Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
16th July 2010, 12:28 PM
Involved in Discussions
Registration Date: Jan 2007
Thanks Given to Others: 1
Karma Power: 27 Karma: 10
Angularity - When angularity is called out should it be to a basic dimension
Simple question I am having a hard time finding a concrete answer on.
When angularity is called out, should the angle it refers to always be a basic dimension? Wouldn't the angularity callout BE the tolerance for the angle.
I have a customer print that has angularity only as a callout (no form tolerance) and a regular (non-basic) angle callout. My understanding is this is not correct.
Appreciate any help.
16th July 2010, 01:03 PM
per ASME Y14.5M-1994
Registration Date: Feb 2005
Thanks Given to Others: 5
Karma Power: 102
Re: Angularity
You are right that this is not correct. Either you are measuring the angle(traditional result in °) or the form error from the basic angle. (GD&T angularity)
Thanks to True Position for your informative Post and/or Attachment!
16th July 2010, 03:56 PM
Appreciated Information Resource
Registration Date: Aug 2007
Thanks Given to Others: 35
Karma Power: 72
Re: Angularity
In Reply to Parent Post by jfbock
Using both ASME Y14.5M-94 and now th3 2009 edition, the angle must be shown in a basic dimension. The tolerance in the feature control frame is tolerance for this angle. If the drawing reflects the angle without being a basic dimension, then the drawing is incorrect.
By the way, angles on surfaces in GD&T also include flatness while angles in holes include straightness.
Dave DeLong
Thank You to David DeLong for your informative Post and/or Attachment!
16th July 2010, 08:19 PM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
Re: Angularity - When angularity is called out should it be to a basic dimension
TP and David have answered the "basic" question, but I'll add that whenever you encounter ambiguous specifications it's best to ask the customer what the intent is. If there's no reference to any GD&T standard on the drawing, it means that the designer can use the symbols to mean whatever she wants them to. Even when the standard is referenced, designers will often demonstrate their failure to understand it.
We aim to please. You aim too, please.
16th July 2010, 08:39 PM
Registration Date: May 2003
Thanks Given to Others: 2,947
Karma Power: 1429
In Reply to Parent Post by Jim Wynne
How true this is! I often see drawings with mixed symbols from 1982 and 1994 GD&T standards.. No standard reference in the title block, so it becomes pure guesswork...
Stijloor.
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Basic Dimension Chaining - Second hole has a basic dimension from the first hole
jfbock |
Inspection, Prints (Drawings), Testing, Sampling and Related Topics |
3 |
19th December 2011 11:11 AM |
Size Dimension and Feature of Size - FOS as subset of a Size Dimension
optomist1 |
5 |
22nd June 2011 08:24 PM |
Basic Dimensions - What are basic dimensions? Why don't they have tolerances?
R. Webb |
Definitions, Acronyms, Abbreviations and Interpretations |
14 |
5th December 2009 02:01 PM |
Angularity or Composite profile - Angularity callout on a recent print
JIMO1972 |
4 |
23rd April 2009 08:54 AM |
Calculating Basic Risk/ Basic on Risk Analysis - Medical device MDD Class II and up
temujin |
ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems |
8 |
23rd May 2007 05:54 PM |
