Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st November 2001, 02:32 PM
Ace's Avatar
Ace Ace is offline
Registered Visitor
Registration Date: Oct 2001
Thanks Given to Others: 1
Karma Power: 33
Ace has less than 100 Karma points so far.
Cool Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action
I need some advice petaining to the ISO 9001:1994 Corrective Preventive Action clause.
First - some background information.
We recently endured our registration surveillance audit and had a non-conformance identified with our customer concern process.
Although our database files identified root cause, CA, & PA, the auditor stated we had a non-conformance because our notes were not detailed enough. For example - we had a pc board returned by a customer and after our analysis found it had a hard failure.
The database was documented to show root cause as: Hard Failure
Corrective Action: Replace PC board
Preventive Action: Go thru inventory, retest, and purge per established documentation.
My questions are:
1. Is there an ISO requirement that mandates how detailed our documentation should be?
2. Would I be justified in challenging this non-conformance issued by the auditor?
Thanks in advance for any advice provided.
Redolpho (ACE)
Sponsored Links
Old 21st November 2001, 02:40 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
Default
I would be looking for the documentation to show what caused the hard failure. The information you gave would be all corrective to me - and really all 1st step of corrective which basically establishes the scope of the problem. Corrective action should address why it was a hard failure. Preventive gets alot of discussion in other threads, but I always look at if there was something else to be learned from the failure that hasn't happened yet - possibly on another product line. Or maybe you determine there were 4 potential root causes. If you implement changes to address all 4, then 3 are "preventive" because they haven't happend yet.
In answer to your direct question:
1 - No
2 - No
Sponsored Links
Old 21st November 2001, 03:38 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
I believe that the nonconformance as issued as "not detailed" enough could be challanged.
What I would not agree with is the content of the answers for correcive and preventive action.
Maybe if you posted the root cause to the cove we might be better able to help.
Old 21st November 2001, 07:32 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Default look out!
1. You haven't stated the dispositioning of the failed board.
2. checking your inventory goes a VERY small way in terms of preventive action. PREVENT - prevent it happening again, reduce the likelihood of it happening again, decide that this is an acceptable failure rate as it is technologically and financially not feasible to improve.
3. At the moment you're looking for a lazy (non-quality) exit - are you a manaufacturing manager?
PS - Who cares if it's ISO if it makes good sense!
Aussie Bloke
Old 22nd November 2001, 06:19 PM
Ace's Avatar
Ace Ace is offline
Registered Visitor
Karma Power: 33
Exclamation
Dave,
Apparently you missed the bottom line to my inquiry. I wasn't writing in to get lectured on ISO's terms and definitions.
Simply stated, we complied with our documentation in stating root cause, CA & PA on our database records. I was inquiring if there was any ISO requirement dictating how specific we had to be with the amount of details we record on our records.
My job title has no bearing on the question at hand and I certainly didn't appreciate your personal remarks. If you can't keep it professional, why bother responding.
Go have yourself a great day!!!!!
Rodolfo
Old 22nd November 2001, 07:26 PM
Aussie Bloke
Karma Power: 51
Default Landin' On Both Feet - In Mouth
You said:
"My questions are:
2. Would I be justified in challenging this non-conformance issued by the auditor? "
1. You have to have enough detail to demonstrate compliance, which apparently you didn't.
2. I'm guessing you lost the argument with the auditor, you can run the argument through the registrar and higher, but this is really a last resort scenario. I'd suggest you just fix it.
You said:
"Simply stated, we complied with our documentation in stating root cause, CA & PA on our database records. "
and,
"the auditor stated we had a non-conformance because our notes were not detailed enough"
I think these are contradictory statements. If you complied, you wouldn't have got pinged.
I think my previous advice was very sound.
Sorry about the wise crack - Experience indicates these things to be generally true.
Aussie Bloke
Old 26th November 2001, 01:47 AM
Ace's Avatar
Ace Ace is offline
Registered Visitor
Karma Power: 33
Default Re: ISO Clause 4.14
Thanks for the advice David, and I apologize for my defensive posture.
Rodolfo
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
High Level CAPA (Corrective Action Preventive Action) SOP Example Needed brecksnowshoer Nonconformance and Corrective Action 6 31st October 2009 10:45 PM
Complaints & CAPA's (Corrective Action Preventive Action) for Clinical Trials PPcricket ISO 13485 - Medical Devices - Quality Management Systems 4 10th August 2009 09:35 AM
Tracking Corrective Action - Preventive Action - Simple Product/Documentation Change craig-c Nonconformance and Corrective Action 1 27th November 2006 05:35 PM
CAR/PAR (Corrective Action / Preventive Action) process flow - Seeking example Bpoole Nonconformance and Corrective Action 7 31st October 2006 05:23 AM
CAPA (corrective action preventive action) Effectiveness - Medical Device Industry jampot Nonconformance and Corrective Action 3 26th February 2006 04:22 PM
The time now is 12:49 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
