22nd February 2010, 06:10 PM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 1
Karma Power: 40 Karma: 75
Scales calibrated by an ISO 17025 accredited organization? TS 16949 requirement?
Hello everyone!
We recently had our TS audit. The auditor looked at our weight scales and said that the company that calibrates them should be 17025 or national equivalent. The service that we use is ISO 9001 only. This comes from the section dealing with external labs. We only use the scales to weigh the parts that we put into baskets for Heat Treating. The weight has to be accurate to get the correct heat treating results (hardness, etc).
Won’t 9001 do or does it have to be equivalent to 17025?
Thanks!
James M. Warner
"Workaholic"
22nd February 2010, 06:12 PM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,686
Karma Power: 476
Re: 17025 for weight scales
Originally Posted by dbzman
Hello everyone!
Thanks!
No, ISO/TS 16949:2009 clearly states that the external (calibration) lab must be ISO/IEC 17025 accredited. So kudos for the auditor and regretfully a NC for your organization.
Stijloor.
22nd February 2010, 06:16 PM
Thaumaturge
Thanks Given to Others: 515
Karma Power: 262
Re: Scales calibrated by an ISO 17025 accredited org?
I agree with Stijloor. I would have written the nonconformity too. In fact, I have on multiple occasions.
22nd February 2010, 06:20 PM
Courtesy Access
Stijloor.
I agree that it is a non-conformity, however we talked him out of it so NO FINDING!
Since the standard says 17025 or National equivalent, what works besides 17025? What would be a national equivalent for weight scales?
Thanks!
James M. Warner
"Workaholic"
22nd February 2010, 06:22 PM
Karma Power: 476
Thanks!
Sorry James, you would not have been successful with me....
ISO 17025 is a very common accreditation standard in the USA, so why would you look for an equivalent?
Stijloor.
22nd February 2010, 06:25 PM
Courtesy Access
Stijloor.
The supplier that we use to calibrate our weight scales is very close to our facility. We have had very good service with them and no problems. Why change?
Value added please?
James M. Warner
"Workaholic"
22nd February 2010, 06:28 PM
Karma Power: 476
Value added please?
I can see your point. But auditors do not make the rules. And ISO/TS is not always about convenience. But you know what? Why did your organization pursue ISO/TS 16949 for just one automotive customer? Are you guys high up in the supply chain? Because with ISO 9001, the calibration requirements would be different.
Stijloor.
22nd February 2010, 06:34 PM
Courtesy Access
Stijloor.
I have, for some time, tried to get them to go to just ISO but one customer (TRW) has required it so they are sticking with TS.
I have no problem with meeting the standard I just need to know what “national equivalent” might be for a calibrations service.
If TS mentions an alternative to 17025 there must be one, right?
Thanks!
James M. Warner
"Workaholic"
Forum Posting Settings
