Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
27th October 2009, 05:42 AM
CAQ System Development
Registration Date: Jan 2007
Thanks Given to Others: 50
Karma Power: 30 Karma: 20
General Term for Inspection Process of Sample Parts that everyone can understand
I am looking for a general term for the inspection process of sample parts. It needs to be understood by people of all kinds of industries.
This is the process (roughly):
- Take samples from first (serial) production
- Test dimensions, performance, material, etc.
- Send report stating parts comply with requirements in drawing.
- Automotive industry says PPAP
- Aerospace uses FAI
- ? uses Initial Sample Inspection Report
But what is a general term for all industries?
Regards,
Kira
27th October 2009, 06:07 AM
Courtesy Access
Registration Date: Mar 2007
Thanks Given to Others: 374
Karma Power: 121
Re: General Term for Inspection of Sample Parts
'First Article Inspection' is popularly being used by most. In auto sector too my customers run FAI prior to the PPAP.
As you have stated about taking samples, from the first (serial) production, the PPAP lot may not contain any of these.
Let others chime in to contribute as per their experience.
Umang
Quality has to be caused, not controlled.-Philip Crosby
Success comes in cans, failure in can'ts
Thanks to Umang Vidyarthi for your informative Post and/or Attachment!
27th October 2009, 06:59 AM
What are the requirements in general for a FAI (First Article Inspection) - are there standards apart from PPAP and aerospace?
Regards,
Kira
Reason: Added "First Article Inspection."
27th October 2009, 07:34 AM
Courtesy Access
Karma Power: 121
In Reply to Parent Post by Kira_n
Regards,
Kira
A "First Article Inspection Report" is a requirement placed on the 'supplier' by the 'customer'. The report documents, and certifies that each first article unit, delivered to the buyer, was produced and inspected in accordance with the buyer’s specifications. The report includes all physical, material, and chemical test data associated with the part. [These reports are provided to the buyer and a copy retained by the supplier, for a minimum specified period as required by the buyer.]
The customer also conducts his own FAI on the supplied parts, which includes 'destructive test' as well, wherever need be.
Hope this helps
Umang
8th December 2009, 09:41 PM
Registration Date: Dec 2009
Karma Power: 15 Karma: 10
I would use first article inspection.
10th June 2010, 11:32 AM
Involved in Discussions
Registration Date: Nov 2009
Thanks Given to Others: 21
Karma Power: 17 Karma: 10
Do you Submit FA Report for each shipment or for the total of parts that were produced without changing anything in the process?
21st June 2010, 02:42 AM
Courtesy Access
Karma Power: 121
In Reply to Parent Post by new_to_this
As the name suggests, the 'First Article Inspection' is conducted only the first time a componenet is supplied. The number of components required for FAI is determined by the customer.
Umang
21st June 2010, 02:57 AM
Courtesy Access
Karma Power: 121
In Reply to Parent Post by Wendy McLaughlin
Hello Wendy McLaughlin,  Welcome to the Cove
This is a customer specific requirement, the quantity is determined by the customer, since the components are required to pass through rigorous & gruelling tests and inspection.
You may adopt FAI for in-house inspection too, to surface even a minor non conformity of the product.
Umang
Forum Posting Settings
