Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 29th October 2001, 09:23 PM
Gary Calahan Gary Calahan is offline
Registration Date: Oct 2001
Karma Power: 33
Gary Calahan has less than 100 Karma points so far.
Listen To Me! Customer Corrective Actions - Replying with 'No corrective action needed'
Has anyone ever addressed a customer corrective action with no corrective action needed? Is this acceptable. I work for a distributor and our customer is rejecting one lot of parts because one nut failed torque test requirements. Lot size is 650 pcs. and they tested two nuts with one failing. Mfg. inspection reports shows 10 pcs. tested passed requirements. This is a large OEM so I do not want to **** them off but finding root cause of one nut non-conformance is difficult if not impossible.
Sponsored Links
Old 29th October 2001, 09:57 PM
energy
Unregistered Guest
Posts: n/a
Default Do you make them?
Gary,
Are you the manufacturer? If you are a distributor, you may have to ask the manufacturer to increase his sampling plan. A torque failure is a serious problem. You have evidence of 0 in 10. The Customer has evidence of 1 failure in 2. Did your Customer do them all? Tell your customer that the manufacturer has agreed to increase the amount of torque tests per lot. But, make sure that they do it. Or, look for another Supplier. It may be a swaging, brazing or clinching process defect. If your Customer has signed off on your Quality Plan, you may suggest that the product met current requirements, but you will increase the testing by (50%?) to ensure that there are no failures. Personally, I would insist a few lots at 100% to convince myself that it was a rare occurrence. It's a problem that requires Corrective Action. Your statement that it is not, falls on these deaf ears!
Sponsored Links
Old 29th October 2001, 10:20 PM
Karma Power: 33
Default
Energy, The customer did not test them all. The Mfg. tested 10 pcs. as did I as soon as I was informed of the reported condition with the same lot of parts pulled from stock. Could not duplicate condition. Since 1998 we have purchased 70,000 pcs. comprised of 19 different lots with no reported failures. I do not see a trend here and would like to call it a isolated incident. The one nut failed on the seventh removal cycle.
Old 30th October 2001, 09:10 AM
energy
Unregistered Guest
Posts: n/a
Default What I would try
Gary,
Then you explain just like you did here. I copied this reply from a post here several months ago, for potential use by me if this sort of condition arose. See if you can use it:
"Current review of the system is sufficient to catch the vast majority of errors. The rest of the Quality System has been audited and found to conform to requirements of ???? Further preventive actions to eliminate the cause of potential future occurrences(Check spelling) would not be commensurate with the minimal risk involved."
All this after you explain the history of failures as you did in your post. Give it a shot and good luck!
Old 30th October 2001, 10:48 AM
SteelMaiden's Avatar
SteelMaiden SteelMaiden is offline
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.SteelMaiden is appreciated, and has over 1700 Karma points.
Default
I have used the "in all of our data..." approach a couple of times. If it is truely a 1 in a million case so to speak, there isn't a lot of justification to spending tons of money to fix a problem that isn't there. One thing you need to be aware of, if this is the route you go, you have to sell this theory to your customer. They aren't going to just take it lying down in most cases. They want to see you do something that makes them feel warm and fuzzy.
Overall, back to the original question, yes there can be customer issues that do not require corrective actions. Not real often. There is usually something you can do to either make you or them more confident of the process. But I can remember a couple of stand-out issues from the past. One, the customer picks up their material, drive off down the road, falls asleep and wrecks their vehicle then turns in a claim that our product surface is bad, dinged up, bent, scratched, or whatever. Ya think? Lucky for us, we had instituted a new preventive action program by taking a polaroid (upgraded to digital) of each truckload before it left the shipping bay.
Old 30th October 2001, 11:06 AM
energy
Unregistered Guest
Posts: n/a
Default We do too!
SteelMaiden,
We also photo everything we ship to preclude Customers and Freight Companies from saying that "This is how we received it". It has saved us from additonal expenses that were not our problem. Here's another example of a Customer Corrective Action Request that was enjoyable. During an audit at our facility, the auditor issued a non conformance because we didn't have the latest revision of a particular packaging procedure. To begin with, they never sent it to us. Second, we never received an order with this procedure specified. When we responded, he just sent us the latest spec and never retracted the N/C. It remains in their "Historical" data.
Same Customer. Late shipments because "their" designated carrier never picked up the shipment that was ready. Our complaints go unanswered and we get their monthly Supplier Status Report with the late shipments affecting our rating. But, guess what? They keep on purchasing and remain one of our largest Customers. Sometimes, lower echelon people just like to thump their chests and try to intimidate you. If these problems, Customer generated, caused us to lose their business, you can bet our CEO would take "our" history to their top person and it would get rectified. Possibly resulting in some "counselling" for the real responsible people. You never rule out what may happen when the "Big Suits" get together.
O.K., this was longer than I intended, but my passion for resisiting the "bully" type customer gets me cranky. Later "Maiden"
Old 31st October 2001, 10:39 AM
Karma Power: 255
Default Re: We do too!
Originally posted by energy
SteelMaiden,
... When we responded, he just sent us the latest spec and never retracted the N/C. It remains in their "Historical" data.
Around here we refer to that as "The Hysterical Data File" All the stuff that people think they can get away with.
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
Old 31st October 2001, 03:17 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Gary,
Are we digging too deep here? There had to be a reason for the nonconformance.
Are you within the PPM requirements for the customer?
Was a new person running the line?
Have you looked at maintenance and set-up records?
What does your FMEA define?
Are increased audit rates applicable until the root cause is determined?
I guess I am getting to the point of let's get real. Something malfunctioned in your system. It may be training, it may be execution of instruction, it might be a lazy employee.
Whatever the scenario there is a glitch somewhere in the process. I surely can't see or say what it is or whether the person that wrote the C/A was just having a slow day.
What type of traceability do you have?
You could not reproduce the incident, did you request the defective part from the customer so you could perform your own test on the subject part?
Have you visited the customer to determine if the operator had the air ratchet backwards and was afraid to open him/herself to superior review?
There are just so many variables that it is a very hard question to answer.
Please believe me that this is not a dressing down, just an opinion of an old *art.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Records of the Results of Action Taken (8.5.2e) - Software Corrective Actions John Mann ISO 9001 - Quality Management Systems Standard 11 21st August 2009 11:35 PM
How to Monitor Corrective Actions - Statistically Monitoring Corrective Action lrl116 Nonconformance and Corrective Action 34 28th October 2006 09:01 AM
Is a Corrective Action needed? Objective is Complete Customer Satisfaction Pudge Nonconformance and Corrective Action 25 22nd October 2004 11:56 AM
Supplier Corrective Actions - EFFECTIVE corrective actions on CAR's Al Cohen Supplier Quality Assurance and other Supplier Issues 7 17th August 2002 07:12 PM
Corrective Action - Superficial/No Internal Corrective Actions at all - Fineblanking Steve Truchon QS-9000 - American Automotive Manufacturers Standard 16 3rd August 2000 03:42 AM
The time now is 11:11 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
