Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > General ISO 17025 Topics - Calibration, Measurement Gages and Test Laboratories
Thread Tags
Tag Cloud
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Tags
calibration
Reply
Old 6th February 2010, 03:05 PM
R. Webb R. Webb is offline
Involved in Discussions
Registration Date: Jul 2009
Thanks Given to Others: 7
Karma Power: 5
R. Webb has less than 100 Karma points so far.
Please Help! Flat Panel Laser Scanner Calibration
My company recently bought a flat panel laser scanner and I have been trying to make sense out of calibrating it. The problem is that evey time I calibrate it, it is out of spec. by a few thousands. This is with a daily calibration. The vendor says to calibrate until it comes into spec. This is a new machine. I have the manufacturer comming soon to explain this to me but in the mean time I don't trust this very expensive measuring device.
Does anyone have any insight into this? Am I expecting too much from this type of inspection device. It is great at telling me if a feature is missing or a punch is installed at the wrong angle, or there is an extra feature on the part. However, the dimensional readings it gives me do not match what I get on the surface plate with standard inspection tools. I have seen .020" difference in measurements
Sponsored Links
Old 6th February 2010, 04:01 PM
True Position's Avatar
True Position True Position is offline
per ASME Y14.5M-1994
Registration Date: Feb 2005
Thanks Given to Others: 4
Karma Power: 65
True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.True Position is appreciated, and has over 1700 Karma points.
Default Re: Flat Panel Laser Scanner Calibration
How well does the machine repeat to itself? Are the problems related to diameters or more position of holes? When you get a 'bad' result does it tend to be in the same direction? (could be a hint of a dirty/bad glass scale) If you take the same part and check it in a couple orientations does it repeat well? If it were a camera based system and not laser I'd recommend also coating some of the edges with layout dye and seeing if that helps.
Sponsored Links
Old 11th February 2010, 03:36 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 199
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Thread moved for greater visibility on calibration issue.
Reply
Bookmarks
Tags
calibration
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
3D Measurements with Camera (scanner) cabdriver General ISO 17025 Topics - Calibration, Measurement Gages and Test Laboratories 13 11th June 2009 12:07 PM
Calibration Frequency for Leica Laser Tracker kevinclynes Calibration Frequency (Interval) 4 29th May 2008 02:43 PM
Laser Etching - Company that will repair/service an InstaMark (control laser) - Help! ISOsandy Manufacturing and Related Processes 7 29th November 2006 11:02 AM
6-panel report explained? How to fill out a "good" 6-panel report TownDawg Six Sigma 13 8th March 2006 12:09 AM
Is calibration of digital panel important in any semicon company? calib General ISO 17025 Topics - Calibration, Measurement Gages and Test Laboratories 3 2nd August 2001 06:33 PM
The time now is 05:41 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
If you are having problems Registering, Activating your Registration, or other problems, you can phone me in the US. I'm not here 24/7/365, but if I'm here I'll try to help.
no new posts
