Go Back   The Elsmar Cove Forum > Medical Device Regulations and Standards > Medical Device Related Standards > ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems
Thread Tags
Tag Cloud
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Tags
shipping, traceability
Reply
Old 9th March 2010, 03:31 PM
TNHunter TNHunter is offline
Involved - Posts
Registration Date: Dec 2005
Karma Power: 23
TNHunter is appreciated, and has over 200 Karma points.TNHunter is appreciated, and has over 200 Karma points.TNHunter is appreciated, and has over 200 Karma points.
Please Help! Partial Shipping of Lots - Shipping of product prior to the lot being completed
I question has arisen in our organization about shipping of product prior to the lot being completed.
We recently started producing lots in excess of 30,000 pieces. Upper management has done this to reduce the number of work orders on the shop floor. The customer may want 3000 of these parts prior to the 30,000 being completed, so 3000 pieces are pushed through and shipped even though it may be 2 -3 weeks before the work order is completed.
Would the customer have to grant a concession to accept product given the above?
How would traceability be effected by this? How much traceability is required, Not defined in ISO? Can we define how much traceability is required or should the customer define it?
I have used break off travelers previously to allow for this with traceability back to the original work order, effectively making this a sublot.
Any thoughts would be appreciated.
Sponsored Links
Old 9th March 2010, 04:37 PM
LSS Master LSS Master is offline
Involved in Discussions
Registration Date: Nov 2009
Karma Power: 4
LSS Master has less than 100 Karma points so far.
Default Re: Partial Shipping of Lots - Shipping of product prior to the lot being completed
It seems to me that there are several issues involved.
First and most importantly, what information/requirements regarding this issue does the contract (PO, order, etc.) from the customer contain? If there are requirements regarding shipping of partial orders and traceability, they must be followed/satisfied.
In the absence of contract requirements, ISO requires that the producer maintain traceability throughout the production process, including delivery to the customer ("delivery" should be defined in the contract requirements). The method used is up to the producer to define.
From a Lean manufacturing perspective, fewer work orders through the shop may result in higher inventories. Has anyone performed a cost/benefit analysis to determine which path produces the higher savings?
I hope you find this to be of use!
Sponsored Links
Old 9th March 2010, 11:38 PM
Golfman25 Golfman25 is offline
Registration Date: Jan 2010
Karma Power: 7
Golfman25 is appreciated, and has over 100 Karma points.Golfman25 is appreciated, and has over 100 Karma points.
Everyday fact of life where I come from. And you certainly don't want to hold a shipment waiting for additional parts to work their way through.
Walk thru your system and make sure you are covering each step for the partial shipments. For example, if you have a final inspection, make sure you apply it to the partial shipment as well as the balance. Apply your traceability requirements to the partial shipment as well as to the balance. Exactly what you do and how you keep records will be dependent upon your system requirements. Good luck.
Old 10th March 2010, 06:14 PM
gholland gholland is offline
Registration Date: May 2008
Thanks Given to Others: 12
Karma Power: 21
gholland is appreciated, and has over 500 Karma points.gholland is appreciated, and has over 500 Karma points.gholland is appreciated, and has over 500 Karma points.gholland is appreciated, and has over 500 Karma points.gholland is appreciated, and has over 500 Karma points.gholland is appreciated, and has over 500 Karma points.
What does your Quality Manual say? That's the first question you would be asked. If you don't have a process for partial lots established then you're not following your procedures and you're exposed to audit findings. If I were forced I would document in your traceability system that you didn't follow your procedures intentionally, rationalize why it's ok, and start a Corrective Action to establish a procedure.
Otherwise Golfman25 has it. If I were asked to do this and change my company's QM procedure I would require a subset of in-process and lot acceptance testing be performed based on lot size. I would also establish traceability to make sure if there was an issue found later in the large lot that you have some way of tracking this smaller lot so you can recall it.
Good luck
Old 11th March 2010, 02:26 PM
TurtleD's Avatar
TurtleD TurtleD is offline
Shy Poster (1 to 5 Posts)
Thanks Given to Others: 2
Karma Power: 9
TurtleD has less than 100 Karma points so far.
Hi. A company that I used to work for got "dinged" in an ISO audit for partial shipments so we opted to reference partials in multiple procedures (as applicable) ... this is an excerpt from the Device History Record procedure:
Release prior to completed work ticket
In the event product from a work ticket must be shipped to customer prior to completion of work ticket, the following process is to be used:
Finished product must be inspected by Manufacturing and Quality (or their designee)
Product’s container is stamped “QC” or “Approved”
Work Ticket is stamped with: Partial Release Approved (or equivalent) and signed/dated by Manufacturing & Quality or their designee
Lot Tracking log is filled in with necessary ship to information (may include customer’s PO number or HM’s invoice number)
Remainder of work ticket’s product is completed following 4.6 – 4.9
Reply
Bookmarks
Tags
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Knowingly Shipping Non-Conforming Product glade Quality Management Related Issues 4 11th March 2010 04:34 PM
Multi-site shipping - Shipping Level 2 example needed irish01 Documentation Control Systems, Procedures, Forms and Templates 4 17th July 2009 08:54 AM
Shipping Validations prior to exporting our product Achemd ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems 4 23rd July 2008 01:30 AM
Shipping Efficiency - 1% return rate due to shipping errors quest Misc. Quality Assurance and Business Systems Related Topics 6 19th July 2006 01:34 AM
Shipping nonconforming product - Out of print OZZIE Nonconformance and Corrective Action 6 2nd June 2000 10:36 AM
The time now is 05:30 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
If you are having problems Registering, Activating your Registration, or other problems, you can phone me in the US. I'm not here 24/7/365, but if I'm here I'll try to help.
no new posts
