Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 4th February 2002, 08:33 PM
omolina omolina is offline
Registration Date: Nov 1998
Karma Power: 45
omolina has less than 100 Karma points so far.
Question How can you deploy an MSA study on a visual inspection appearance variable
Hi. I have a question. Maybe someone outthere can answer.
Clause 4.11 states that MSA studies has to be deployed for all measure systems documented in control plans. This is done using the Evaluation/Measure Technique column in the Control Plan Format.
How can you deploy a MSA study on a visual inspected appearance variable ? (In the APQP / CP booklet there is an example of this kind of variables).
What about go / no go issues ? Are they similar ?.
Thanks for your comments ...
O. MOLINA
Sponsored Links
Old 5th February 2002, 08:26 AM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default
It would depend on what the visual inspection is for. If your inspection evaluation is pass/fail, then you could use the attribute MSA. If your inspection was incremental, use the variable.
We have a process of counting coated threads to control a process. The operator records the threads counted as a numerical value and SPC charts are kept on those results. We list the control on the CP and do a MSA. So far we have not had a problem with our PPAPs or with an auditor.
Dave
Sponsored Links
Old 25th August 2005, 07:09 AM
Robert Molenberghs Robert Molenberghs is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jul 2005
Karma Power: 18
Robert Molenberghs has less than 100 Karma points so far.
Default
Hi Molina
You should perform an attributive MSA study. See IATF MSA Reference Manual (old QS-9000 manual)
Robert
Old 25th August 2005, 07:41 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
For attribute R&R you can see more here
Go - No Go (Attribute) Gage R&R (Repeatibility and Reproducibility) or search for attribute
You can’t fake quality any more than you can fake a good meal.
* William S. Burroughs
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
MSA and Control Plan - Satisfying Visual Inspection Requirements fregando ISO/TS 16949 - International Automotive Quality Systems Standard 5 19th August 2009 04:51 PM
Capability Study on Attribute Data? Visual Inspection Barahir Capability, Accuracy and Stability - Process, Machine, etc. 6 6th April 2009 10:03 AM
Visual Inspection Not 100% Effective - How to Improve Visual Inspection jkittle Quality Tools, Improvement and Analysis 48 19th March 2009 06:16 AM
MSA - Is an attribute study required for visual inspection? atchukorn Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 19th June 2006 07:33 AM
MSA Study for tensile tester - Its difficult to do an MSA study on a destructive test mattye Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 28th December 2005 03:57 AM
The time now is 02:40 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
