Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th January 2002, 04:28 PM
AURELIO AURELIO is offline
Registration Date: Jan 2002
Karma Power: 32
AURELIO has less than 100 Karma points so far.
Question Internal Audits - Can we to perform audit just using process maps?
If ISO 9001:2000 require at least 6 documented procedures for QMS. Can we to perform audit just using process maps ( flow chart) as work instruction or QAP?
Sponsored Links
Old 15th January 2002, 04:40 PM
Jim Biz's Avatar
Jim Biz Jim Biz is offline
Registration Date: Mar 2000
Karma Power: 51
Jim Biz is appreciated, and has over 100 Karma points.Jim Biz is appreciated, and has over 100 Karma points.
Spin!
I wouldnt know why you could not do it that way
BUT what rumors I have heard explain that even auditing methods will be changing....
What external auditors do now is "compare actions to standards requirements." Internal auditors compare actions to written procedures... and verify they are yes/no being satisfied.
The "new look approach" to auditing (big guess here ) is that effectivness of what the standards require or effectivness of what the proceedures are asking for will be the major consideration. NOT necessarily - are the same words used in the standards - used in the procedures - but is the intent of an effective outcome as esxplained in the standards being accomplished.
Regards
Jim
"Chance is a word void of sense; nothing can exist without a cause."
Voltaire
Sponsored Links
Old 16th January 2002, 06:20 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default Compliance vs Effectiveness
Its true that the traditional 'compliance' only auditing is considered to be a thing of the past. The requirement to audit effectiveness is now emphasised in ISO9001:2000, although it did exist in the 1994 version. Compliance auditing will still be an important element of the audit process, but blindly quoting non-compliance or compliance where the actual activity is effective or ineffective will hopefully die.
Auditing should now look at the process, consider the inputs, outputs, mechanisms and controls. A written procedure or a flow diagram might be one method of control - what the auditor must satisfy himself with is 'are the controls adequate so that the process performs effectively', clearly looking at the output of the process will be a major part of this assessment.
Old 16th January 2002, 06:24 AM
Courtesy Access
Karma Power: 80
Default P.S.
As a P.S. to the last post...
ISO9001:2000 now also explicitly states that audits are undertaken against the requirements of the standard. This was always considered 'best practice', and is the method taught by accredited audit training bodies.
So primarily your audit needs to address compliance with ISO9001:2000, therefore without a procedure or flow diagram there is still plenty to audit against.
Old 16th January 2002, 08:40 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
Please remember that as flow charting is simple and may be easier to comprehend,however you will more than likely need to also supplement with words. Anything you write(flow chart) for you QMS must be understandable by your people who use it. Do not write(flow chart) for the registrar/auditors. Make a value added QMS for your users of the QMS .
Old 16th January 2002, 09:08 AM
Karma Power: 32
Default
Thank You Sirs
I agree both as about a new audit approach as the audit having focus on the effectiveness of output, since I am with advisor hat that look at not only standard compliance but add value to client process output too.
BUT, If someone is on auditor hat, mainly registrar auditors, could miss some information in a diagram flow, as WHO, WHEN, WHERE, WHAT, WHY, HOW, not necessarily all.
And I knowing very well what is a point of view of registrar auditor, for example, some registrars auditors say that is a paradox the standard require at least six written procedures or another auditor wants quality objectives measurable for ALL FUNCTIONS within organization, I would like to remake my question as:
Does anyone have experience with registrars auditors using only diagram flow to perform process assessment and these was accept as a work instruction?
Best Regards
AURELIO
Old 16th January 2002, 11:00 AM
Courtesy Access
Karma Power: 80
Default diagram flow
We have used flow diagrams for years, and have been successfully audited against them.
Your auditor should be able to accept the format of your documentation whatever it is.
Old 18th January 2002, 07:50 AM
Laura-2002's Avatar
Laura-2002 Laura-2002 is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2001
Karma Power: 0
Laura-2002 has less than 100 Karma points so far.
Laughing my 2 pen'orth
I've used flow charts to document procedures and had no problems with staff or auditors, in fact I find them easier to audit.
One more thing!
I was given to understand by a BSI assessor that it would be prudent for an organisation to audit the QMS by selecting one of the quality management principles and using it as a theme for the annual audit plan.
Any thoughts?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How many audits a year do your internal auditors perform? Claes Gefvenberg Internal Auditing 42 6th April 2009 12:27 PM
ISO 14001 Clause 4.5.4 - Internal Audit - Must a company perform internal audits? adamsjh ISO 14001 and Environmental Related Standards 5 16th July 2003 01:30 PM
Outsourcing Internal Audits - Hiring a contractor to plan and perform internal audits Richard K Internal Auditing 21 16th July 2001 06:47 PM
Is training necessary to perform internal audits within our company Aussie Internal Auditing 1 5th July 2001 01:58 AM
Our QS9000 audit team has been using checklists to perform internal audits Becky Blosser Internal Auditing 37 14th July 1999 01:23 AM
The time now is 08:34 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
