Go Back   The Elsmar Cove Forum > National and International Business Standards > FDA (United States Food and Drug Administration) > General FDA Topics
Thread Tags
Tag Cloud
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Tags
calibration, glp (good laboratory practices), maintenance, operation manual, regulations and regulatory requirements
Reply
Old 15th March 2010, 11:09 AM
AnaMariaVR2's Avatar
AnaMariaVR2 AnaMariaVR2 is offline
Involved in Discussions
Registration Date: Mar 2010
Thanks Given to Others: 309
Karma Power: 6
AnaMariaVR2 is appreciated, and has over 100 Karma points.AnaMariaVR2 is appreciated, and has over 100 Karma points.
Send a message via Yahoo to AnaMariaVR2
Please Help! Regulatory References for the Operation, Maintenance and Calibration of GLP equipment
Dear Colleagues:
I want to see if anybody could guide me as to where can I find the regulatory references backing the operation, maintenance and calibration of several GLP equipment used in regulatory studies. Currently there is a lot of confusion about which standards apply and/or should be used for regulatory studies.
Which are the standards (FDA, ICH, ISO, etc., ?) to follow or that apply for the operation, maintenance and calibration of pipettes, pH meters, weight balances, plate readers, etc., or other more complex instrumentation?
I'm looking forward to your feedback. I want to clear the confusion at work, focus on the right standards and comply with them.
I appreciate everybody's time and consideration to my question.
Best Regards,
Ana Maria Rodriguez-Rojas
Sponsored Links
Old 15th March 2010, 11:52 AM
Karma Power: 6
Cool Re: Regulatory References for the Operation, Maintenance and Calibration of GLP equip
I just found the Pipette Standards Handbook and I want to share it with all.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf Pipette Standards Handbook by Troemner.pdf (1.12 MB, 23 views)
Sponsored Links
Old 15th March 2010, 12:10 PM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 878
Karma Power: 317
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Default Re: Regulatory References for the Operation, Maintenance and Calibration of GLP equip
Hi there!
NOTE: A alot of acronyms used here. If you are not familar with one of them, please ask.
I am not sure I understand your question. Within the framework of FDA, there are lots of standards like you mention, including CFR (Code of Federal Regulation for applicable items) and ISO (for applicable items).
For example, CFR addresses balances used to measure assay (Good Laboratory Practice work). But the Handbook 44 may be a better standard for non-GLP balances.
You posted a document on pipettes. I might go with IS0 8655 for that.
Cleanroom classifications are another, sterilization another, etc.
So yes, for many of the operation areas, there will be a standard. For some, there may not be one. A pressure gauge used for steam sterilization pressure will need to be calibrated, but may not have an associated standard. One would need to be developed for it.
Brad
Chuck Norris has counted to infinity.Twice.
Thanks to BradM for your informative Post and/or Attachment!
Old 17th March 2010, 11:28 AM
Karma Power: 6
Let Me Help You Re: Regulatory References for the Operation, Maintenance and Calibration of GLP equip
Thanks BradM for your response!
Like you say, there will be clear standards for many of the operation areas, however for other areas/topics, there may not be clear one.
Despite all the guidances and regulations, there are problem (grey) areas in GLP bioanalysis which can cause uncertainty, inconsistency, regulatory citations and/or re-work.
How I see this, it seems to me that it may be due to one or a combination of these:
  1. technical areas are not covered in great detail in the guidances or regulations.
  2. 'translation' and application of the GLP regulations within the bioanalytical environment.
  3. Regulatory citations for deficiencies in areas not clearly defined in guidances or regulations.
In my original posting I was mainly asking about which standards (FDA, ICH, ISO, etc., ?) to referenced in an SOP (for example) in order to establish quality/compliant procedures for the operation, maintenance and calibration of pipettes, pH meters, weight balances, plate readers, etc., or other more complex instrumentation. These types of activities are not covered in great detail in guidances or regulations. More clarity will be nice.
Reply
Bookmarks
Tags
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Aviation Safety Standards applicable to operation and maintenance Joy Federal Aviation Administration (FAA) Standards and Requirements 2 26th January 2010 10:22 AM
Calibration and Preventive Maintenance - What is meant by Calibration Life Cycle JHONNYMEDICO Student Research Questions - Any Educational Institution 2 13th November 2009 12:22 PM
What is External Documentation? Equipment Operation Manuals and Handbooks Ruthie J ISO 9001 - General Questions and Discussions 4 23rd February 2009 11:19 PM
FDA's view on Wiki's for users to find equipment operation procedures kisxena US Medical Devices (21 CFR part 820) 13 5th January 2009 12:57 PM
Good References and Books in the field of Calibration Ruebenn General ISO 17025 Topics - Calibration, Measurement Gages and Test Laboratories 4 29th June 2008 12:32 PM
The time now is 05:39 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
If you are having problems Registering, Activating your Registration, or other problems, you can phone me in the US. I'm not here 24/7/365, but if I'm here I'll try to help.
no new posts
