Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th February 2002, 10:09 PM
tohbin's Avatar
tohbin tohbin is offline
Registered Visitor
Registration Date: Feb 2002
Karma Power: 32
tohbin has less than 100 Karma points so far.
Question Cpk Calculation
We report Cpk monthly for our process. In order to report the Cpk, we must have at least 25 data points on the chart (say Xbar-R chart). But sometimes volume in certain month is so low that we won't be able to get 25 points on the chart. Is it right to calculate Cpk even though my data point is less than 25 or should I get previous month data with the current month in order to make it 25?
Sponsored Links
Old 19th February 2002, 01:26 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
Process Capability calculation is an ongoing thing. If you decide to calculate on the basis of 25 points, at any given point of time, you can take the last 25 points.
Sponsored Links
Old 19th February 2002, 02:39 AM
tohbin's Avatar
Registered Visitor
Karma Power: 32
Default
But if I use the last 25 points which may include points from previous month in the case when I do not have enough points in the present month, would that be reflective of my current month Cpk? Or because it is an ongoing calculation, it doesn't matter as long as I have 25 points?
But then comes the question if I have more than 25 points in the current month, I won't have problem with Cpk calculation. Then, the previous month data will not be included. Isn't this in contrast to the practice above?
Old 19th February 2002, 03:48 AM
Forum Administrator
Karma Power: 90
Default
I do not know what is the reason for reporting Cpk on a 'monthly' basis. What are the chances that you will have exactly 25 subgroups/points in a month? Sometimes you will have less and sometimes more than 25. In my opinion, Cpk should be calculated over a 'horizon' that is independent of calendar days. In your case, the horizon would be last 25 points. With every new subgroup added, you calculate the Cpk based on the last 25 points. This way you will be able to monitor the improvement ( or deterioration) in your Cpk.
Do you calculate new control limits every month?
-Atul
Old 19th February 2002, 04:19 AM
tohbin's Avatar
Registered Visitor
Karma Power: 32
Default
No, I don't calculate control limits every month. The reason for calculating Cpk every month is for the purpose of monitoring the improvement of the process month by month.
Old 19th February 2002, 08:15 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Default
tohbin,
you haven't told us your calc method.
I'm always dubious of how people use x&R charts to calculate other things.
Even computer programs use different calc methods, and these often aren't aligned with the calc method endorsed by the auto manufacturers.
CPK calc methods inlcude:
(1-k)xCp
or
Cp = (USL - LSL)/6xStd.Dev
Cpl = (Mean - LSL)/3xStd.dev
Cpu = (USL-Mean)/3xStd.dev
Cpk = Min(Cpl,Cpu)
or
Cpk is calculated using RBar/d2 or SBar/c4 for Sigma in the denominator of you equation. This calculation for Sigma REQUIRES the process to be in a state of statistical control. If not in control, your calculation of Sigma (and hence Cpk) is useless - it is only valid when in-control.
What are you using?
Aussie Bloke
Old 19th February 2002, 08:33 PM
tohbin's Avatar
Registered Visitor
Karma Power: 32
Default
I'm using the following method.
Cpk = Min(Cpl,Cpu)
Has this got anything to do with data points less than 25 in a month?
Old 20th February 2002, 09:53 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Tohbin,
I had the same problem at a previous company I worked for. Sometimes it would take 3 months to get a sample size of 25.
The method I used was to:
1- Select ten parts from the run,
2- measure the specified dim.,
3- if the average ,+/- the range of the ten parts was within specification I would accept the parts,
4- if not, 100% inspect the lot back to the last point that the parts were accepted.
This metod was acceptable to our auditors and to our big 3 customers.
You might also find this method in the Juran Handbook.
Additional Comment:
I did not read your second response.
If what you want is to report Cpk, then report the figures that you have with the way the process is run. If you haven't run for a mth, then report the same figures as the previous month.
Remember Cpk is on-going over time for processes that are in control. For it to be an efective method of reporting, the data should be gathered from a continous running lot.
Sam Goody
Reply
Bookmarks
Tags
cpk, low volume production, spc
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Implementation of TS 16949 for Low Volume Production Ramatein ISO/TS 16949 - International Automotive Quality Systems Standard 2 30th September 2009 07:40 AM
Supplier Rating System - Weighting low volume suppliers vs. high volume suppliers fcardillo Supplier Quality Assurance and other Supplier Issues 2 2nd May 2008 08:05 AM
PPM (Parts Per Million) for Low Volume Production DavidB Quality Tools, Improvement and Analysis 1 18th May 2007 08:23 AM
Low Volume Manufacturing - What is Low Volume Manufacturing? Ady12 Definitions, Acronyms, Abbreviations and Interpretations 9 5th September 2006 07:40 PM
Cpk calculation for short runs - Manufacturing FFC (flexible flat cable) rikkyyee Capability, Accuracy and Stability - Process, Machine, etc. 3 14th September 2002 03:30 PM
The time now is 12:46 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
