Elsmar Cove Quality DiscussionsDFMEA & PFMEA - Special Characteristics IdentificationThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
critical characteristics, detection ranking (fmea), dfmea (design fmea), fmea - failure modes and effects analysis, occurrence ranking (fmea), pfmea (process fmea), process fmea, severity ranking (fmea), special characteristics, significant characteristic(s)
Reply
  Post Number #1
Old 18th October 2010, 06:07 AM
tcastelino
Please Help! DFMEA & PFMEA - Special Characteristics Identification
Hello Everyone,
I'm a quality consultant, working in many industries, but mainly automotive, aerospace and consumer goods. I have some specialist experience in FMEAs, but would like to clarify the following:
A) Can anyone advise on what criteria are used to identify the following Special Characteristics in a DFMEA and PFMEA, in terms of Severity, Occurrence and Detection rankings?
1. Critical Characteristic
2. Significant Characteristic
3. Major Characteristic
4. Standard Characteristic
This information would normally be shown in the 'Classification' columns of the FMEAs. Attached are what I believe to be the normal criteria used by Ford and Visteon. Are these correct, or does anyone know of amendments to these?
B) Does anyone know the significance/meaning of of the 'Y' and 'V' prefix for YS (potential significant characteristic) and VS (confirmed significant characteristic).
I would really appreciate your feedback on these points
Attached Files: 1. Scan for viruses before opening, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
File Type: xlsx Special Characteristics Identification - Ford & Visteon Comparison.xlsx (11.0 KB, 646 views)
Thanks to tcastelino for your informative Post and/or Attachment!
Sponsored Links
  Post Number #2
Old 18th October 2010, 06:57 PM
Stijloor's Avatar
Stijloor
Re: DFMEA & PFMEA - Special Characteristics Identification
In Reply to Parent Post by tcastelino View Post
Hello Everyone,
Any feedback?
Thank you!!
Stijloor.
  Post Number #3
Old 19th October 2010, 02:42 AM
joker33
Can anybody reply to the above question of tcastelino?
  Post Number #4
Old 19th October 2010, 06:24 PM
adamsjm
Special Characteristics are based upon risk. Ford (and therefore Visteon) use a severity / occurrence table for this (see FMEA ver 4 ref. manual). Per your attached spreadsheet, if the "potential effects of failure" severity rating is a 9 or a 10 then the potential failure mode is critical and corrective action / re-design must be taken to reduce the severity. [Check with Ford's or the Visteon Supplier Quality Engineer to see if an occurrence of a 1 is acceptable.}
DFMEA: If the "potential effects of failure" severity rating is a 5, 6, 7 or 8 and the occurrence of the potential cause is a 4 or greater then the potential cause is "Significant" and requires re-design / improved and/or improved design tools to be proven in the recommended section of the DFMEA. If this cannot be accomplished in the DFMEA (such as part tolerance), then it may be passed to the PFMEA for risk reduction (again via the recommendation section). If Manufacturing can prove acceptable Cpk, then they have proven "occurrence reduction" which can be fed-back to the DFMEA. But keep the "Significant"characteristic on the PFMEA as a reminder as to why SPC or proof of tolerance compliance is required on that dimension.
  Post Number #5
Old 20th October 2010, 12:43 AM
Richard Pike's Avatar
Richard Pike
Not quite in agreement there.
Special Characteristics have many meanings. Look at all the different definitions in TS / VDA / AIAG etc etc.
A common auditor "nuance" is to state that if a severity factor is 9/10 then we must have corrective action. not true -- only if it "relies on detection". I will ALWAYS have 9/10 and no amount of corrective action (other than a process/productdesign change) will fix it.
One of the better definitions of Special - is if it needs special control. This applies especially to charecteristics that cannot be verified easily - and therefore the Process Charecteristic controling the product charecteristic becomes "special".
In essence my best advice is to define them according to your own needs -- and then to see if the use of those definitions - assist you in applying resources to the areas that need them.
If the definitions do no assist you in applying resources where needed - then the definitions are wrong. Hence they cannot be generic (as some auditors advise) but must be customised to suit the organisation.
  Post Number #6
Old 20th October 2010, 03:22 AM
tcastelino
Adam & Richard,
Thanks for your replies. My understanding of the Critical and Significant Characteristics is the same as yours, but the Major and Standard Characteristics is new to me. I was wondering whether you have any idea as to the numbering criteria (ref attached spreadsheet) that apply to the DFMEA (if applicable) and PFMEA to define these two characteristics.
File Type: xlsx Special Characteristics Identification - Ford & Visteon Comparison.xlsx (11.1 KB, 340 views)
  Post Number #7
Old 20th October 2010, 12:54 PM
adamsjm
... but the Major and Standard Characteristics is new to me. I was wondering whether you have any idea as to the numbering criteria (ref attached spreadsheet) that apply to the DFMEA (if applicable) and PFMEA to define these two characteristics.
It appears that Visteon is separating DFMEA from PFMEA Characteristics. They are also appear to be basing their risk category solely upon severity.
I would check the Ford (& Visteon) FMEA manual or contact the SQE for your product.
Per Richard Pike
I was addressing the question as viewed by the AIAG members FORD / Visteon. Not all possibilities.
Thanks to adamsjm for your informative Post and/or Attachment!
  Post Number #8
Old 21st October 2010, 03:53 AM
cmi001
Visteon is one of our customers. Generally, I cannot see this method deviated to the TS-16949 requirement (at least for 7.3.2.3).
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
DFMEA, PFMEA and KCC's (Key Control Characteristics) Relationships Ajgupta FMEA and Control Plans 11 30th August 2016 03:45 PM
Design (DFMEA) and Process (PFMEA) FMEA Failure Mode Identification YKT Design and Development of Products and Processes 8 11th June 2012 03:18 PM
Special Characteristics Identification x Classification Jason Volney FMEA and Control Plans 3 15th February 2012 06:25 PM
Identification of Special Characteristics - Cl 7.3.2.3 Interpretation andrewg IATF 16949 - Automotive Quality Systems Standard 5 3rd September 2009 02:23 PM
Special Characteristics in DFMEA (Design FMEA) - Carry over to PFMEA? Labbe FMEA and Control Plans 9 28th October 2004 01:42 PM
The time now is 09:48 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
