18th October 2001, 04:56 PM
Registration Date: Mar 2000
Karma Power: 51 Karma: 114
I waited for over two years to gain semi-official input for the same question...... It seems to be one of those that is of a varying opinion depending on who you talk to..
Marc would "most likley" tell you -- there is no set standard number of "INTERAL" auditors required or even suggested -- And many discussions here at the Cove about the definition of who an Internal auditor can be - we use our outside consultants staff in a pinch.
Our last External auditor however offered "the opinion" that for 185 employees 5 to 6 trained ACTIVE internal auditors would be what she would consider adequate..
If my math is correct that would make - 1 per each 30 or 35 employees. As a general opinion/suggestion.
Regards
Jim
"Chance is a word void of sense; nothing can exist without a cause."
Voltaire
18th October 2001, 07:32 PM
An Early Cover
Registration Date: Aug 2000
Karma Power: 40 Karma: 15
Just for some numbers, we have about 1,000 employees and 2 full-time internal auditors (I finally got back-up), with 16 others trained to help us part-time. The part-time auditors each typically participate in 2-4 audits per year. Keep in mind that we full-timers also spend a lot of time investigating and writing procedures, doing employee training, twisting arms, etc.
Alf
18th October 2001, 09:22 PM
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51 Karma: 84
it's your call
First and foremost, let me say that the audit program/schedule must be implemented, maintained, and kept on schedule. So if you're having trouble holding it together due to resource problems, then clearly you need more auditors. Registrars will look at this - of course.
Second, and of little consequence, the type of indutry, product, etc. plays a big part in determining auditor:employee ratios. I find in service industry environments (and I'm talking auditing as an extra job for people here) a trained auditing pool of about 8-10% is required, with an active force of 5%. Lower than this and you risk losing them through over work - too many audits. So the better question relates to how many auditors do I need to perform 35 x 1 hour audits per year? Auditors need to do at least 2 per year to keep their hand in, and generally no more than 5. Quality dept type people can do extra/more to fill all the audits.
NOTE: it also depends on the number of departments, geographical locations of sites, etc, etc, etc, etc.
Aussie Bloke
19th October 2001, 09:11 AM
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
I have seen a few suggestions and will look in my files to see if I still have the info. The best plan is based on the schedule of audits, "Am I getting them done on time?" If "No", you may need more. We have over 300 under one roof people and have 8 from various departments including floor employees
19th October 2001, 09:50 AM
Courtesy Access
Registration Date: Mar 2001
Thanks Given to Others: 225
Karma Power: 73
Few years ago, our manpower is 160 and we have three internal auditors. And now we almost double the size, were 259 now and now we have 18 healthy internal auditors.
I think there's no specific number of auditors, as long as when that auditors audit, document what they are doing. I think that's fine.
Hope this helps,
Raffy
19th October 2001, 12:17 PM
Registration Date: Jun 2001
Karma Power: 35 Karma: 10
I agree........... our external auditor has never specified a number of auditors per number of employee....
My company has aprox ~90 employees and we have 6 internal auditors. I just made sure that we had at least one person from each department so that all audits can be objective. Also find this helps increase Quality Awareness within each department, as this can be a problem.
21st October 2001, 03:27 AM
Courtesy Access
Karma Power: 73
That was great, having at least one per department with 18 healthy auditors including 4 in QA department. I make sure that plenty in QA, we don't want to happen someone would leave the department without any replacement.
Raffy
