The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Search the Elsmar Cove
Custom Search
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 30th November 2009, 08:19 AM
Patrick Johnson Patrick Johnson is offline
Registration Date: Nov 2009
Karma Power: 18
Patrick Johnson has less than 100 Karma points so far.
Question Tape Measures (again) Gage R&R
I have read a number of the posts on tape measures, but this is a slightly different twist. The plant where I'm at has long used tape measures ("we've always done it that way"). The problem is that most tape measures resolution is only at 1/32" or 1/16" and the tolerance ranges on what we are measuring are typically anywhere from +/- 0.016" to +/- 0.047"!! I have done several gage studies using various operators and not one has passed to date. They all fail based on the ndc, % study variation, % contribution and of course P/T ratio!!
Am I missing the boat or is this a pointless activity to measure with a tape measure? I have discussed this with my manager but the direction I got was to get a certified tape measure. I was then told to check this certified tape to other tapes to verify their accuracy. After that I was told to have the various operators check the same piece 10 times to make certain that they could accurately measure a piece with it.
This seems pointless. I still strongly believe that even though people "build houses with tapes" that they are not up to the task at hand.
Please advise if I am missing something from the outsiders point of view.
Thanks to Patrick Johnson for your informative Post and/or Attachment!
Sponsored Links
Old 30th November 2009, 09:02 AM
David DeLong's Avatar
David DeLong David DeLong is offline
Appreciated Information Resource
Registration Date: Aug 2007
Thanks Given to Others: 35
Karma Power: 76
David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.David DeLong is appreciated, and has over 1700 Karma points.
Re: Tape Measures (again) Gage R&R
Patrick:
It is so obvious that your tape measured are not used in the appropriate application. You can visually see down to 1/16 " or .060 thou yet you are trying to measure down to an tolerance of .047. It just doesn't make sense.
One always needs to look at the 10% rule. If you part tolerance is +/- .050", your gauge should have a increment to at least .005".
Your R & R values that you have already calculated show that this type of gauge is not appropriate for the application and all the King's horses will not make it better.
You now have the toughest job of any person in the Quality field - trying to convince your Supervisor that your company should look for alternative methods of measuring.
Good Luck!
Dave DeLong
Sponsored Links
Old 30th November 2009, 09:45 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,985
Karma Power: 1509
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by Patrick Johnson View Post
Other than GR&R, what are you seeing that makes you think that the tape measures aren't working? Is it possible that the tolerances are too tight? If there's no history of rejection that can be ascribed to measurement error and tape measures have been in use for a long time, what's to be gained by spending money at this point?
It is difficult to get a man to understand something, when his salary depends upon his not understanding it. --Upton Sinclair
Thanks to Jim Wynne for your informative Post and/or Attachment!
Old 30th November 2009, 10:25 AM
hogheavenfarm's Avatar
hogheavenfarm hogheavenfarm is offline
Involved in Discussions
Registration Date: Feb 2007
Thanks Given to Others: 127
Karma Power: 64
hogheavenfarm is appreciated, and has over 500 Karma points.hogheavenfarm is appreciated, and has over 500 Karma points.hogheavenfarm is appreciated, and has over 500 Karma points.hogheavenfarm is appreciated, and has over 500 Karma points.hogheavenfarm is appreciated, and has over 500 Karma points.hogheavenfarm is appreciated, and has over 500 Karma points.
I have to agree with Jim - why the GR&R exercise if there are no problems directly related to measurement? I worked in a modular home plant in a past life, and we used various kinds of tapes, all with the same problems. What I suggested (but never implemented), was a measuring range, calibrated by a surveyors steel tape (NIST) certified and checking tape measures against that. Anything found out more than 1/16" was to be tagged and removed from service. This was never done because most cheap tapes would fail, and the company supplied the tapes.
Old 30th November 2009, 12:07 PM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 1,178
Karma Power: 363
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
I too am with Jim on this one. Do you really need such (relatively) tight tolerances? If you could give us some indication of what you are measuring and what current known field/performance problems you are experiencing we may be able to help more.
Statistics without physics is gambling; Physics without statistics is psychics
Old 1st December 2009, 11:02 AM
Richard Pike's Avatar
Richard Pike Richard Pike is offline
Thanks Given to Others: 98
Karma Power: 55
Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.Richard Pike is appreciated, and has over 700 Karma points.
Send a message via Skype™ to Richard Pike
Using a tape measure on such tolerances indicates that you are not concerned (or turn a blind eye) to products that are indicated as "out of tolerance". If this is the case, and you are receiving no comebacks from the customer, then of course the product is over specified. If you "are" rejecting product that the tape measure indicates is "out of spec" then you are undoubtedly throwing money away.
Old 7th December 2009, 11:10 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Karma Power: 291
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Welcome to posting in the Cove!
Given the measurement you need to make, I must ask what is the overall length you measure? If it is say 50', then the tolenece you need is frankly impossible to achieve with a tape. If you are working under 12", get digital calipers and have them calibrated by an accredited lab, then teach folks how to use them proprly to get good results.
Even a precise steel ruler cannot give those tolerences, due to the uncertainty.
Old 18th December 2009, 09:48 AM
Karma Power: 18
Thanks to everyone for your feedback and I believe you all brought up some interesting points.
The parts are steel doors and frames of varying sizes. The main issue is trying to hold tolerances in thousandths of an inch on something that may be over several feet large.
Until we can get the tolerances right we will continue to run in circles. If the tolerances truly need to be this tight then we will have to accept the fact of the 10:1 rule and acquire a more appropriate gaging method. Since the dimensions in question rarely present an issue from the customer I believe our time is best spent on the prints first and the measurements later.
I appreciate the advise and observations.
Thanks again!!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Exempt from Calibrating our Tape Measures and Micrometers poprock7 ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 32 21st July 2011 03:11 PM
Need Tape Spec for MSCH 62 Full Tape Wrap & MSDC 13-B Spot Tape pancho-2007 Various Other Specifications, Standards, and related Requirements 3 14th September 2004 11:26 AM
Tape Measures & Scales - Part Tolerance - Gage R&R Linda Miller Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24 7th January 2004 11:03 AM
Verbage to cover tape measures JRKH ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 6 1st December 2003 02:24 PM
Calibration of Tape Measures used for reference RLBredeweg ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 13 28th October 2001 08:38 PM
The time now is 03:53 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
