Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
13th July 2010, 10:53 AM
Cross Forum Moderator
Registration Date: Mar 2008
Thanks Given to Others: 1,201
Karma Power: 430
Can a shaving razor blade be classified as a medical device
By any logic could a shaving razor blade be classified as a medical device ... ?
Best Regards...
Somashekar BV, INDIA
13th July 2010, 04:58 PM
Appreciated Information Resource
Registration Date: Aug 2008
Thanks Given to Others: 1,035
Karma Power: 350
Re: Can a shaving razor blade be classified as a medical device
Yes. Shaving is essential before many surgical procedures, to allow effective disinfection of the skin at the surgical site. Thus shaving falls within the "preventative" definition-elements of the MDD and the US FDA's FD&C Act.
Thanks to MIREGMGR for your informative Post and/or Attachment!
13th July 2010, 08:43 PM
Glad to help, if I can
Registration Date: Mar 2010
Thanks Given to Others: 1,308
Karma Power: 159
In Reply to Parent Post by MIREGMGR
I think it actually depends on the indication for use as specified by the manufacturer. If the razor is indicated by the manufacturer to be used for surgery prepartion or anything similar then yes, it should be considered a medical device. However, a plain home-use razor, such as the type used for regular facial shaving, not specified by the manufacturer for any medical-related use, should not necessarily be considered a medical device. True, even the latter can be used in medical settings, but medical regulation places significant emphasis on intended use as assigned by the manufacturer, so as long as it's not indicated for medical use the manufacturer should enjoy the benefit of doubt. I think that with a lack of explicit indication for use (as probably is the case with many home-use razors) the responsibility for any medical use, if done, falls on the medical practitioner / insititute.
Cheers,
Ronen.
Thanks to Ronen E for your informative Post and/or Attachment!
15th July 2010, 09:18 AM
Appreciated Member
Registration Date: Oct 2004
Thanks Given to Others: 30
Karma Power: 71
I would agree with Ronen. Also, razor blades can be (or have been in the past to my knowledge) used as scalpel blades (those old Schick injector razors with the single-edged blades...exact same blades, just a different dispenser.
Ron S Rompen
Goju Ryu
Kitchener, Ontario
Do other dogs think that poodles are members of some strange religious cult?
15th July 2010, 09:26 AM
Karma Power: 350
The question was "could". The answer to that is "yes".
If the question was "is", the answer would be "maybe, depending".
Precise language matters.
15th July 2010, 10:14 AM
Registration Date: Nov 2007
Thanks Given to Others: 134
Karma Power: 85 Karma: 3030
In Reply to Parent Post by somashekar
The answer does appear to be definitely 'yes'. Firstly there is a UMDNS reference number - 16580 for a 'Razor, skin prep' - so not necessarily the blade. But there are also a number of references on the GMDN site, including just 'Razor blade'.
Its Medical Device Definition being:
"A cutting device with an extremely sharp cutting edge that is inserted into a reusable razor and provides the cutting edge. It comes in various designs, traditionally with two cutting edges (one on either side of the blade's width). Though this device is reusable and designed to be used until blunted, it would be for single-patient use only to reduce the risk of cross-infection. Some types can be purposely used for breaking into smaller segments to be used like a scalpel to cut tissue, e.g., during certain ophthalmologic surgical procedures. This is a reusable device."
Steve
Thanks to SteveK for your informative Post and/or Attachment!
Forum Posting Settings
