Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
5th May 2010, 12:29 PM
Involved in Discussions
Registration Date: Oct 2005
Thanks Given to Others: 43
Karma Power: 34 Karma: 35
Continual Improvement of the Organization - TS 16949 Clause 8.5.1.1
Hello Covers,
Once again, here I am with a doubt: When the ISO/TS16949 says, in its 8.5.1.1 requirement, that "The organization shall define a process for continual improvement", what that means?
Is necessary to implement a core process according to the process approach, or it means that the continual improvement must be a part of all the processes?
Salutations,
Vitor
6th May 2010, 01:06 PM
Dirk
Registration Date: Jun 2004
Thanks Given to Others: 410
Karma Power: 153
Re: Continual Improvement of the Organization - TS 16949 Clause 8.5.1.1
In my opinion, either could be a possible approach. I would define it however your organization achieves continual improvement.
Our entire QMS is our defined, interrelated processes that allow us to achieve continual improvement.
Thanks to vanputten for your informative Post and/or Attachment!
6th May 2010, 01:24 PM
Registration Date: Nov 2009
Thanks Given to Others: 98
Karma Power: 51
In Reply to Parent Post by vitortavares
Hello Covers,
Salutations,
Vitor
What is required is to have a organizational process for continual improvement. What type / format etc is not prescribed.
Certainly is is not expected to be able to demonstrate continual improvement for every process.
The key is - to demonstrate that the process you use is effective - . If it is - then the process you use is OK.
Remember it says shall have a process - and not necessarily a "documented" process.
Thanks to Richard Pike for your informative Post and/or Attachment!
30th June 2010, 07:41 AM
Registration Date: Jun 2010
Thanks Given to Others: 1
Karma Power: 27 Karma: 130
Hi !
You must have installed such processes for this continuous improvement. Iou can very easily mention here 5S or other suggestion system that allows you to enter improvement ideeas and to be applied in production.
Also, mention the quality policy that should include the focus for this. You can include daily production meeting with fast respons and a weekly department meeting. Could be included contingency plans/backup schemes.
14th January 2012, 11:18 PM
Registration Date: Sep 2004
Thanks Given to Others: 15
Karma Power: 42 Karma: 45
Perhaps I can revive the conversation.
To address the requirement:
We simply need to show that we take a consistent approach to continual improvement but this doesn't necessarily mean we need a "continual improvement" procedure that is documented. Right?
15th January 2012, 12:10 AM
Cross Forum Moderator
Registration Date: Mar 2008
Thanks Given to Others: 1,208
Karma Power: 430
In Reply to Parent Post by Dan M
That means your continual improvement be a planned activity.
To continually improve you need to know where you are and where you want to be and when and how. This comes out of a plan and a timeline, within which analysis of data and targets are determined, frequently monitored / corrected as necessary and progress made.
Best Regards...
Somashekar BV, INDIA
Thanks to somashekar for your informative Post and/or Attachment!
18th January 2012, 09:15 AM
Appreciated Information Resource
Thanks Given to Others: 216
Karma Power: 232
Consider that one of the output of management review is also recommendation for improvement. When an organization reach objectives, they shall also improve by means of continual improvement . It means that this shall be a stepped process, raising the so called "bar" whan you are already in compliance.
You shall demonstrated showing evidence that you have a process that pervades the whole organization, for example, adopting a project management approach and working in multidisciplianry approach to reach results to improve your QMS processes.
AN organization can puursue continual improvement with projects that carried the revision of QMS process or with step improving activities within existing processes.
Hope this helps
Forum Posting Settings
