Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Preventive Action and Continuous Improvement
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 22nd October 2001, 06:43 AM
qsmso qsmso is offline
Involved in Discussions
Registration Date: Jan 2001
Karma Power: 38
qsmso has less than 100 Karma points so far.
Let Me Help You Pass Through Rate Ratio Improvement and Defining Pass Through Rate
Dear Cove’s friends,
I conducted the internal quality audit at the final inspection section. They have the quality objective “ 95% pass through ratio”. Their work is only inspecting the product that come from previous process. So, I am confuse that
1. What does it mean for pass through rate? For the current formulation is
Pass through ratio = (total passed product / total inspected product) * 100
2. How can they define their quality objective like that since I have seen none of value added from this process? So, in my imagine, if I would like to achieve the target, fine, just let every pass (OK)
3. The current result is the target is not being achieved, so, I am wondering that what should be the improvement plan for them to achieve the target?
Any comment?
Regards,
QSMSO
Sponsored Links
Old 22nd October 2001, 11:14 AM
E Wall's Avatar
E Wall E Wall is offline
Just Me!
Registration Date: Jun 2001
Thanks Given to Others: 67
Karma Power: 63
E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.
Default Final Inspection Criteria and Records?
QSMSO, What did they respond when you asked those questions during the audit?
Each location will have their own process, but in general I would presume there is some documented Final Product specification or criteria to inspect against. Also, are any records being maintained?
Sponsored Links
Old 22nd October 2001, 12:26 PM
Al Dyer
Unregistered Guest
Posts: n/a
Question
Maybe I am confused with the term pass through ratio as it applies to final inspection. Does it really mean that 5% scrap is allowed to leave or are they inspecting 95% of the product.
Either way way it is at the least counterproductive and at the most means 5% bad parts go to the customer. (50,000 PPM)
Maybe some more clarification??????
Old 22nd October 2001, 02:24 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Default acceptance rate
Hello qsmso,
Are your referening to an acceptance rate...that is 95% of the product is accepted on original inspection? If this is what the goal is, one question I have is why is this a "Quality Objective"? Final inspection didn't produce the parts, so how can they be responsible for an unachievable goal???
Perhaps you could provide us a little more info...
Regards,
CarolX
CarolX
Theater is life, film is art, and television is furniture.
Old 23rd October 2001, 10:49 PM
Karma Power: 38
Default
Thank you for all responses,
I did check with the final inspection area again, they issisted that the formulation to calculate pass through ratio is
Pass Through Ratio = ( Total OK / Total inspected ) x 100
It means they want to monitor previous processes' performance.
95 % pass through rate means only 5 % they allow for NG products from provious process. They inspect and separate those NG prior to deliver to customer.
But what I also do not understand is what kind of method they can apply in order to achieve 95 % pass through rate without any support from previous process, who actually make root causes of NG.
What I comment for them is to make good analysis report about type of defect they detected and souces where those NG coming from, then report to management.
Any comment?
Old 24th October 2001, 11:44 AM
CarolX's Avatar
Karma Power: 176
Default company objective
Sounds more like a company objective than a department objective. The only thing final inspection can do to raise the acceptance rate is to not inspect product and plead ignorance. Begin an analisys of the reject reasons and try to identify trends. Report those finding to the responsible department, get some CA commitment, and then see what happens to your acceptance rate.
Regards,
CarolX
CarolX
Old 24th October 2001, 12:50 PM
goose goose is offline
Registration Date: Apr 2001
Karma Power: 35
goose has less than 100 Karma points so far.
Default Pass Through rate
Follow the grandma's lead.
We had similar situation where "first pass yeild" was 90% aprx. Used a greenbelt team to do historical analysis of the 10%. Segmented and stratified data and learned that vital few contributors to defects were assembly errors, vendor errors and design issues.
Established feedback loops to departments causing defects. Formed "mini" teams to attack repetitive issues.
Project not complete but in 4 months over 60% improvement.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Where can I find pass rate information for ASQ exams? qualitytrec Professional Certifications and Degrees 10 23rd September 2008 07:54 PM
Effectiveness, miss rate and false alarm rate - Need formulas to calculate nurcan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 18th April 2007 02:49 AM
Injection Molding Quality Improvement - 10% Rejection Rate for Nonfills rossbach63 Manufacturing and Related Processes 4 9th September 2006 02:02 PM
Mortgage Rate Data on average 30 year fixed mortgage rate Andy Nutt Coffee Break and Water Cooler Discussions 5 19th May 2006 06:25 PM
Miss rate & False Alarm Rate - What are they and how are they calculated? paulo Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 1st September 2004 03:25 PM
The time now is 01:07 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
