A Peachfarm Internet Property
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
Calibration of Angular Graduations/Protractor
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
polarization of lenses, inspection methods and plans, measurement and monitoring and test devices, calibration (general topics)
Reply
  Post Number #1
Old 10th June 2010, 11:13 AM
TWIBlogger's Avatar
TWIBlogger
Please Help! Calibration of Angular Graduations/Protractor
I am designing a simple inspection device for checking polarization of lenses. Basically, I need to check horizontal position, vertical position and then any polarizing shift +/- 5deg from vertical position.
So, the lens fixture has to be horizontal, loading of the lens must be horizontal. The rotational measuring device is done by hand, with a straight line indicating horizontal and vertical positions against a "printout" of a protractor.
My question is how to calibrate this device? Assuming I fixture everything at 90 degrees relative to each other, is there a need for calibration, or is this sort of a verification - like checking a tape measure?
The real murky part in my mind is checking the accuracy of +/- 5deg
Thanks for your help, Bryan
Sponsored Links
  Post Number #2
Old 11th June 2010, 03:24 AM
Stijloor's Avatar
Stijloor
Re: Calibration of Angular Gradations/Protractor
In Reply to Parent Post by TWIBlogger View Post
Bryan
Can someone help Bryan with this?
Thank you.
Stijloor.
Sponsored Links
  Post Number #3
Old 16th June 2010, 09:25 AM
Jerry Eldred's Avatar
Jerry Eldred
Since this appears to impact measurement of product quality, I would recommend finding a way to calibrate it; or at least documenting reasoning why, if it does not end up requiring calibration. Here are some details that I would research if I had to determine if or how to calibrate it.
Look at all the variables and how their accuracies impact product quality. I am ignorant of this type of process, but from your posting, maybe review the angular movement - does the absolute accuracy of the angle impact quality, or is it relative. IF it is relative, how do you maintain repeatability of the angle (if you had to build a second fixture. Does the thickness or flatness, size or shape of the lens impact quality? Also, perhaps calibrating the protractor may provide some traceability.
Or is there a "Golden Unit" that could be used to verify the fixture. If you use a "Golden Unit", how is that unit verified to meet specifications. The method used to verify the "Golden Unit" meets specifications may need to have calibrated instruments. Or, is this fixture the way you finally measure/monitor product specifications?
I know this may not answer your question; but as metrology engineer, these are some of the kinds of questions I might pose when assisting a customer in determing when or where to calibrate. Hope it is of some help.
Thank You to Jerry Eldred for your informative Post and/or Attachment!
  Post Number #4
Old 17th June 2010, 09:35 AM
TWIBlogger's Avatar
TWIBlogger
Thanks Jerry,
We just had a quick powwow on this and the question of calibration is on everyone's mind. It seems that, as you suggest, the question is less about calibration and more about repeatability. It isn't possible to calibrate the angular markings, the action will be more of a verification: are the meridians on the angular protractor legible, intact, easy to read, etc.
Thanks for you suggestions, if anyone else can chime in I'd appreciate it.
  Post Number #5
Old 17th June 2010, 09:51 AM
bobdoering's Avatar
bobdoering
Thanks Jerry,
There has been some tossing about of definitions between the term calibration and verification. Yes, you can perform calibration on a protractor. A device does not have to be "adjustable" to be calibrated - adjustment is just an option for a device that is out of calibration. Of course the other option is to remove the gage from the system. Calibration itself is comparison to a standard - 4 to 10 times more accurate - to ensure the device measures to the standard within its specifications. All other functions - readability, damage, etc. are also handy to do at the time you are performing calibration.
Don't let parsing of the terms dilute the fact: compare to a standard that is more accurate and traceable.
Thanks to bobdoering for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage RGohil General Measurement Device and Calibration Topics 10 4th January 2012 12:25 AM
Flow Meter Calibration - Outside Calibration Service vs. In-House Calibration CDISO General Measurement Device and Calibration Topics 3 1st November 2011 08:00 PM
Gage pin calibration - Actual calibration readings required on the calibration cert mfr11 General Measurement Device and Calibration Topics 3 9th April 2009 12:58 PM
Bevel Protractor - Which one to choose? MysterHK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1 28th April 2008 11:27 AM
Calibration Outsourcing vs. In House Calibration - Outrageous Costs of Calibration Cathy Everett General Measurement Device and Calibration Topics 28 5th September 2006 12:50 AM
The time now is 04:09 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
