Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Internal Auditing
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th February 2002, 11:29 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Question Knowledge of test methods in order to conduct an internal audit to ISO 17025?
This is similar to other threads, but could those with some experience tell me if it is necessary to have technical knowledge of test methods in order to conduct an internal audit to ISO17025 ?
Sponsored Links
Old 18th February 2002, 04:02 PM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default MG
I am an approved auditor for the 2pCP lab approval program and I don't have technical knowledge of all the test methods. I do have a lot of experience in lab functions and in a lot of the tests but not all of them.
The lab has to have a test method (procedure) for each of the tests and I can determine if the technician is following the procedure. If the test is determined by a spec or standard, I can evaluate their procedure against the spec.
IMHO you would not need to have technical knowledge to be an internal auditor (if you had it, why wouldn't you be working in the lab?).
Dave
Sponsored Links
Old 19th February 2002, 04:56 AM
Courtesy Access
Karma Power: 80
Default
Thanks Dave
That is what I thought. I have been asked to do an internal audit of our test lab, which is UKAS approved, and the lab manager was saying that it requires a technical appraisal of the actual test methods undertaken. Like you said, I asked if documented test methods existed that I could audit for compliance against (as I am not a test expert), and he said 'not in all cases'.
To my mind this audit requires compliance and effective implementation to ISO17025, not technical evaluation of the tests themselves.
Its a bit like auditing the design requirements of ISO9001 and being expected to technically appraise the design itself !!
Old 8th June 2007, 02:28 AM
Libnani Libnani is offline
Involved in Discussions
Registration Date: Jun 2007
Thanks Given to Others: 24
Karma Power: 11
Libnani has less than 100 Karma points so far.
Default Re: Knowledge of test methods in order to conduct an internal audit to ISO 17025?
I AGREE with you if the test methods are standard one ,
but if the test methods are in- house ones you should
examine if they are validated ,
Otherwise you should evaluate yourself if the tests are
technically appropriate and in this case you should have a huge technical
background in the same area of the tests . (especially in internal audits
where their target is an improvement of the system )
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ISO 17025 Audit check list to conduct horizontal and vertical audits Maria ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 28th August 2009 09:44 AM
Do we have to conduct tests during internal audit of ISO 17025:2005? amanbhai ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 24th April 2007 11:56 AM
How to conduct the first ISO 9001:2000 Internal Audit Mike Hudson Internal Auditing 11 13th March 2007 03:25 AM
To conduct ISO 17025 Internal Audit - Auditor Requirements Elynn ISO 19011 and ALL Auditing Discussions 10 7th December 2006 04:33 PM
ISO 17025 Internal audit - No independent internal auditors amanbhai Internal Auditing 4 28th March 2006 04:14 PM
The time now is 08:09 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
