The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Forum Username
Wooden Line
AMS2771 - Soak Time Interpretation (Thermal Conditioning) - T6 or T61?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Reply
  Post Number #1
Old 30th November 2009, 05:00 PM
sorin's Avatar
sorin
Please Help! AMS2771 - Soak Time Interpretation (Thermal Conditioning) - T6 or T61?
AMS 2771 page 11 (and 12) Table 2
Soak times are mentioned either as a single value (and in this case it says minimum) or as a range.
Also, the note 13 says that "Soak times are recommendations, other times may be required depending upon casting configuration and property requirements"
Example:
For A356.0 we have
T6 - 310 deg F - Soak time 3-6 hours
T61 - 310 deg F - Soak time 6-10 hours
If a customer requires T6 condition but in order to obtain the mechanical properties I have to maintain (soak time) for 7 hours, do I certify that as a T6 or T61?
Thank you in advance for help
Sponsored Links
  Post Number #2
Old 1st December 2009, 03:31 AM
anil123's Avatar
anil123
Re: AMS2771 - Soak Time Interpretation (Thermal Conditioning) - T6 or T61?
In this case it is better to discuss the matter with customer and finalaze the manufacturing process plan and get the approval from customer. You should not assume anything, get the confirmation by convencing customer regarding the issue.
Thanks to anil123 for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 1st December 2009, 03:50 AM
Phiobi's Avatar
Phiobi
In Reply to Parent Post by sorin View Post
Example:
For A356.0 we have
Thats a good question and one faced by me all the time. The way I have been looking at it is that we provide a mechanical result which confirms the heat treated condition, therefore if the required heat treatment (to hit the customers required mechanical properties) does not match the spec, I tell them. We then agree to state the base alloy and have the required mechanical properties entered into the contract instead of the heat treated condition.
Thanks to Phiobi for your informative Post and/or Attachment!
  Post Number #4
Old 1st December 2009, 05:57 AM
anil123's Avatar
anil123
Actually when we heat any material due to temeprature and soaking time we get some properties which is also depends on material under consideration.
Hence as a metallurgist, we have to convince the customer with basic principles of metallurgist. definately he will agree.
  Post Number #5
Old 1st December 2009, 02:58 PM
Caster's Avatar
Caster
For A356.0 we have
I did some research into the source of these heat treat time and temperature tables, and it seems they were developed by ALCOA around the WWII time frame. ALCOA has since disowned these tables.
Since that time the rise of lawyers/liability has led to a situation where these original tables are copied but no one dares publish new values in case a component fails and their company is dragged into the lawsuit.
So the times/temperatures listed are very dated and do not take into account metallurgical advancements like modification, chill casting, higher temperature aging and so on.
I think you are right to heat treat to the required properties, and worry less about what it is called.
Do you cut test bars from test castings or are results from separately cast test bars? That is another whole can of worms.
Thanks to Caster for your informative Post and/or Attachment!
  Post Number #6
Old 1st December 2009, 03:02 PM
Phiobi's Avatar
Phiobi
We do both. We use integrally cast bars for routine tests but we also perform cut up analysis. If customers allow then we will append to a casting so that we do not need to destroy a whole casting.
One of our customers calls for 1 cut up for each heat treatment load, we can only HT 6 parts in any 1 load! Very expensive. A pain if we need to resolution!!!
  Post Number #7
Old 2nd December 2009, 02:48 AM
anil123's Avatar
anil123
The normal and pricipally ok practice is to load a HT charge along with cut sample. Then cut sample is tested for metallurgical properties which are the indicative result for that HT charge. This practice is used for each Heat
  Post Number #8
Old 6th December 2009, 08:45 AM
sorin's Avatar
sorin
Thank you all for advice....it was more or less what I had/have in mind...I think I just wanted to see if I am on the right path...Thank you again...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Heat Treatment - Soaking time interpretation sorin Manufacturing and Related Processes 5 16th June 2016 04:38 PM
AMS2770 Aluminum Heat Treat - Determining Soak Time Mtvated Various Other Specifications, Standards, and related Requirements 1 6th January 2014 03:22 AM
AECQ 200 Revision D vs. Revision C - Thermal Shock & Thermal Cycling OscarG Other ISO and International Standards and European Regulations 2 6th July 2012 07:14 AM
Humidity Pre-Conditioning IEC 60601-1 (2005) EEmags IEC 60601 - Medical Electrical Equipment Safety Standards Series 9 23rd April 2012 03:11 PM
Pre-Conditioning Leakage Current john95 IEC 60601 - Medical Electrical Equipment Safety Standards Series 12 26th March 2011 09:57 PM
The time now is 10:22 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
