Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th January 2002, 04:46 PM
Russ's Avatar
Russ Russ is offline
Registration Date: Apr 2001
Thanks Given to Others: 1
Karma Power: 42
Russ is appreciated, and has over 100 Karma points.Russ is appreciated, and has over 100 Karma points.
Send a message via AIM to Russ
Listen To Me! Where I can find the grade requirement for an inspection plate
Does anyone know where I can find the grade requirement for an inspection plate used in a QS9000 shop? All of our granite plates are certified to Grade B however we have many steel plates that are used from time to time that really need calibrated. However, we are having trouble finding any shop who can calibrate them to Grade B which is the standard we have in our QMS. Anyone know where and if this is spelled out in QS9000?
Sponsored Links
Old 18th January 2002, 06:11 PM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Gaging is not specifically called out in the standard. However 4.11.2.a of QS states that "the supplier shall determine the measurements to be made and the accuracy rfequired, and . . . . .
It is up to you to select the equipment you need to do the job. Some people use a 10:1 rule some use as low as 4:1. The standatd for surface plates is GGG-P-463. Two plates are listed Gradw A Inspection grade & Grade B shop grade. If yours can not be calibrated to grade B then it may not be of much use.
Sam Goody
Sponsored Links
Old 21st January 2002, 08:47 AM
Russ's Avatar
Karma Power: 42
Question Inspection Plates
Sam,
Thru exhaustive research I see where you are on this. We state we calibrate our inspection plates to Grade B. Since we need to spell out our specifications, can we seperate certain inspection routines from the rest, i.e. say we use plates calibrated to a custom Grade C for checking only concentricity? I think this would simplify most of my problems with this issue.
So simple yet so complicated
Old 21st January 2002, 10:26 AM
Ryan Wilde's Avatar
Ryan Wilde Ryan Wilde is offline
Registration Date: Feb 2001
Karma Power: 41
Ryan Wilde is appreciated, and has over 100 Karma points.Ryan Wilde is appreciated, and has over 100 Karma points.
Default
GGG-P-463c is the Fed Std for Granite Surface Plates only, and does not apply for steel or cast iron surface plates. I can't recall what the Fed Std for metallic plates is off-hand, but I will look when I get home tonight. As I recall, the specification on non-granite plates was much looser.
That said, it is very difficult to find a company that can measure/resurface a metallic surface plate because it is not cost effective. The process of resurfacing them is very time consuming and very close to artistic. In the hundreds of locations that I have been in doing surface plates, all but one had marked their cast surface plates as "Reference Only" and replaced them with granite surface plates, due to the very well characterized elasticity modulus of granite, the availability of service, etc.
If you must keep the steel/cast iron plates, then you should spec them as you need them, and hope that they never require resurfacing. The only company I ran into that could resurface them used the same method that they used for mill surfaces, which was a hand scraping that took a few days labor. If you are looking for a company to do the plates, then a mill resurfacing company will probably be you best bet, although it may be difficult to find any that are accredited to provide that calibration.
Ryan
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
99.5% - Quality Inspection Requirement (Power / Sample Size Selection) equesnel Inspection and Test, Sampling and Related Topics 2 26th July 2009 09:25 AM
Hospital Grade and Medical Grade power cord differences? luloo117117 Hospitals & Health Care Providers - Best Practices and ISO 9001 2 5th March 2009 09:18 AM
Advice on maintaining surface plate condition - Starrett crystal pink surface plate apestate Inspection and Test, Sampling and Related Topics 14 4th July 2006 11:37 AM
Components "Commercial grade" vs "Automotive grade" betgza Inspection and Test, Sampling and Related Topics 7 8th February 2006 04:40 PM
Grade 3 accuracy requirement for gage block jim Zilla ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 25th April 2001 07:24 PM
The time now is 06:31 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
