The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
document control, procedures (general)
Reply
Old 1st December 2009, 04:11 AM
Sweetsue28uk Sweetsue28uk is offline
Involved in Discussions
Registration Date: Jun 2009
Thanks Given to Others: 10
Karma Power: 18
Sweetsue28uk has less than 100 Karma points so far.
Thank You! Document Control Procedure Please Review
Hi all
I am currently writing up the necessary procedures for our QMS. I have left the document control until I had a good structure in place and have tried to document it as is as well as ensuring that it meets all the requirements of the clause. Could you please have a read of it and let me know your comments? This is the first procedure I have ever written so any helpful comments would be most appreciated.
Sue
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Sponsored Links
Old 1st December 2009, 04:47 AM
qusys qusys is offline
Appreciated Information Resource
Registration Date: Mar 2008
Thanks Given to Others: 216
Karma Power: 232
qusys is appreciated, and has over 1700 Karma points.
qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.qusys is appreciated, and has over 1700 Karma points.
Re: Document Control Procedure Please Review
Hi Sue,
this is my thoughts about the procedure.
Probably Purpose and Scope should be better defined.
The documented procedure shall respond to 4.2.3 of the ISO standard . If you are going to certificate ISO TS, you shall consider other clauses as well.
The purpose could be to identify actions and responsibilities for ensuring the control of all quality documents related to your QMS.
The scope could be that the procedure applies to all process of your QMS and encompasses all internal and external documents used to manage, perform or verify work . This is only a suggestion : it could be better phrased, I am speaking from general point of view.
I think it is not clear the process of review and update as necessary and re-approve documents. You should also define a time frame when to review documents, even though they are not changed during this time, in order to set a process to re-validate them.
It is not mentioned how you ensure that the changes are identified in the documents.
As to the external documents, it could be useful to better explain how the process is to control their distribution.
These are my first feedback after a first glance review of the documents procedure.
However my suggestion could be to design the process ( Control of Documents) and not seeing it as a functional but in a cross-way all over the organization. To better address this phase of process design, you should be first define who the process owner is.
Hope this helps.
Sponsored Links
Old 1st December 2009, 05:58 AM
brahmaiah - 2010 brahmaiah - 2010 is offline
Registration Date: Mar 2009
Thanks Given to Others: 12
Karma Power: 66
brahmaiah - 2010 is appreciated, and has over 500 Karma points.brahmaiah - 2010 is appreciated, and has over 500 Karma points.brahmaiah - 2010 is appreciated, and has over 500 Karma points.brahmaiah - 2010 is appreciated, and has over 500 Karma points.brahmaiah - 2010 is appreciated, and has over 500 Karma points.brahmaiah - 2010 is appreciated, and has over 500 Karma points.
In Reply to Parent Post by Sweetsue28uk View Post
Hi all
Sue
Your format is not standard.The standard format is :
Ist row:Company name,Title of Procedure,Doct.No:,Rev.no:
1. Purpose:
2. Scope:
3. Reference: QMS Clause No. Etc.
4.Responsibility: Optional
5.Procedure: Step by step
6.Records: Optional
See attachment for an example
There is also an ISO Stanadard which guides on procrdure format.
V.J.Brahmaiah
VJBrahmaiah
Thanks to brahmaiah - 2010 for your informative Post and/or Attachment!
Old 1st December 2009, 06:10 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,944
Karma Power: 1429
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
There is no "standard format" for writing procedures. An organization can decide how to document its procedures. I have seen flow charts, traditional procedures (as you described them), process maps, Wiki-based documents; whatever works for the organization.
(BTW, what ISO Standard are you referring to?)
This document is helpful.
Stijloor.
Thank You to Stijloor for your informative Post and/or Attachment!
Old 1st December 2009, 06:41 AM
ScottK's Avatar
ScottK ScottK is offline
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 170
Karma Power: 284
ScottK is appreciated, and has over 1700 Karma points.
ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by brahmaiah View Post
1. Purpose:
2. Scope:
3. Reference:QMS Clause No. Etc.)
4.Responsibility:Optional)
5.Procedure: (Step by step)
6.Records:Optional))
V.J.Brahmaiah
Thank you for your example and it is certainly suitable but I must agree with Stijloor that for ISO9001 there is no "standard" format.
The organization will use what best suits their operations as long as it meets the minimal requirements of the standard - which are more concerned with the control of the document than the format.
I'm unaware of a standard that defines contents of a procedure for an ISO9001 system. Can you specify what standard? Perhaps you are confusing standards and guidances.
Question for the Original Poster - is this a general home brew QMS or are you going for registration to a standard?
Time for a new sig line.
My LinkedIn Profile
Old 1st December 2009, 06:46 AM
Stijloor's Avatar
Karma Power: 1429
In Reply to Parent Post by ScottK View Post
<snip>I'm unaware of a standard that defines contents of a procedure for an ISO9001 system. Can you specify what standard? Perhaps you are confusing standards and guidances.
Yes, a possible reference could be made to these guidelines which are NOT requirements.
From ISO/TR 10013:2001....
4.5 Documented procedures
4.5.1 Structure and format
The structure and format of the documented procedures (hard copy or electronic media) should be defined by the organization in the following ways: text, flow charts, tables, a combination of the above, or any other suitable method in accordance with the needs of the organization. The documented procedures should contain the necessary information (see 4.5.2) and should contain a unique identification. Documented procedures may make reference to work instructions that define how an activity is performed. Documented procedures generally describe activities that cross different functions, while work instructions generally apply to tasks within one function.
Stijloor.
Last edited by Stijloor; 1st December 2009 at 06:56 AM. Reason: Added paragraph from ISO/TR 10013:2001
Old 1st December 2009, 06:58 AM
Karma Power: 66
In Reply to Parent Post by Stijloor View Post
Stijloor.
There is an ISO Guideline in the same lines as I have described.I WILL TRY TO GIVE YOU THE NO AFTER REFRRING TO MY LIBRARY.
V.J.Brahmaiah
VJBrahmaiah
Karma Power: 18
Hi
Thanks for all your replies. I am attempting to get us registered to ISO9001:2008. In summary up to now I need to clarify the scope and purpose on my document; I need to clarify the process of review, update and reapprove and define a timeframe when to review documents. The changes on each document were going to be identified on the Change Request Form - is this not sufficient - do I actually have to mark them up on the old document as well?
As for external documents, they are accessible by all staff as they are work instructions, therefore there is no control around the distribution they are uncontrolled when printed - is this sufficient?
Sue
Thanks to Sweetsue28uk for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Please review and critique our new Document Control Procedure wooden nickle ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems 4 20th October 2011 08:21 AM
Document Control Procedure - Review and Feedback Needed JaimeB Documentation Control Systems, Procedures, Forms and Templates 9 2nd August 2011 01:19 PM
Sample of Control of Document Procedure and Control of External Documents Lorenzo36 Documentation Control Systems, Procedures, Forms and Templates 2 21st March 2008 09:22 PM
Changes to document control procedure - need review TErickson Documentation Control Systems, Procedures, Forms and Templates 4 6th September 2007 09:52 AM
Edit rights in document control / document review METerry Documentation Control Systems, Procedures, Forms and Templates 11 8th January 2007 12:35 AM
The time now is 11:05 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
