The Elsmar Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Failure Modes Services and Solutions to ProblemsElsmar Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Discussion Forums > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Wooden Line
Spark Testing for Coating Applications
Search the Elsmar Cove
Search Elsmar
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
  Post Number #1
Old 16th March 2002, 11:53 AM
energy
Total Posts: n/a
Question Spark Testing for Coating Applications
Does anybody have experience in calibrating a High Frequency Generator Tester for Leak Detection? We have an Electro Technic Products Model BD-60 (2,000-40,000 @ 1/2 Megahertz Frequency) that is used to detect pin holes in our Pressure Vessels interior lining. My question has to do with the Calibrator we purchased to determine the proper spark length (gap). We will be, undoubtably, be questioned on the calibration of this device by our future Registrar Auditor. The instructions that came with the Calibrator has caused me some concern as to the proper method for determining the actual voltage applied to the coated surface. Any help will be appreciated. I figure I would try here before getting into it with the Manufacturer. You know, practical hands-on experience?
Sponsored Links
  Post Number #2
Old 18th March 2002, 05:07 PM
Jerry Eldred's Avatar
Jerry Eldred
I don't think I'll be of much solace. I don't know anything about the particular manufacturer of the unit. But my experience has been that manufacturer's calibration instructions range anywhere from excellent to nothing.
In the cases where there is apparently nothing, there is no substitute in my experience for doing the digging. you'll have to pull out the claimed specifications, then spend some time on the phone with them digging out their method for making the measurements traceable.
There is the possibility in some cases that manufacturer's won't be forthcoming. The best you can do in some cases is get their method good or bad, and use that method. If the traceability seems inadequate, there is a grey line somewhere between doing it the same way the manufacturer does... period; and determining the manufacturer's method simply isn't adequate.
I took a look at their website. I didn't see any plu/minus tolerances listed. Some of the issue depends on how tight they spec the units. If it is simply a range of voltages, it isn't uncommon to see a spec of < for the bottom end to > for the top end. If that is the case, the required method won't be any more stringent than the spec (which in my example is very loose).
I think the test method would probably need to be a high voltage probe with adequate bandwidth and voltage. I'd be curious to see the calibration instructions. If you have something you could email to me, I may be able to give you some more detailed comment offline.
Sponsored Links
  Post Number #3
Old 18th March 2002, 07:35 PM
energy
Total Posts: n/a
Thumbs up Thanks, Jerry
I kind of thought so. You're interest in this is appreciated. The fact that you went to their website looking for assistance, impressed me. I will scan the instructions and send them to you along with what I see as a problem. Please stay tuned.
  Post Number #4
Old 19th March 2002, 03:03 PM
energy
Total Posts: n/a
BIG Smile What, me Worry?
Jerry,
The concern I had regarding the amount of voltage applied to the lining of our vessels has diminished considerably since I obtained the Operating Sheet for the Calibrator. The instructions are pretty much what you alluded to in your post. Statements such as “may vary between 200-400V per Mil of thickness” and “to adjust sensitivity, reduce sensitivity somewhat” and “there is approx. ¼” spark difference between starting voltage and breaking voltage”, indicates that there is no exact voltage measurement possible between coating applications. It would drive someone with a desire to “measure” actual voltage, batty. The calibrator gets you in the ballpark with the generator settings. So, I can have the machine set to deliver a voltage between 2 to 4kV for a 10 Mils of coating. 4kV-8kV for 20 mils and so on. We typically apply a minimum of 60 mils up to 80-100 mils. It’s a spray and bake operation. You can do the math. One good thing came from this, besides peace of mind. Whoever wrote our work instruction saying we apply 6000-8000 Volts to our lining must have only read the first sentence, or were out to lunch. As I was simulating the spark gap we usually use, the calibrator was indicating approx. 25,000 Volts. I was verifying the procedure, before releasing it. We will put in the voltage ranges we may be obtaining in the procedure and simply scribe a reference mark on the power setting and the sensitivity setting to make sure that the knobs are in the same location all the time. (approx.) Once a quarter, we will verify the settings and ranges and document it. As for the Calibrator, I will probably send it out to the Manufacturer every two years for its own verification. Maybe three years. The use for this device is really to make sure that you are not applying excessive voltage/corona that could damage the lining and enough voltage to ensure that there are no pinholes or bare spots. There is a wide spread between the two parameters. Thanks for the response. If you see anything here that you think would cause an Auditor concern, let me know.
And, yes, we have self calibrating Coating Thickness Tester.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Testing Zinc Coating on Expanded Metal pog451 Manufacturing and Related Processes 7 17th June 2014 09:22 PM
Typical Wire Harness Testing and Validation Testing for Automotive Applications optomist1 Reliability Analysis - Predictions, Testing and Standards 8 23rd December 2013 06:36 AM
Hydrophilic Coating of Catheter Shafts Failing Durability Testing henderscheid - 2010 ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems 2 15th October 2008 09:53 AM
XRF vs. Spark Test for RoHS Compliance Verification Eusoof RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 24 15th January 2008 10:58 AM
Power cuts in Germany spark wave of blackouts across Europe Marc National and International News 2 6th November 2006 07:34 AM
The time now is 02:17 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
NOTE: This forum uses "cookies".
