Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
11th August 2010, 04:37 PM
Getting Involved (6 to 9 Posts)
Registration Date: Aug 2010
Thanks Given to Others: 1
Karma Power: 12 Karma: 10
Post Market Surveillance Guidelines or examples of procedures
I am in the search of some info and guidelines for Post Market Serveillance. I am wondering if I need to have a specific procedure on a plan for PMS. Any guidelines or examples of procedures would be very helpfull!
Thank you,
Emily
11th August 2010, 05:41 PM
Joanne
Registration Date: May 2009
Thanks Given to Others: 61
Karma Power: 42
Re: Post Market Surveillance
I've sent you a link to the relevant info for the US.
There are other specific requirements you need for other countries.
Where are you selling?
11th August 2010, 08:34 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,456
Karma Power: 400
In Reply to Parent Post by J0anne
<snip> I've sent you a link to the relevant info for the US. <snip>
If you put the link in a post like this: site (dot) com we'll make it into an active link. After your 5th post you will be able to post links in posts. I apologise for the inconvenience. It's a spam prevention method we use here.
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
12th August 2010, 02:40 AM
Forum Administrator
Registration Date: Dec 2005
Thanks Given to Others: 1,471
Karma Power: 400
Re: Post Market Surveillance Guidelines or examples of procedures
In Reply to Parent Post by EmbTech
Thank you,
Emily
Hi Emily,
Welcome to the Cove
Since you are in the US, I provide you the links of FDA -
522 Postmarket Surveillance Studies – Frequently Asked Questions (FAQs)
Postmarket Surveillance Under 522 of the Federal Food, Drug and Cosmetic Act
21 CFR Part 822
Hope this will be helpful for you - pl come back if you have more questions
Well done is better than well said - Benjamin Franklin
Reason: added 21 CFR Part 822 reference
12th August 2010, 02:56 AM
Appreciated Information Resource
Registration Date: Jan 2005
Thanks Given to Others: 66
Karma Power: 52
Here are some resources.
Path to Notified Body public documents:
http://www.team-nb.org/index.php?opt...d=17&Itemid=38
The attached GHTF documents are more current than the attached MEDDEV documents.
From the European perspective, it is very clear that PMCFU is a subset of Post Market Surveillance. The latest European Medical Device Directives (MDD Annex X for example) mentions that if you are not planning to do PMCFU it must be "duly justified" whereas there is no getting out of doing Post Market Surveillance if you are following MDD Annex II (Full QA System) approach. MDD Annex X says:
The clinical evaluation and its documentation must be actively updated
with data obtained from the post-market surveillance. Where post-market
clinical follow-up as part of the post-market surveillance plan for the
device is not deemed necessary, this must be duly justified and documented.
Hope this helps.
Sam Lazzara
Reason: Activated link.
Thank You to Sam Lazzara for your informative Post and/or Attachment!
12th August 2010, 05:51 AM
Forum Administrator
Karma Power: 400
Thanks Sam - this info is very useful !
21st October 2010, 02:35 AM
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2005
Karma Power: 31 Karma: 10
Thanks Ajith - these links asnwered several of my questions regarding PMS for med devices.
27th February 2012, 06:09 AM
Involved in Discussions
Registration Date: Jul 2010
Karma Power: 13 Karma: 15
Hi Guys
I need to distribute a PMS document would anyone have a PMS formet?
Forum Posting Settings
