The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards
Forum Username
Wooden Line
5D and 8D as an option, can it be both or one of them in the system?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
8d problem solving, corrective action (ca)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 29th July 2010, 02:24 AM
YAZIDM's Avatar
YAZIDM
Please Help! 5D and 8D as an option, can it be both or one of them in the system?
Our system just practice 5D as for our Corrective Action record. Since most of the customer asking for 8D, should i remove 5D from the procedure and replace it with 8D or is it possible to have both? My boss is asking can it be both in the procedure since he want the 5D to be used internally.
Sponsored Links
  Post Number #2
Old 29th July 2010, 03:45 AM
qusys
Re: 5D and 8D as an option, can it be both or one of them in the system?
In Reply to Parent Post by YAZIDM View Post
Personally I do not know 5D methodology. Most common is 8D , well known in the automotive industry. This is a standards adopted by mostly company, in order to have a common ground on corrective actions process.
My suggestion is to use 8D methodology also for internal purpose in order to be eventually accustomed to do it in case of external issue.Be also prepared in training the personnel and declare it in the documented procedure.
Sponsored Links
  Post Number #3
Old 29th July 2010, 04:10 AM
JaneB's Avatar
JaneB
What are the elements of your 5D procedure?
If you use both, but your customers ask for the 8D one, how will you ensure that you use the 8D one for them? Is this only iif/when they insist?
  Post Number #4
Old 29th July 2010, 09:13 PM
YAZIDM's Avatar
YAZIDM
Hi Jane / qusys,
Actually this is the first time I saw 5D, fyi, I’m the freshie new guy who taking care the QMS.
Our 5D consist;
D1: Define the Problem
D2: Define & Verify the Root Cause(s)
D3: Identify & Verify Proposed Permanent Corrective Action
D4: Implement Permanent Corrective Action
D5: Action to Prevent Re-occurrence
While for 8D;
D1: Identify Team Member/Roles & Responsibilities
D2. Define the Problem
D3. Implement & Verify Interim Containment Actions(s)
D4. Define & Verify Root Cause(s)
D5. Identify & Verify Proposed Permanent Corrective Action(s)
D6. Implement Permanent Corrective Action(s)
D7. Action(s) to Prevent Re-Occurrence
D8. Communicate Results & Recognize Team
As we all well know, nowadays ALL customers demanding 8D. But my supr. asking me whether is it possible to have them both in the system, reason is 5D for internal use and 8D for external. To me, i will agree with qusys....I’m not sure about this.
The procedure only mentions one report that is 5D. My boss wants them both which is ‘as an option’. My concern is will I face any problem in future especially during audits? I believe it’s explainable as what my boss said, but in term of requirement or possibility or necessary maybe logic? Beside "add-in" 8D as an option, should I amend anything on the procedure? Please review attachment. Were gonna arrange Internal audit this coming sept and ISO audit is soon after that.
thanks in advance
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
File Type: pdf QA,PROC-13-01,MAL EDI 1 Corrective Action_.pdf (54.1 KB, 333 views)
File Type: pdf QA,PROC-13-03,MAL EDI 1 Customer Complain.pdf (134.9 KB, 131 views)
  Post Number #5
Old 29th July 2010, 09:37 PM
Duke Okes
There's nothing wrong with using multiple models, but as some have pointed out, people need to know which to use when.
To me the 5D is simply the 8D without use of a team. Many problems do not require a team.
Thanks to Duke Okes for your informative Post and/or Attachment!
  Post Number #6
Old 29th July 2010, 10:48 PM
harry
................. should i remove 5D from the procedure and replace it with 8D or is it possible to have both?....................
You had literally paint yourself into a corner or tie your own hands. Your procedures shouldn't be that restrictive. It should just mention the use of appropriate problem solving techniques - bearing in mind that the different techniques or methods are useful into different situations.
Thank You to harry for your informative Post and/or Attachment!
  Post Number #7
Old 29th July 2010, 10:50 PM
JaneB's Avatar
JaneB
In Reply to Parent Post by Duke Okes View Post
Excellent advice, with which I agree.
I don't see it as a divide between 'external' and 'internal' use - why should or would it be. Some issues require a team approach, with others it would be overkill.
Key point is to be clear about who decides which approach is to be used when - eg, a manager deciding (NOT someone deciding on the basis of which is 'easiest'.
Thanks to JaneB for your informative Post and/or Attachment!
  Post Number #8
Old 29th July 2010, 11:29 PM
YAZIDM's Avatar
YAZIDM
Duke,
I guess i'll agree with that, not all problem req a team. it does make sense
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Closed or Resolved: Follow thread option ... somashekar Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2 9th March 2013 01:57 AM
Suggestion(s): Option of 'Strikethrough' in the reply somashekar Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5 20th December 2011 02:38 AM
Developing a Spares System - 2-bin Kanban System the best option? soton Lean in Manufacturing and Service Industries 3 18th December 2006 05:56 PM
The time now is 08:15 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
