Elsmar Cove Quality and Medical Device Discussions
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > Aviation, Space and Defense Standards and Requirements > AS9100, Nadcap and related Aerospace Standards and Requirements
Forum Username
Wooden Line
Configuration Management - AS9100 Rev B or C
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
7.3.1 - design and development planning, configuration management, flowcharts, machine shop, small companies (small businesses), as9100 - aerospace quality management systems, procedures (general)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 11th August 2010, 05:08 PM
Mbarr
Please Help! Configuration Management - AS9100 Rev B or C
My husband and I have a small machine shop. We've spent the last year training and getting ready for AS9100 certification and are lined up to undergo the third party audit in mid-October. Although we were trained on Rev C, we will be auditing to Rev B, which we've discussed with our trainer. Since Rev C covers Rev B, he said it would not be necessary to edit our QPM. The probably now lies, as I knew it would, in the area of configuration management. In Rev C, it is addressed in Section 7.3.1 and I believe a flow chart would be adequate to address the procedure. However, would it be more advisable to actually write a procedure, per Rev B? I'm down to the wire so the less procedure writing I need to do, the better - but on the other hand I don't need this to become a major. Advice please!
Elizabeth
Sponsored Links
  Post Number #2
Old 12th August 2010, 02:06 AM
Joy
Re: Configuration Management - AS9100 Rev B or C
In Reply to Parent Post by Mbarr View Post
It is not in 7.3.1 but in 7.1.3. There is no specific need of a procedure. Without a documented procdure,you can have a system. For a machine shop like yours a strong system of product identification as per design specifications and changes may meet the requirements.
Thanks to Joy for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 12th August 2010, 11:59 AM
Mbarr
Marc, thanks for your answer and also thank you for correcting my dyslexia... I've had my head buried in this stuff for days and I'm starting to see double, triple and eveything else! As far as CM, we certainly have very well-defined product tracking system (we don't do design and are excluding it from our QMS) and I think what you're saying is that we are covered by this.
  Post Number #4
Old 12th August 2010, 12:20 PM
KwalityWonk
I am a little confused by your situation. Are you auditing to Rev B or C? Rev B requires a documented process whereas Rev C does not. Rev C does however require that you "establish, implement and maintain" a process that includes as appropriate those elements listed in 7.1.3. A bigger question is whether you have taken an exclusion to the design requirements (7.3 ), as Configuration Management Processes are required to be much more in depth if it is your design, as opposed to just Maintaining configuration status as directed by Customer, Design or Regulatory authority. Preparing for Rev C without a documented procedure, and auditing to Rev B will lead to a Major finding. If auditing to Rev B, disregard Rev C requirements until you are ready to update. Unfortunately, they do not make it easy to design a QMS that will meet both, unless you just bite the bullet and document everything. Good Luck in your preparations and on your audit. Sounds like you are asking the right questions.
  Post Number #5
Old 12th August 2010, 01:23 PM
ddunn's Avatar
ddunn
I'm a little confused here. A adequate flow chart is a documented procedure. I've often used flow charts for procedures with no problems during audits. They are quick, easy to understand and easy to use.
Thanks to ddunn for your informative Post and/or Attachment!
  Post Number #6
Old 12th August 2010, 04:53 PM
Mbarr
Thank you both for the input.
1) we have claimed an exclusion from Design 7.3. 2) We are auditing to Rev B, but our manual has been designed for Rev C. Confusing, yes, I know. I did clarify with our trainer that this would be ok, HOWEVER Config Mgmt. seems to be the major sticking point. I don't want a major finding (also, thanks for letting me know that it would be!)
I thought, but was not sure, that a flowchart was, in fact, a documented procedure. I just completed designing one to spell out our config. mgmt. system. It just seemed to do a better job of it than trying to write a procedure. (At this point my brain is pretty fried)
I think I've got it covered now... fingers are crossed! Just in case, I will double check with our trainer.
Thanks again!
  Post Number #7
Old 12th August 2010, 05:31 PM
KwalityWonk
Indeed, a flowchart will be fine for Rev B. You also stated that your Quality Manual is designed for Rev C. While most of the elements are the same or at least similar, the clauses have been shuffled around, and requirements for Configuration Management, Risk Management, and Customer satifaction have changed significantly. And how are meeting the intent of 4.2.2b(BOLD) that has been removed from Rev C? I'M sure you have thought of all this, however it sounds like it would be difficult to do Clause by Clause Comparison of the Rev B Std and your Manual. While that is not a requirement, it sure makes it easy to ensure you have covered everything. Just make sure you have covered all the requirements for Rev B in your Manual, and have Fun!!
  Post Number #8
Old 13th August 2010, 07:44 AM
Mbarr
Kwalitywonk,
As I fill out the Stage One Readiness Review for our auditor, i'm doing a lot of cross-referencing. It is exactly as you say - a shuffling of clauses! I think that's why my brain is fried. The main thing is that we've covered it, documented it, can explain it, and mostly - we can walk the walk! I'm sure I'll be writing to this forum ALOT this month.
Elizabeth
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Configuration Management - AS9100 Requirements Kasturi.P.Shetty AS9100, Nadcap and related Aerospace Standards and Requirements 8 24th June 2011 04:52 PM
Configuration Management Basics - AS9100 Koivisto - 2009 AS9100, Nadcap and related Aerospace Standards and Requirements 9 7th January 2009 04:12 AM
Compliance with AS9100 Configuration Management Requirements chandrasekar2000 AS9100, Nadcap and related Aerospace Standards and Requirements 2 30th December 2008 10:01 AM
Configuration Management Exemption? AS9100 normzone AS9100, Nadcap and related Aerospace Standards and Requirements 14 15th September 2008 12:29 PM
AS9100 - 4.3 Configuration Management - Regulatory impositions Chriso AS9100, Nadcap and related Aerospace Standards and Requirements 26 18th April 2006 11:36 AM
The time now is 11:15 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
