Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
4th July 2010, 02:32 PM
Involved in Discussions
Registration Date: May 2010
Thanks Given to Others: 18
Karma Power: 15 Karma: 15
Process Map of Document Control - Review wanted (Visio)
Could I please ask for some kind people to have a look at my process map for Document Control please. It is based on a template that I got from the site, and revamped to enhance the process to suit the company and people I work with.
Reviews are very much welcome
4th July 2010, 10:50 PM
Cross Forum Moderator
Registration Date: Mar 2008
Thanks Given to Others: 1,228
Karma Power: 435
Re: Process Map of Document Control - Review wanted (Visio)
In Reply to Parent Post by starfish
It will help many to see, review and comment if you can attach same as an .xls file or a .pdf
Best Regards...
Somashekar BV, INDIA
5th July 2010, 06:31 AM
Appreciated Member
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 83
Some initial thoughts...
What is the purpose of the diagram? Who will use it? Does it give them the information they require in the best format? Can they easily find the parts that affect them?
What triggers the process (it is not clear who can suggest a change)?
"Document Creator": is this a person or role? (If a role, the person may not have been the creator)
Not sure that I see some of the "Inputs" as anything other than "useful notes".
A number of the "Inputs" and "Outputs" are tasks, which I would expect to see in the middle column.
Passive tense is to be avoided!
Who is the "Author"?
I had a go at the first part (as attached) - I think that it helps to make the steps clearer, and also highlights who is responsible (and who else needs to be involved) for each step - and makes it easier to fix if it is wrong!
Hope this helps.
Peter
"Insight through Clarity"
Thanks to Peter Fraser for your informative Post and/or Attachment!
5th July 2010, 08:06 AM
Hi Peter
Many thanks for your comments and the suggested format, the flow chart is to be included in a document control procedure that specifically relates to Adminstration staff that are not familar with DC steps, and I wanted to show the process in a step by step approach, and able to reference the procedure when required for more details. Your suggested format was a good help, are you able to send me this so I can work with it? Thank you
5th July 2010, 08:56 AM
Appreciated Member
Karma Power: 83
You can set it up in Excel (or even Word) - but it gets unwieldy if you are defining a number of processes this way. We use our own software (I'll send you a private email with more details)
PS might a flowchart in this detail not be able to replace the procedure?
Peter
6th July 2010, 01:58 PM
Shy Poster (1 to 5 Posts)
Karma Power: 13 Karma: 10
Two things to share. First, to share with others who may not have Visio installed, just copy the entire drawing and paste it to a PowerPoint slide. Or do the same thing to a properly oriented Word doc. Secondly, there's always the challenge about how much to include in a flowchart. My opinion is that a flowchart should be a reasonably high level document (somewhat of a aerial view) so that one can see the basic steps. To this add the critical inputs, the approvals, and the end product. If the latter makes the flowchart unweildy, the use the multi-chart approach: one high level flowchart that describes the major steps and supplement each off-page reference with an appropriated deailed flowchart. From a high-level perspective, looks like you have identified the critical steps.
23rd July 2012, 04:46 PM
Registration Date: Jul 2012
Karma Power: 4 Karma: 10
Peter. I am in the process to develop a similar project as StarFish. I really liked the flowchart format you sent. You mentioned that this was done using your own software. what software is that. Can you help me?
24th July 2012, 03:53 AM
Appreciated Member
Karma Power: 83
In Reply to Parent Post by BTRAP
Glad you like it - it is almost a standard format in UK North Sea oil and gas (they used Excel and Powerpoint about 20 years ago, but then realised that it was difficult to maintain an integrated set of process descriptions), but not well known in other sectors.
See http://www.promanade.co.uk/basic for the edition that creates printed (or pdf) output, and http://www.promanade.co.uk/our-software for the version that generates a complete electronic (html) management system.
Let me know if you want more details.
Peter
Forum Posting Settings
