Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > FMEA and Control Plans
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th October 2001, 02:28 PM
RLBredeweg RLBredeweg is offline
E-Mails Invalid or Rejected
Registration Date: May 2001
Karma Power: 0
RLBredeweg has less than 100 Karma points so far.
Default Reference Dimensions on Control Plans
Our Steel Coil Control Plans have a characteristic I.D of coil identified in the sequence of measurements the characteristic is just a quick check to make sure the operator doesn't grab the wrong coil and try to put it up on the coil reel which will not accept the coil if it is not the correct size. My question is can the term "For Reference Only" be used on the control plan, is there anything in the QS9000 standard or the APQP Manual that states this term may not be on the control plan???? I'm having real diffuculty with my Auditor about this I believe subjective interpratation.
Sponsored Links
Old 25th October 2001, 05:18 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
I've seen "for internal reference" many times on a control plan. As long as the nomenclature is agreeable and approved by the customer, whether intenal or external. This type of reference is usually carried down to the level III work instructions.
Any other views?
Sponsored Links
Old 26th October 2001, 09:48 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
IMO. you can put anything on the control plan that you deem necessary to control the quality of the product. Refer to the overview on page 33 of the APQP.
Your auditor may have a problem with how you are documenting the results of this inspection. Regardless of what type of characteristic that is listed, variable or attribute, it must be documented as being "checked" before the process can continue.
Sam Goody
Old 29th October 2001, 08:48 AM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default
Just a thought, but why put it in the Control Plan if it is for reference only? Surely the measurement is part of the process set-up verification and not a dimensional requirement of the product.
IMHO I wouldn't think you should use the term "Reference Only" on a control plan as the purpose of the CP is to address the process/product characteristics which need to be controlled. Leave the non-required "checks and balances" to the work instructions.
Dave
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
1st Article Part - Recording All Dimensions vs. Critical Dimensions - AS9100B pwabbit AS9100 Aerospace Standard and Requirements 24 19th May 2009 05:20 AM
Control Plans and Inspection Plans for panel board industries naran FMEA and Control Plans 5 1st March 2009 11:46 AM
Control Plans - Intending to transfer our control plans to electronic format Paul Homer Documentation Control Systems, Procedures, Forms and Templates 7 20th September 2000 04:56 AM
How does one handle dimensions on a control plan that are purely functional? ChrisB FMEA and Control Plans 2 31st May 2000 01:22 AM
Control Plans - A few control plans that are generic enough to represent the facility Steven Sulkin FMEA and Control Plans 1 18th August 1998 01:15 AM
The time now is 03:45 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
