Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th March 2002, 12:10 PM
anrappa
Unregistered Guest
Posts: n/a
Question Process Standard deviations and equivalence of Cp & Cpk
Hello Ladies & Gentlemen
By principle of natural tolerancing, the product tolerances are to be so selected that they lie within +/- 3SIGMA of the mfg process
My questions are :
1. Is a table / database giving the standard deviations of various processes(specifically machining processes)available.If yes, could somebody give me the reference/links.
If no, do we have to arrive at the standard deviation of various processes only thro analysis of past data.Could sombody clarify.
2. It is said that cpk = 1.67 implies cp = 2.00. How is this arrived at.
Regards:
Sponsored Links
Old 13th March 2002, 01:48 PM
Dave Strouse's Avatar
Dave Strouse Dave Strouse is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 46
Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.
Default Don't believe it exists
Thoughts on your questions-
(1) I don't think you will be successfull in finding any tables for process standard deviations. There are so many factors, I can't imagine they would be tabulated.
How are you going to use it anyway? I believe you will need to develop this data yourself.
(2) WHO says.
I don't understand what in the world is meant.
Cp is (USL-LSL)/6s.
Cpk is closest or minimum of (USL- xbar/3s, Xbar-LSL/3s). The relationship of Cp to Cpk is Cpk =Cp(1-k) where k (|m-u|/(USL-LSL)/2 and m = (USL+LSL)/2 or the midpoint. But 0 to 1 is the range for k. So Cpk can be almost any value in relation to Cp.
The statement as I read it says that a Cpk of 1.67 always has Cp of 2. One counter example should disprove this.
Consider where LSL is 0 , USL is 10 sigma . Midpoint of spec is at 5 sigma. Cp is 10/6 or 1.67. Since a distribution could be centered on the mean i.e. k=0, we also have Cpk of 1.67.
Let's approach it another way. When will cp of 2 equal cpk 1.67?
From the formula above 1.67 = 2(1-k) or k =0.165.
So only at the k=0.165 value will the statement be true. Don't see how it implies anything remarkable.
Sponsored Links
Old 13th March 2002, 02:33 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
anrappa,
There are no 'standard' values for process std. deviations for manufacturing processes. In any case if you set the tolerance limits 'within' your +/- 3 Sigma limits what would be the process capability? Tolerance represents Customer's voice and process spread is the voice of the process. You will have to study your individual process variation and review tolerances only when it is just not possible for the process to produce within tolerance. I will quote from Grant:
"..specification limit is, of course, the service need of the part. This is not primarily a statistical matter....It often happens that the service needs can be judged more accurately with the aid of statistical methods....There is no use specifying desired tolerances on any quality characteristic without some prospect that these can be met...."
You could determine the variaton by conducting experiments and probably tell the designers what you can achieve. If you best effort does not meet the service requirement, I suppose you'll have to look for a better process.
Cpk=1.67 DOES NOT automatically imply Cp=2. This should be apparent from the formulas used to compute these indices as well as from a simple diagram that explains Cp/Cpk. Look at :
http://www.symphonytech.com/articles...capability.htm
Cp is (Spec width/process width).This does not take into account the centering of the precess. Cpk does that. (As Dave has already explained)
I think you are confusing this with something else -like a six-sigma process has Cp=2 etc?
-Atul.
Old 14th March 2002, 03:25 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Lightbulb That's it..
Yep that's it
So, simply put you can have a process that is centered way outside tolerance limits and still get a good Cp value, because the spread is good. The Cpk value, on the other hand would be very poor indeed.
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Are Process Behavior Charts the only way to Analyze Deviations from Targets? D.Salman SPC Monitoring and Statistical Analysis Techniques 6 31st January 2008 10:59 AM
How do you handle process deviations? ScottK ISO 9001 - Quality Management Systems Standard 9 9th October 2006 03:30 PM
Gage R&R - Anova Method - Standard Deviations vs. Variances rderoeck Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 21st October 2005 04:03 PM
Cp & Cpk - How are you calculating the standard deviation? MSHELLEY Capability, Accuracy and Stability - Process, Machine, etc. 3 19th February 2001 07:35 AM
Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? G.Hester Capability, Accuracy and Stability - Process, Machine, etc. 3 29th March 2000 10:59 AM
The time now is 12:18 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
