The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
design of experiments (doe), minitab (statistical analysis software)
Reply
Old 19th April 2010, 08:09 PM
beejkelly beejkelly is offline
Getting Involved (6 to 9 Posts)
Registration Date: Apr 2010
Karma Power: 13
beejkelly has less than 100 Karma points so far.
Please Help! Design of Experiment - 24 Samples per Run
I have 11 different runs - set by my design of experiments factorial design with center pt. For each run - production took 4 samples at 6 different intervals during the run.
I am used to in Minitab where for the run you have
StdOrder RunOrder CenterPt Blocks Hold psi Barrel Temp Mold Temp Overall Length ID(these are in order of column below but too wide to fit over each column)
6 1 1 1 19000 500 165 4.52701 0.73537
7 2 1 1 15000 530 165 4.52672 0.73520
11 3 0 1 17000 515 180 4.52729 0.73543
3 4 1 1 15000 530 165 4.52642 0.73516
10 5 0 1 17000 515 180 4.52690 0.73536
9 6 0 1 17000 515 180 4.52691 0.73538
2 7 1 1 19000 500 165 4.52703 0.73545
5 8 1 1 15000 500 195 4.52462 0.73494
8 9 1 1 19000 530 195 4.52969 0.73558
1 10 1 1 15000 500 195 4.52453 0.73491
4 11 1 1 19000 530 195 4.52950 0.73557
the second to last and last columns are the Mean of the 24 data points Per run.
Is there a better way to analyze of Design of Experiments in minitab to include all individual points ??
thanks,
Barb
Sponsored Links
Old 19th April 2010, 08:20 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Statistician
Registration Date: May 2005
Thanks Given to Others: 206
Karma Power: 134
Statistical Steven is appreciated, and has over 1700 Karma points.
Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.Statistical Steven is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to Statistical Steven
Re: Design of Experiment - 24 samples per run
In Reply to Parent Post by beejkelly View Post
thanks,
Barb
Barb
If you look at your variable called Block you will notice you have a single block. You can replicate the setting and for each of the 6 sample intervals, you can increment the block variable (6 blocks). For each block you can replicate the design matrix 4 times for each replicate. You should end up with 264 rows (6x4x11). There might be other ways, but this gives you the sampling interval variability and within interval variability will be part of the MSE.
Steven Walfish
When in doubt, ask your company statistician!
Thanks to Statistical Steven for your informative Post and/or Attachment!
Sponsored Links
Old 19th April 2010, 08:38 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 389
Miner is appreciated, and has over 1700 Karma points.
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Look! Re: Design of Experiment - 24 samples per run
In Reply to Parent Post by Statistical Steven View Post
Barb
Steve,
If these were true replicates, that would be an option, but these are repeats. The variation for repeats is typically less that that of replicates because it does not include setup variation.
The standard approach for repeats is to calculate the average and standard deviation for the within run repeats then analyze the mean and Ln(StdDev) separately.
Because these repeats were collected in subgroups, I would evaluate both short and long term variations, as well as evaluate in a control chart.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
Old 19th April 2010, 08:59 PM
Karma Power: 13
Re: Design of Experiment - 24 Samples per Run
So I took the Mean of each Run (mean of the 24 samples) and looked at the Length and ID See below
not sure what the Curvature Line means???
Thanks so much for helping-
Does this look right for that data and just looking at the means
do I do same DOE but for st. Dev. (not sure why ln in front of your st.dev)
again thanks a ton!!
Barb
Welcome to Minitab, press F1 for help.
Full Factorial Design
Factors: 3 Base Design: 3, 8
Runs: 11 Replicates: 1
Blocks: 1 Center pts (total): 3
All terms are free from aliasing.
Alias Information for Terms in the Model.
Totally confounded terms were removed from the analysis.
I + Hold psi*Barrel Temp*Mold Temp
Hold psi + Barrel Temp*Mold Temp
Barrel Temp + Hold psi*Mold Temp
Mold Temp + Hold psi*Barrel Temp
* NOTE * Some of the terms requested in MEANS were removed from the analysis.
