23rd October 2001, 09:08 AM
Registration Date: Apr 2001
Thanks Given to Others: 1
Karma Power: 42 Karma: 172
ISO 9001:2000 vs. QS 9000 Quality (QMS - aka QM) Manual
Has anyone successfully wrote a new Q Manual for a company with a split ISO 9K2K/QS 9000 certification? I've been told by our registrar that we should not try to include QS 9000 in the new manual covering ISO 9K2K, but don't I have to include both in the Q Manual and then reference to our procedures which I have done? He has also told me that I have to answer 4.2.2 (c) in the Q Manual not in a procedure. This is not the way I understood the standard. I have deliberately left the procedures out of the Q Manual because I felt there were too many in the last one which became rather redundant when the procedures covered it too. I appreciate any input you may have.
Strike 1 on new manual!
24th October 2001, 03:17 AM
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Sure have!
I have written a QM for ISO2K and QS9000. I have taken the relevant positionings from the draft of ISO/TS 16949.
As I understand it 4.2.2 c all is needed is a flow chart in the QM.
No need for a procedure at all.
Because of the QS requirements the QM has all the references to the QS demands.
Even for the special QS demands you do not necessarily need a procedure, reference in the QM is enough
I forgot to say that this has not yet been submitted for approval.
You can’t fake quality any more than you can fake a good meal.
* William S. Burroughs
24th October 2001, 01:33 PM
Howard,
Just how have you formatted your flow chart for 4.2.2 (c)? Should I just use a flow chart showing the processes a job would follow thru the facility from estimate until shipped? As far as QS requirements, I have been advised to not add the QS references to my QM for ISO 9K2k.
25th October 2001, 07:45 AM
Forum Administrator
Karma Power: 195
I used a very generic chart from customer requirements thru feasability, development, test production , production , shipping and customer feed back.
The records were indicated as outputs of the stage.
I must translate it and then post it.
I do not understand why you have been advised not to add the QS to the QM, do they want 2 systems?
25th October 2001, 03:11 PM
Howard,
I don't exactly know just what he is thinking. I am waiting on clarification and hope to have that before our surveillance audit Nov. 13. I will post his ideas back here when I get them. Thanks for the discussion on this topic.
18th October 2002, 04:31 PM
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2002
Karma Power: 29 Karma: 10
ISO 9000 / QS 9000 Hybrid System?
I also have a dilemna regarding a new registration. Our customer base is about 1/8 automotive. We are presently not ISO registered. Having registered several previous organizations, the ISO is pretty straightforward. But, is it possible to have a (Registered) system for which I may run a full APQP regimen for some customers.....but also maintain a more typical process regimen for other (non QS) customers? I know....I know......the APQP process could benefit BOTH. But, frankly, a smaller company can't maintain that much administration, particularly when the bulk of customers can't even spell "FMEA"!
Could I include a decision point during the design planning process as to which "road" a project will take....based upon individual customer requirements? The automotive customers will require one regimen.....while (others) would use a parallel protocal? Can I develop an ISO 9000-2000 program and "self declare" QS9000 compliancy to my (smaller) automotive customers? Or, do I spin this all around.....go for the QS registration......but develop the two paths.....
Advice...please!!!!!
23rd October 2002, 04:52 PM
RickG,
You do realize that if you register to QS you will be required to apply it to all your customers. However, you can go for a double certification (mandatory after 12/03) of ISO9K2K & QS9000. This would allow you to do what you have alluded to in your post. We are in the middle of just such a transition. Of course this is assuming that your automotive customers are mandating QS9000. If they are not just go with the ISO9K2K or plan for the future and get a TS16949 certificate.
