Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th February 2002, 11:39 AM
SteveTIB SteveTIB is offline
SteveTIB
Registration Date: Feb 2002
Thanks Given to Others: 6
Karma Power: 32
SteveTIB has less than 100 Karma points so far.
Please Help! System Reliability Projections using the Series Probability Formula
I am trying to calculate our system "reliablity projection" using the series probability formula, Rs=(Ra)(Rb)(Rc).... I have received performance data from suppliers, e.g., 1,00,000 hrs or 1,000,000 cycles, and calculated a failure rate (lambda) based on Chi Square (X^2) where:
lambda=X^2(1-a)/2t
a=1-percent confidence desired (.05)
r= number of failures = (0)
dof=degrees of freedom= 2(r+1)
t= device hours= supplier data
I want to calculate Reliability from the reliability equation: R=e^(-lambda(T)), where "T" is a specified interval of time, but don't know:
1) Is there an industry standard definition for "T", e.g., machine life, shift duration, preventive maintenance interval, etc., or can I make and state an assumption?
2) Is this even a statistically valid way to calculate a "reliability projection"?
Sponsored Links
Old 3rd April 2002, 11:36 AM
Zanzi Zanzi is offline
Registration Date: Sep 2001
Karma Power: 34
Zanzi has less than 100 Karma points so far.
Default
Steve,
I have always worked on the premise that 'T' relates to a period of time that is defined as the shift period. The standard period I use is 8 hours (unless otherwise defined).
If you are not sure you could clarify the T value with your customer or define the rationale for yourselves always using 8 hours (or whatever period you chose). Basically as these figures are predictions simplify quantify you assumptions, e.g. shift period etc.
With regards the calculation, it is statistically valid in terms of calculating the reliability over time, however I would typically calculate lamda as the failure rate, using the formula -
Total number of equipment failures / operating time = 1/MTBF
I hope that this helps and good luck - I'm currently trying to fight my way though reliability predictions as we speak so it woudl be good to know how you get on - I have no end of trouble getting reliability information from suppliers, so any ideas you have would be appreciated.
Sponsored Links
Old 16th April 2002, 03:04 PM
SteveTIB
Karma Power: 32
Default Reliability Projections - Supplier Data
Zanzi,
Thanks for your input. We did use a self defined mission/shift time "T" to make our calculations. I received a response on the SAE discussion site, the G-11 Reliability, Maintainability, Supportability and Logistics Division discussion forum confirming, as you did, this method.
Regarding your problem of getting supplier data, I wish I had an answer. Getting supplier data was excruciatingly painful and provided very little value and return on our "investment".
I am currently working on defining how we will make reliability projections so that we don't have to do this time consuming exercise that adds no value to our product, either for us or our customer.
Wish I had more to offer.
Steve
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) yepezyepez Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 11th March 2008 01:59 PM
2 Reliability Problems - Have Answers, Need Formula Jgutierrez Reliability Analysis - Predictions, Testing and Standards 7 8th September 2006 07:53 AM
Calculating Series System Reliability and Reliability for Each Individual Component jag53 Reliability Analysis - Predictions, Testing and Standards 4 17th April 2006 09:20 AM
Reliability Questions - System vs Component Reliability - Target Values jkittle Reliability Analysis - Predictions, Testing and Standards 11 28th January 2006 05:03 PM
Probability problem - The probability of picking 4 bad brakes out of 500 anoop_mahajan Reliability Analysis - Predictions, Testing and Standards 3 16th January 2006 02:24 PM
The time now is 08:56 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