Factorial Fit: Overall Length versus Hold psi, Barrel Temp, Mold Temp
Estimated Effects and Coefficients for Overall Length (coded units)
Term Effect Coef SE Coef T P
Constant 4.52694 0.000059 76940.22 0.000
Hold psi 0.00273 0.00137 0.000059 23.24 0.000
Barrel Temp 0.00229 0.00114 0.000059 19.42 0.000
Mold Temp 0.00029 0.00015 0.000059 2.46 0.049
Ct Pt 0.00009 0.000113 0.83 0.439
S = 0.000166416 PRESS = *
R-Sq = 99.35% R-Sq(pred) = *% R-Sq(adj) = 98.92%
Analysis of Variance for Overall Length (coded units)
Source DF Seq SS Adj SS Adj MS F P
Main Effects 3 0.00002557 0.00002557 0.00000852 307.78 0.000
Curvature 1 0.00000002 0.00000002 0.00000002 0.69 0.439
Residual Error 6 0.00000017 0.00000017 0.00000003
Pure Error 6 0.00000017 0.00000017 0.00000003
Total 10 0.00002576
Estimated Coefficients for Overall Length using data in uncoded units
Term Coef
Constant 4.47435
Hold psi 6.83750E-07
Barrel Temp 7.61667E-05
Mold Temp 9.66667E-06
Ct Pt 0.000093333
Least Squares Means for Overall Length
Mean SE Mean
Hold psi
15000 4.526 0.000083
19000 4.528 0.000083
Barrel Temp
500 4.526 0.000083
530 4.528 0.000083
Mold Temp
165 4.527 0.000083
195 4.527 0.000083
Mean for Center Point = 4.527
Effects Plot for Overall Length
Effects Pareto for Overall Length
Alias Structure
Residual Plots for Overall Length
Factorial Fit: ID versus Hold psi, Barrel Temp, Mold Temp
Estimated Effects and Coefficients for ID (coded units)
Constant 0.735273 0.000012 60456.05 0.000
Hold psi 0.000440 0.000220 0.000012 18.09 0.000
Barrel Temp 0.000210 0.000105 0.000012 8.63 0.000
Mold Temp -0.000045 -0.000023 0.000012 -1.85 0.114
Ct Pt 0.000118 0.000023 5.05 0.002
S = 0.0000343996 PRESS = *
R-Sq = 98.63% R-Sq(pred) = *% R-Sq(adj) = 97.71%
Analysis of Variance for ID (coded units)
Main Effects 3 0.00000048 0.00000048 0.00000016 135.06 0.000
Curvature 1 0.00000003 0.00000003 0.00000003 25.46 0.002
Residual Error 6 0.00000001 0.00000001 0.00000000
Pure Error 6 0.00000001 0.00000001 0.00000000
Total 10 0.00000052
Estimated Coefficients for ID using data in uncoded units
Term Coef
Constant 0.730068
Hold psi 1.10000E-07
Barrel Temp 7.00000E-06
Mold Temp -1.50000E-06
Ct Pt 0.000117500
Effects Plot for ID
Effects Pareto for ID
Alias Structure
Residual Plots for ID
Old 19th April 2010, 09:25 PM
Miner's Avatar
Karma Power: 389
Look! Re: Design of Experiment - 24 Samples per Run
The center point is used to test for curvature. In this analysis, the p-value of 0.439 indicates that there is no curvature. Rerun your analysis after removing the center point from the model.
Ln (Std Dev) = Natural log (Std Dev)
The variance of Standard Deviations changes based on the magnitude, so a Natural log transform is used to stabilize the variance. Log base 10 can also be used.
Old 19th April 2010, 09:27 PM
Karma Power: 13
Is that what you should do - is just delete the runs with the center pts in minitab(3 runs here) and just rerun DOE???
Old 19th April 2010, 09:29 PM
Miner's Avatar
Karma Power: 389
No. If you are using Minitab, uncheck the box for Include center points in model? under the Terms menu. What software are you using?
Old 19th April 2010, 11:08 PM
Karma Power: 13
yes minitab
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Design of Experiment (DOE) Help Needed massfrompak Quality Tools, Improvement and Analysis 8 21st June 2010 12:53 PM
Design an experiment to optimize the PCB solder reflow profile peacewong Design and Development - Process and Product 4 3rd July 2008 03:17 AM
Design of Experiment (DOE) for Heat Treatment Process Bill Rudnicki SPC Monitoring and Statistical Analysis Techniques 4 28th May 2008 02:41 PM
DOE (Design of Experiment) with Several Output Variables sabrinalim Quality Tools, Improvement and Analysis 4 15th April 2008 05:08 AM
Minitab refuses to run saying the Design is Not Balanced - Gage R&R davis007 Using Minitab Software 14 26th July 2006 08:25 AM
The time now is 06:33 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
