Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd January 2002, 08:14 PM
Henriqued Henriqued is offline
Involved - Posts
Registration Date: Mar 2001
Karma Power: 36
Henriqued has less than 100 Karma points so far.
Please Help! Defects and Nonconformities - Railroad maintenance company
I have a problem with a (railroad) maintenance company:
Does a defect which is noticed later after a normal maintenance service, during a general monitoring/inspection activity, need to be approached as a nonconformity, and a nonconformity record (a CAR form) filled?
(E.g., a defect noticed in a railways junction or a bolt not well tightened).
What about if the causes are due to the normal use of the material/equipment; is it still considered a nonconformity requiring a CA?
Your views on this will be most welcomed.
Thank you.
Henrique Silva
Sponsored Links
Old 24th January 2002, 05:51 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
My first thoughts are yes - a CA should be raised.
If a fault is found after the maintenance activity, that should have been picked up by that activity, then the system has failed (with potentially disasterous consequences ??).
Also if a fault is found due to normal wear and tear in between maintenance activities then the frequency should be increased, or the maintenance activity looked at to see if it can be improved - so again a CA would be a good way to progress this and make sure it happens.
Sponsored Links
Old 24th January 2002, 07:00 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I agree with the exception of the normal wear and tear situation which becomes a preventive action. But, as is pointed out above, many use their corrective action system to address preventive actions.
Old 24th January 2002, 08:23 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
To the first a definite CA, one of the things CAs do are to protect you, as a company in a sense. To the second could go both ways as a PA (in a trend sense) may need to do PM more often. As a comment, I feel if you have a trend you have a problem and a CA. As a CA are the trains running at the designated rail limit?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Determining Defects per Opportunity/AQL - Vehicle & Equipment Repair and Maintenance ProStreet AQL - Acceptable Quality Level 1 23rd November 2007 10:15 AM
Excluding 7.5.2 - Warranty Repairs - Vehicles Maintenance Company samer ISO 9001 - Quality Management Systems Standard 4 4th May 2006 06:21 AM
Machine failure defects due to no/poor maintenance for FMEA - Looking for examples Bartosz Murawski FMEA and Control Plans 6 26th May 2005 02:58 PM
Zero Defects & Taguchi Loss Function - ISO 9000 and the Zero Defects Philosophy Marc Quality Tools, Improvement and Analysis 32 25th April 2004 10:26 AM
SPC (minimizing defects) Vs Poka Yoke (zeroing out defects) Marloun SPC Monitoring and Statistical Analysis Techniques 3 3rd May 2000 07:05 PM
The time now is 08:14 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
