The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Quality Assurance Discussion Forums > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Wooden Line
How do you calculate an AQL Confidence Level?
Monitor the Elsmar Forum
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering's
Quality Digest
LinkedIn Groups
ISO 9001 for Small Businesses
Information Security Community
Medical Devices Group
Quality and Regulatory Network
AS91XX Series - Tips and Advice
FDA (Food and Drugs)
Related Topic Tags
aql (acceptable quality level), statistical analysis and studies, confidence level (statistics)
Reply
  Post Number #1
Old 13th September 2010, 12:37 PM
QApoultry
Question How do you calculate an AQL Confidence Level?
Help with a question? How do you figure Confidence level?
I had a inspector/auditor want a lot of product 12,000 lbs inspected at a 95% confidence level?
Obviously he wasn't too skilled on AQL and Statistics but neither am I.
Based on my ANSI slide rule that would be Code letter M or 315 pounds
base on inspection level II.
No can someone help me how far am I off and I guess I am getting AQL and confidence levels confused. Any assistance would be appreciated.
Sponsored Links
  Post Number #2
Old 13th September 2010, 12:51 PM
Duke Okes
Re: How do you calculate an AQL Confidence Level?
Typically we don't calculate an AQL, we set one then select a sampling plan that will achieve it.
Thanks to Duke Okes for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 13th September 2010, 01:37 PM
somashekar's Avatar
somashekar
In Reply to Parent Post by Duke Okes View Post
The confidence level tells you how sure you can be. It is expressed as a percentage and represents how often the true percentage of the population who would pick an answer lies within the confidence interval. The 95% confidence level means you can be 95% certain; the 99% confidence level means you can be 99% certain.
So you have a sampling plan for various AQL determined seperately for a 95% confidence level and 99% confidence level. You determine the confidence level you want to apply.
  Post Number #4
Old 13th September 2010, 03:34 PM
Tim Folkerts's Avatar
Tim Folkerts
I see several difficulties with your situation.
  • AQL is typically applied to discrete objects, not to bulk materials (which is what I assume you have here). So AQL would be a strange choice to begin with in your case. It could be done -- basically assuming that you have 12000 individual lots of 1 pound.
  • If you can measure a "variable" (like the actual density of the sample) instead of an "attribute" (like "yes or no: is the density under 2.3 g.cm^3), then you can use a variable sampling plan, which typically requires a MUCH smaller sample to achieve the same level of confidence.
  • AQL plans provide pretty much the oppose of the sort of confidence you want. A typical Level II normal inspection tells you that you are "NOT 95% confident the lot is bad" so you accept the lot, even though bad lots could get by quite often. You presumable want to be "95% confident the lot is NOT bad" so you can accept the lot with confidence. These are two very different things.
  • You need to state WHAT you want to be 95% confident of. For example "95% confident that there is no more than 1% foreign material," which would lend itself to variable testing. You could also do something like "95% confident that 1 lb samples would pass inspection 99% of the time," which would lend itself to attribute sampling.
  • Furthermore, the choice to use pounds as your unit is completely arbitrary. You could just as well call it 5500 kg or 6 tons. Those choices would obviously change the sample sizes and the inspection costs. Generally I would suggest finding the smallest unit that would give reliable results. Maybe you can test just an ounce and get a good result. maybe you need to test a pound or 10 pounds to get a representative sample.
I'm sure others will weigh in with more advice.
Tim F
Thanks to Tim Folkerts for your informative Post and/or Attachment!
  Post Number #5
Old 13th September 2010, 09:48 PM
George Weiss
Is the auditor attempting to guide you into ISO/IEC-17025:2005 testing compliance?
When I hear 95% I think of 17025 coverage factor of 2, (k2), and 99% being a coverage factor of 3, (k3).
Determine what is to be tested for, and sample test for these items with a k2 or k3 coverage as in 17025
  Post Number #6
Old 14th September 2010, 12:04 PM
Bev D's Avatar
yes - your auditor's request is non-sensical as they have incompletely specified their request for inspection.
  Post Number #7
Old 14th June 2011, 11:55 AM
Jim G101
If I understand correctly then, you would have to use each Sample Size Code Letter on its own merit, correct? Example:
I have a team of 8 personnel doing a task to the same work instruction/ performance standard. I want to do a sample size of those 8 personnel. As an industry norm, I have decided to use GIL 2, w/ an AQL of 2.5. GIL 2 says use Sample Size Code Letter A. Using Single, Normal chart, actually evaluate 2 personnel. 2.5 AQL says accept the performance of the team if both operators are complying with requirements and reject (fail the team) if one of those operators is not complying with instructions (fails). For management, I can tell them we have a 90% Confidence Level that evaluations will only miss 2.11 non conformances out of every 100 observations (instruction requirements/ checklist items) or a 90% Confidence Level that we will accept team performance 97.91% of the time. (No 2.5 AQL in tables for A and B, go to Table X-C-1, 90% Pa (loosely a 90% Confidence Level). Is this correct?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Formula to tie together - Confidence/Reliability Level AQL? LTPD? Romvill2002 Reliability Analysis - Predictions, Testing and Standards 2 8th April 2015 01:47 AM
Confidence Level in percent (i.e 90 or 95%) at AQL .65? paperclip AQL - Acceptable Quality Level 4 29th June 2010 08:16 PM
AQL - How to calculate aql and aql level moonlight - 2011 AQL - Acceptable Quality Level 3 6th November 2009 09:50 PM
How to connect AQL to confidence level? Xinyuli AQL - Acceptable Quality Level 2 6th June 2008 01:00 PM
What is the confidence level for a given AQL in zero sampling plan Yew Jin AQL - Acceptable Quality Level 4 10th August 2007 04:07 AM
The time now is 03:57 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
