Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th December 1998, 10:27 PM
Lyndon Diong
Unregistered Guest
Posts: n/a
Question What is defined as a Laboratory? Supplier Laboratory Requirements - Clause 4.10.6
What is defined as a laboratory? We do titration in a lab to the find the acidity of a chemical. Does this mean that 4.10.6 applies? We can easily perform the titration outside a lab too.
We calibrate thermometers using the comparison method. A std thermocouple and the thermocouple for calibration are both used to measure the heater block temp. The results are compared. This is done at room temp and humidity. Is this acceptable?
Sponsored Links
Old 15th December 1998, 02:35 AM
Ganesh Chidambarakrishnan
Unregistered Guest
Posts: n/a
Default
Laboratory is not a place bound by four walls, but a place where testing is performed. If titration is performed outside the four walls of the place called "laboratory", the place where titration is doen becomes the laboratory as per QS9000 definition.
Calibrating a thermocouple or thermometer using a standard thermocouple is acceptable, as long as "traceability to national or international standards" is maintained. Necessary systems to ensure that the said calibration is done corretcly must be documented.
Sponsored Links
Old 4th January 1999, 12:49 PM
Dan Indish
Unregistered Guest
Posts: n/a
Default
Note AIAG interpretations at:
http://www.aiag.org/quality/labs.html
Old 7th January 1999, 05:51 PM
Joe Ptak
Unregistered Guest
Posts: n/a
Default More 4.10.6 Supplier Lab Requirements
Thanks Dan for posting the AIAG link, that helps to clear things up a little. Additionally, I recently attended a 3rd edition upgrade seminar and was advised that 4.10.6 is concerned about labs that do product development, failure analysis, specialized tests that require lab techs, or in other words, tests that are clearly OFF-LINE and not a normal function of in-process testing.
And so, I have another applicability question for the board. We are a metal stamper and we perform traditional in-process dimensional tests by the operator and a QC auditor, also rockwell tests, plating thickness tests, etc. Pretty basic stuff. We also have a CMM which we use to perform more complex dimensionsal testing and calibration services. It is our opinion that the CMM is really the only equipment performing "tests" that would need to be covered by 4.10.6, all the other are in-process tests.
Am I interpreting all of this info correctly or should our scope be expanded to cover other areas? Any info would be greatly appreciated.
Old 8th January 1999, 09:28 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
Default
This is another QS gray area to me. I think there is some merit to the opinion that this requirement applies only to off-line lab tests. However, unless my eyes deceive me (which happens all too often), I don't see this in the text. We have, what I consider, in-line lab tests that operate on a sampling basis. IMHO, this requirement applies to those tests. Off-line, to me, does not just include physical location of the lab facility, but also that production is not necessarily waiting for the results to allow the product to proceed to the next step.
Old 9th January 1999, 09:00 AM
Bryon C Simmons
Unregistered Guest
Posts: n/a
Default
Gotta agree with Roger on this one...isnt your rockwell testing (which I have some limited experience with)a form of failure analysis? It surely is non-destructive testing....which is gonna fall into the 4.10.6 thing. I think you will have a hard time convincing your registrar that your testing scope falls outside the requirement as it is stated. My advice is to keep it simple, and be pragmatic about it....
Good luck
Old 21st March 2001, 10:40 AM
Mkrickel
Unregistered Guest
Posts: n/a
Question Supplier Lab Requirements
Could someone please send me a sample of a Lab scope and related procedures. I am almost complete with our documentation system, but am stuck on this one. I would greatly appreciate it.
Thankyou
MK
e-mail Mkri529506@aol.com
Old 22nd March 2001, 11:02 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
You might want to start out reading:
http://Elsmar.com/ubb/Forum1/HTML/000088.html
http://Elsmar.com/ubb/Forum1/HTML/000131.html
http://Elsmar.com/ubb/Forum1/HTML/000247.html
to start out.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
7.6.3.1 Internal Laboratory - Are "Technical requirements" defined somehow? jawatts ISO/TS 16949 - International Automotive Quality Systems Standard 2 8th November 2005 07:32 PM
QS-9000 Section 4.10.6 Supplier Laboratory Requirement Michael Busha QS-9000 - American Automotive Manufacturers Standard 4 20th April 2003 01:32 PM
Supplier Laboratory Requirements 4.10.6 Linda Jurasin QS-9000 - American Automotive Manufacturers Standard 38 11th July 2002 04:51 AM
Supplier Laboratory Requirements - 4.10.6 - Requirements for an In-House Laboratory mniem QS-9000 - American Automotive Manufacturers Standard 4 1st March 2000 04:02 AM
Do we really need to meet the Supplier Laboratory Requirements (4.10.6)? mibusha ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 22nd December 1999 06:29 PM
The time now is 06:03 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
