The Cove Business Standards Discussion Forums
Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
5.9, iso 17025 - testing and calibration laboratories, calibration reports and certificates, calibration (general topics), iso 14664 - cleanrooms and associated controlled environments
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 14th March 2010, 01:14 PM
suildur's Avatar
suildur
Please Help! Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9
I am working to build an integrated QMS for a calibration lab and an inspection body which are established under the same company.
The proposed accreditation scope of the calibration lab is as below:
1. Heat cells
2. T/Cs
3. Pressure (up to 75 bar)
4. Non-automatic weighing scales (up to 150 kg)
The inspection body's scope is inspection of clean rooms and zones according to ISO 14664-1, -2 and -3.
Anyway, I have constructed a QMS documentation as belows:
1. QM
2. Procedure 1 - Control of documents and Records
3. Procedure 2 - Sales
4. Procedure 3 - Purchase
5. Procedure 4 - Customer Relations
6. Procedure 5 - Corrective and Preventive Action
7. Procedure 6 - Control of Nonconforming Operation
8. Procedure 7 - Management Review
9. Procedure 8 - Internal Audit
10. Procedure 9 - Training
11. Procedure 10 - Quality Assurance
12. Procedure 11 - Clean Room Inspections and Tests
13. Procedure 12 - Calibration
14. Procedure 13 - Control of Data
15. Procedure 14 - Control of Reference Equipment
The system structure is based on ISO 9001 plus 17020's and 17025's additional requirements.
So... My questions to 17020 and 17025 experts are as follows (begining from the most important):
ISO IEC 17025 clause 5.9 Assuring the quality of test and calibration results requires a procedure. The requirement states (in short);
5.9.1 There must be a quality control procedure where data are recorded, and, statistical methods are applied for the review of the results. That monitoring must be planned and reviewed. Monitoring can contain,
a. Building of internal quality control system by using certified reference materials,
b. Joining inter-lab test programmes, conducting proficiency tests etc.
c. Re-conducting of tests or calibrations with the same or different methods,
d. Re-conducting of tests or calibrations on the preserved material,
e. Research on the different specs of the material.
5.9.2 Quality control records/data must be analysed and planned operations are applied to correct the problem or to prevent reporting of nonconforming results when data are out of limits.
Okay, I clearly understand 5.9.1. I will write down the method for proficiency tests (where two of our employess will conduct the same calibration) and joining inter-lab test programmes (where our AB, TURKAK, or any other accredited laboratory plans a test programme we will join, too), however, the problem is about 5.9.2.
I understand there must be analysis if PT/ILC demonstrates a nonconformity. But, I have also seen some statistical methods (t-distribution, f test, z score, q test, chi square test, x cards) in a sample procedure.
So, shall I apply statistical methods on client's calibration results?
I mean,
1. Shall I apply statistical methods on each calibration step of an individual calibration of any client? For example, if we calibrate a T/C and use 10 calibration points, so I have 10 deviation values and an uncertainty value, shall I apply t-distribution on 10 deviation values?
2. And, shall I compare the uncertainty value to similiar T/C calibrations which we have conducted before?
Thanks in advance for answers.
P.S. I have checked the thread Compliance with ISO/ IEC 17025:2005 Clause 5.9 for Calibration Laboratories That doesnot help me, I think.
Sponsored Links
  Post Number #2
Old 16th March 2010, 02:58 AM
suildur's Avatar
suildur
Re: Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9
Arent there any answers? S.O.S!!!
Well, maybe kidding, but I really need some comments on this. Any comment or information is highly appreciated.
  Post Number #3
Old 16th March 2010, 11:14 PM
BradM's Avatar
BradM
Well... I'm certainly not an expert here. But I will certainly try.
In general, I interpret that section that you have adequate quality control over the records. This might be 100% inspection, or may involve using SPC and control charts. Basically you have assurance to detect if something is out of specification, and a plan to deal with it when it is discovered.
  Post Number #4
Old 17th March 2010, 05:02 AM
suildur's Avatar
suildur
In Reply to Parent Post by BradM View Post
Yes, maybe not an expert answer, but at least that's an answer.
Thanks for your kind reply...
  Post Number #5
Old 17th March 2010, 03:59 PM
Hershal's Avatar
Hershal
Here is a document that may help. It is a no cost download.
http://www.aplac.org/documents/pt/ap...01_issue_5.pdf
  Post Number #6
Old 18th March 2010, 04:18 PM
suildur's Avatar
suildur
In Reply to Parent Post by Hershal View Post
Thanks for the answer. However, that is not what I m looking for. Anyway, I got an answer in another way.
And the answer is there is no need to calculate with t-&f-tests or z-score to assure the quality of calibration results.
  Post Number #7
Old 18th March 2010, 08:27 PM
Mgrace
Dear Suildur,
When reporting the uncertainty, t distribution is really needed because the uncertainty will be express like this....>>>> example : The uncertainty is 0.01C with a coverage factor K=2 at 95% confidence level. "K=2 at 95% is from t distribution.
That is my idea and I'm not expert for that.
  Post Number #8
Old 19th March 2010, 05:35 AM
suildur's Avatar
suildur
In Reply to Parent Post by Mgrace View Post
Dear Suildur,
Yes, you are right, but, right for the expanded uncertainty As you probably know, every calibration method has its own method of uncertainty calculation, and, those are determined by internationally recognized reference documents if you are using standard referenced methods. After calculating the uncertainty you expand it by multiplying the uncertainty result with two. But, that's something different than what I was asking.
I asked, if I must apply any statistical method to check whether the distribution of the sample space (calibration step results) is meaningful or not, each time I calibrate something. I got an answer from another lab, that there is no need to apply those statistical methods for the calibration.
Thanks for your kind interest.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
ISO 17025 Clause 5.4.2 - Calibration and Test Method Requirements tacom ISO 17025 related Discussions 6 7th February 2012 12:37 AM
Calibration Procedures - ISO/IEC 17025, Clause 5.5.9 - Outsourced Calibration Tom from Clayton ISO 17025 related Discussions 10 5th October 2010 06:37 AM
ISO 17025 Clause 5.9 - Calibration results - How to achieve what ISO wants Sofia Cal ISO 17025 related Discussions 7 1st December 2005 11:15 AM
17025 Para. 5.6.2 - Calibration certificates - Measurement results - Uncertainty joecalibratio ISO 17025 related Discussions 6 18th October 2005 03:39 PM
Trying to find an ISO 17025 accredited testing laboratory to verify our test results Rachel ISO 17025 related Discussions 14 10th November 2004 11:31 AM
The time now is 07:03 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
