Hello guys, appreciate and need help on the below :
How am i going to determine the distribution (standard, normal etc) of the graph from minitab?
Two ways:
1. If you are assuming that it is Normally distributed and want to verify go to:
Stat>Basic Statistics>Graphical Summary
Look at the left side panel under the "Andersson-Darling Normality Test"
Ho: Data is Normal
Ha: Data is not Normal,
check the p-value, usually 0.05 is the set cut-off. Below that it is taken as evidence of Non-normality.
2.
Go to Graph>>Prob Plot
Select the variable of interest and the hypothesized distribution using the "Distribution" Button.
Click on "OK" and check visually if plotted points follow the "ideal" line.
Objectively test the hypothesis:
Ho: Data is like the hypothesized distribution
Ha: Data is not like the hypothesized distribution
check the p-value, usually 0.05 is the set cut-off. Below that it is taken as evidence of Ha.
Regards,
Reynald
"Unless the CEO builds the Company, the Engineers labor in vain"
Thanks to reynald for your informative Post and/or Attachment!
Re: Graph Distribution Identification (standard, normal etc) from Minitab
Hello Reynald,
Your explanation has been very helpful for me in finding a way out to my doubt. Keep up the good work and i really appreciate your fast and accurate reply to my question.
