The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
4:1 Test Accuracy Ratio (TAR) or Stated Measurement Uncertainty (MU)
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
ansi z540, measurement uncertainty (mu), test uncertainty ratio, iso 17025 - testing and calibration laboratories
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  Post Number #1
Old 26th May 2010, 04:22 PM
tmklaves
Please Help! 4:1 Test Accuracy Ratio (TAR) or Stated Measurement Uncertainty (MU)
These questions pertain to comparing standards ANSI/NCSL Z540-1-1994 to ISO 17025. First, I am confused if ANSI/NCSL Z540-1-1994 specifies a "Test Uncertainty Ratio" or a "Test Accuracy Ratio" of 4:1 instead of a stated measurement uncertainty. Also, does ISO 17025 make the same distinction?
Sponsored Links
  Post Number #2
Old 26th May 2010, 09:56 PM
BradM's Avatar
BradM
Re: 4:1 Test Accuracy Ratio or Stated Measurement Uncertainty
Hello there!
You pose a good, and very common question. If you may, take a look at this thread:
http://elsmar.com/Forums/showthread.php?t=24451
There is a link to a Transcat document in Benjamin's post that does a pretty good job clarifying the different ratios.
In short, if you are calculating uncertainties, then you would use a test uncertainty ratio. If you are using accuracies, then use an accuracy ratio.
To utilize a Test Uncertainty Ratio, you will need to calculate the stated uncertainties to determine the given ratio.
Not sure if any of that made sense.
Thank You to BradM for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 27th May 2010, 07:54 AM
tmklaves
Thanks for the link, the TransCat document does a good job explaining the difference between TUR and TAR and how to properly us the TUR ratio. However, I still question if ANSI/NCSL Z540-1-1994 is referring to TAR or TUR. The following quote is form paragraph 10.2.b of ANSI/NCSL Z540-1-1994 regarding calibration requirements:
"The laboratory shall ensure that teh calibration uncertainties are sifficiently small so that the adequecy of the measurement is not affect. Well defined and documented measurement assurance techniques or uncertainty analysis may be used to verify the adequacy of the measurement process. If such techniques or analyses are not used, then the collective uncertainty of the measurement standard shall not exceed 25% of the accepted tolerance"
The first option calls for a workup of the uncertainty budget for the reference standard, the second option says if this is not available, the collective uncertainty should be 25% of the tolerance. However, to know the collective uncertainty, you must also calculate uncertainty budget. I don't get the difference.
Tom K
  Post Number #4
Old 4th October 2010, 06:41 PM
howste's Avatar
howste
In Reply to Parent Post by tmklaves View Post
Tom K
Does anyone have an answer for Tom's question? I find myself coming to the same conclusion he did...
  Post Number #5
Old 4th October 2010, 09:41 PM
BradM's Avatar
BradM
Calculating uncertainty is the way to go. If you calculate the collective uncertainty of your measurement system, it should be 25% of the Unit Under Test accuracy.
If you have not calculated the collective uncertainty, then the measurement accuracy of your standard has to be 25% of the Unit Under Test accuracy.
Did that answer the question?
  Post Number #6
Old 4th October 2010, 09:59 PM
howste's Avatar
howste
Let's assume that the collective uncertainty of the measurement system hasn't been calculated. If a gage block or mass standard (weight) is used for the calibration, what would be the measurement accuracy of the standard? There are no divisions or increments to be read on the standard, so would the "measurement accuracy" be the accuracy of the instrument used to calibrate the standard?
  Post Number #7
Old 5th October 2010, 01:21 AM
George Weiss
I still remember calibrating to the Z540.1:1994 back in the 1995-2000 years.
I had a 1% spec on a hand held meter, and a calibrator which had a spec of less than 0.25%, which was a TAR of better than 4:1, and so I just went forward with the calibration. I was audited by a NAVY auditor once, and that is all he wanted to see. 4:1 TAR accuracy on the standard/DUT. Now we have Uncertainties, and devisors, and multipliers. OMG……….guard bands……….
Even the NEW Z540.3:2006 says 4:1 TAR/TUR, and forget false-pass risk analysis for that particular test.
  Post Number #8
Old 5th October 2010, 09:30 AM
BradM's Avatar
BradM
In Reply to Parent Post by howste View Post
Good question. The two standards that you mentioned (gage blocks and mass standards) are calibrated to industry standard specifications (or grades); classes and grades.
Mass standards classifications can be found at Rice Lake and Troemner. Gauge blocks are listed under ASME B89.1.9-2002, for one.
I know you know some of this... but just for explanation....
The classifications of each go along with the construction of them. You don't buy a set of inexpensive Class 3 weights, and then calibrate them to an Ultra Class tolerance. Same with gauge blocks. So you send them to the competent vendor, and have them calibrate both, providing actual data and such.
Depending on your application, the blocks and weights should be four times more accurate that what you are verifying.
Think of it like this.... you have a standard thermometer (N.I.S.T traceable of course), and a well constructed ice bath. You're calibrating some thermometers. The ice bath... is.... .01C. It does not have to indicate anything; where the standard thermometer will. Same with blocks and weights. The gauge block (if properly certified), is 1 inch. Period. So the device should produce 1.000 inch or whatever.
A lot of babbling there. Not sure I helped or not.
Thanks to BradM for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Test Uncertainty Ratio TUR (UUT Tolerance / STD Uncertainty) Question jfgunn General Measurement Device and Calibration Topics 8 15th February 2013 03:26 PM
TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? ScottBP Measurement Uncertainty (MU) 2 25th March 2009 10:04 AM
TAR (test accuracy ratio) vs. TUR (test uncertainty ratio) - The difference is..? Charles Wathen Measurement Uncertainty (MU) 2 20th March 2004 06:25 PM
Differences between Test Accuracy Ratio (TAR) and Test Uncertainty Ratio (TUR) ralutz Measurement Uncertainty (MU) 3 29th September 2000 09:40 AM
Measurement Risk Management - 4:1 Test Accuracy Ratio Guardband Mike Czech General Measurement Device and Calibration Topics 1 20th December 1999 12:39 PM
The time now is 04:22 AM. All times are GMT -4.
NOTE: This forum uses "Cookies"
