Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
30th November 2009, 08:46 AM
Involved in Discussions
Registration Date: Aug 2000
Thanks Given to Others: 217
Karma Power: 80 Karma: 95
ASTM E-18 Annex A3 - Ball and Diamond Indenters Requirements
For those of us who use rockwell testers, how are you handling the requirement that all ball and diamond indenters must now meet Annex A3 requirements? Have you bought new indenters? Any thoughts would be appreciated. Thanks in advance.
A wise person kisses, but does not love, listens but does not believe, and leaves before they are left.
30th November 2009, 09:41 AM
UK Quality Consultant
Registration Date: Jan 2009
Thanks Given to Others: 69
Karma Power: 41
Re: ASTM E-18 Annex A3 - Ball and Diamond Indenters Requirements
We switched to HB
30th November 2009, 09:46 AM
I don't get it. What is HB?
30th November 2009, 09:47 AM
Karma Power: 41
We switch to Brinell - Made my life easier as we could use a hand held machine to test Hardness Brinell (HB) instead of trying to use the HRE scale.
Thanks to Phiobi for your informative Post and/or Attachment!
30th November 2009, 09:51 AM
I see that it was a good decision for you. However, we still need to use the "T" and "N" scale as well as "C" scales.
13th May 2010, 12:16 PM
I will re-ask the question and hope some one can help answer my original question. The new ASTM E-18-08b now calls for all diamond and ball indenters to have a serial number indicating that they were made according to the new standard specifications. Wlison (Instron) says that you can still use old indenter if they are verified and recertified. Is this what other people are doing or have done? Any comments would be appreciated.
13th May 2010, 03:24 PM
Lab Manager
Registration Date: Jun 2004
Thanks Given to Others: 19
Karma Power: 87
Hello, dbulak wrt your question, we're currently ignoring the requirement. Our internal lab isn't certfied to ISO 17025 and currently no one reviews ASTM standard test methods on an annual basis to check for changes. This wouldn't have flown at my prior employer, AKSteel, but is acceptable here.
Heck, we don't even do the 3 indentations to check RBW on a daily basis - 1 is "good enough", 3 would use up blocks too quickly.
Having seen your post, and done a quick check of ASTM E18 and of our current indenters, what we should do is replace all of them with correctly certified ones - it's what I would have done at AK, of course I also checked our relevant ASTM standards annually for changes.
Being prompted by your quote, I'll probably check with technical management to see if they want to comply with the updated requirement.
" We have met the enemy and he is us." Pogo
Thanks to Kevin H for your informative Post and/or Attachment!
15th June 2010, 01:03 PM
I was told that in order to have rockwell testers calibrated to ASTM E18-08b, the indenters aalso have be certified. Has anyone come across the same situation?
Forum Posting Settings
