Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO/TS 16949 - International Automotive Quality Systems Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th January 2002, 07:56 AM
rui12524 rui12524 is offline
E-Mails Invalid or Rejected
Registration Date: Dec 2001
Karma Power: 0
rui12524 has less than 100 Karma points so far.
Laughing Maintaining manufactoring process capability
8.2.3.1 Draft ISOTS 16949:2002 says "The organization shall maintain manufactoring process capability or performance as specified by the customer part aproval process requiremts":
Well, imagine that i have a Cpk of 5.25 mentioned in the PPAP; So, i understand that i can't go below 5.25! What if i mention in PPAP (control plan) that (although CPK of 5.25 was achieved) cpk must be superior to 1.67?
Best to all
Sponsored Links
Old 18th January 2002, 08:33 AM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default
There was an IASG intrepretation on this point which I am sure will apply to 16949 as well. You will find it listed as C7. It states "The intent of this requirement is based on the maintenance of the process and not the level of the indices' value. To maintain (or exceed) requires two components:
1) Monitoring of the process over time to verify capability and stability; and
2) If the process is capable and stable, then to verify that the process meets the requirements as described in PPAP 1.2.2.9.3"
The fact that you had at one point a 5.25 Cpk is immaterial. You are required to provide product meeting the requirements.
Hope this helps.
Dave
Sponsored Links
Old 18th January 2002, 08:40 AM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
Default
Technically, yes, you need to maintain that Cpk. Which begs the question, why do so good in the first place, right?
But the theory behind it is that your PPAP parts are matched up with other suppliers PPAP parts, and a Cpk of the assembly is established. Variation outside the 5.25 Cpk parts you submit is not considered. So if you add variation, the impact is not known. It's that variation that "gets them into trouble" so to speak.
I know its theoretical, and difficult to accept if the costs of maintaining 5.25 are high, but that's the rules right now.
Old 18th January 2002, 08:57 AM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Jeez, did the customer let you define the spec limits!
The initial study performed during PPAP is to get an idea about variation. Long term process performance is what is important and that should not deteriorate (sp) although it will vary.
Also, I see no difference in the thought process between holding a process at 1.67 or 5.25 if those are the accurate numbers. A process is a process and performs as designed when special causes are defined and removed.
I don't see the control plan as an appropriate place to put such a disclaimer, >1.67 is the industry "norm". Let sleeping dogs lay.
Plus, don't sweat it too much until the approved TS is released.
Old 18th January 2002, 08:59 AM
Karma Power: 0
Default
Ok, so what it seems is that i need a customer specification regrading cpk; we have some customers (although not in the auto business), that specifie cpk of 1.2 and 1.67.
The question is that we have a ppk in the PPAP process that's not a true cpk (at least i think so).
Just for the record, we make injected plastic parts! so, maintaining a cpk of +5 is unreall for most of the parts, as there is much variation that we CAN?T control (material and the sorts).
Comments?
Old 19th January 2002, 05:35 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
Believe it or believe it not this has happened a number of times.
If the distribution is good then we have had automotive customers, French and German asking us to give them tolerances that will give a ppk of 1.67 or in one case 2.0.
They have then changed the drawing for us.
I have also seen cases where the same part is produced by diferent suppliers each with their own drawing from the customer with their name on it and diferences in tolerances.
Old 23rd January 2002, 05:11 PM
frank-h frank-h is offline
Karma Power: 33
frank-h has less than 100 Karma points so far.
Bomb! I know someone will be upset.
I have also seen where a part was given to two suppliers and after both have submitted samples they were given different prints. New dimensions and or tolerances so the could both provide better CPK numbers. Is it me or does this sound like the customer is over critical on the specs for both vendors. Both parts work! Why not one print that you can actually manufacture to.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How is everyone handling TS2 Clause 8.2.3.1 - Maintaining Process Capability GoKats78 ISO/TS 16949 - International Automotive Quality Systems Standard 2 8th June 2005 07:06 AM
TS 16949 Clause 8.2.3.1 - Maintaining Process Capability p_tww ISO/TS 16949 - International Automotive Quality Systems Standard 9 11th September 2003 01:09 PM
MSA Chicken and Egg - Process Capability and Measurement System Capability M Greenaway Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 15th July 2002 01:44 PM
4.9.2 Maintaining Process Control - Maintaining ongoing process capability MSHELLEY QS-9000 - American Automotive Manufacturers Standard 13 4th April 2001 11:44 AM
Maintaining Process Control Tom Goetzinger QS-9000 - American Automotive Manufacturers Standard 1 7th March 2000 01:33 AM
The time now is 06:24 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
